POV-Ray : Newsgroups : povray.binaries.images : QUESTION: Bump not showing? Server Time
1 Apr 2026 12:31:46 EDT (-0400)
  QUESTION: Bump not showing? (Message 77 to 86 of 91)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: QUESTION: Bump not showing?
Date: 28 Jul 2017 21:15:01
Message: <web.597be1699f453b979c5d6c810@news.povray.org>
Sven Littkowski <I### [at] SvenLittkowskiname> wrote:
> Okay, everyone: I herewith declare myself as a big fool!
> I use POV-Ray for soooo many years, since around 1990 or so, and can you
> believe it I just oversaw all the time of posting here, that I used:
> QUALITY = 6
> And did not even think about checking for the Q setting!!!!!
> SHAME ON ME! I wasted so much of your all valuable time! But at least,
> one more time the POV-Ray community has proven its great pioneer-alike
> spirit! I owe you all my big thanks!
That explains it.
You have been raytracing too long when... quality settings are forgotten!
LOL
I am glad that problem is solved, regardless of why!
I was just about to email you back to say it looks okay again.
Although before I rendered the balloon, seeing that very dark texture image_map
for it, I was thinking it must be too dark to show the normal_map. Yet it isn't,
mine looks the same as your quality change render now.
P.S.  Still don't know if you want that parachute piece hovering over the
balloon (makes the little shadow on left top edge).
I keep removing it by using:
#declare LowerBalloonShape = difference
 sphere { < 0.0, 0.0, 0.0 > MyRadius }
 cylinder {
  < 0.0, 0.0, 0.0 > < 0.0, /*175.001*/MyRadius+0.001, 0.0 >
   MyRadius+0.001 }
 scale < 1.0, 1.5, 1.0 >
Date: 28 Jul 2017 23:07:31
Message: <597bfbf3@news.povray.org>
Le 17-07-28 à 19:17, Sven Littkowski a écrit :
> On 27.07.2017 08:16, Stephen wrote:
>> On 7/27/2017 12:19 PM, Thomas de Groot wrote:
>>> On 27-7-2017 11:34, Stephen wrote:
>>>> Has anyone collect Sven's code? I don't fancy going through the thread
>>>> to piece it all together. And I've not been following it closely.
>>> This is the latest, with my amendments. See also the attached images I
>>> used.
>> Thanks Thomas.
>> The results were as expected. The shadows showing.
>> But is this expected? It is the top of the balloon.
>> [Drat! I can't put them inline.]
>> Using Sven's original code. I imported it into Bishop3D correcting the
>> errors one by one. Using the image maps you supplied. The second image
>> is directly from Sven's code.
>> What concerns me is:
>>    image_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher
>> - Balloon - Type 001 - Moon Runnings - Balloon Texture.png" }
>> Are those spaces and dashes part of the file name?
> Yes, they are part of the file names. But they cause no error message,
> as POV-Ray gives them straight to the Windows system, and Windows is
> handling the file management.
> Please use my balloon texture for the outside, and let us know, if you
> still get bumps.
> Diese E-Mail wurde von AVG auf Viren geprüft.
> http://www.avg.com
Well, that image is all pure black... So, unless it have reflection of
high specularity, the bumps will have a practically impossible task
showing up.
Date: 29 Jul 2017 00:04:57
Message: <597c0969$1@news.povray.org>
>> QUALITY = 6
> That explains it.
> LOL
> Bob
>  cylinder {
>    MyRadius+0.001 }
Really, I am sooo ashamed. :-D
Thanks for reminding me about that parachute. I didn't see it yet, but I
will give now more distance with the camera to see it.
YES - that parachute gotta go! I use now your suggested code that I
should have added long time ago. I simply forgot that area, when i a
longer time ago changed the diameter from 175 to 200.
Starting to think now about the best outside surface attributes
(finishes). Don't know, how the surface attributes of a balloon are, I
admit. it is not one of those ultra-thin surfaces, because of the huge
size of the balloon. The surface material would be more similar to that
of a zeppelin, I think, as more stability is required. After all, we
speak about a total diameter of 400 meters! :-)
http://www.avg.com
Date: 29 Jul 2017 03:02:33
Message: <597c3309$1@news.povray.org>
> still get bumps.
Has /this/ image been your balloon texture all along? Then, I am /not/
surprised that you do not see any bumps: the image is completely black! ;-)
Date: 29 Jul 2017 03:32:40
Message: <597c3a18$1@news.povray.org>
>> still get bumps.
> Thomas
Hi, the problem was been solved already, but big thanks anyhow.
We found what was wrong, in fact it was a seldomly stupid error: I
forgot to change the QUALITY from 6 to a better level (using 10 now).   :-)
http://www.avg.com
Date: 29 Jul 2017 07:22:26
Message: <597c6ff2$1@news.povray.org>
The devil is in the detail :-)
Date: 29 Jul 2017 08:02:46
Message: <597c7966$1@news.povray.org>
> #version 3.7;
> #include "kolors.inc"
Thanks but since you found the problem it is not needed now. :-)
Don't be embarrassed about the quality setting. These things happen.
Regards
Date: 30 Jul 2017 05:51:23
Message: <597dac1b@news.povray.org>
Kenneth, here is the texture file, latest version.
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon texture.png' (1217 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon texture.png'
Date: 30 Jul 2017 07:00:00
Message: <web.597dbbd79f453b97883fb31c0@news.povray.org>
Unfortunately, what I'm seeing is *almost* a completely black image, and with a
*completely* white alpha-channel. I checked it out in Photoshop.
I made some screen shots of what I'm seeing, and will post them in the IMAGES
section...
Date: 30 Jul 2017 07:28:04
Message: <597dc2c4@news.povray.org>
> section...
This is the images section, Kenneth. ;)
This is what I get after using "Edge Enhance" 8 times.
Regards
Download 'image3.png' (3663 KB)
Preview of image 'image3.png'
