POV-Ray : Newsgroups : povray.binaries.images : QUESTION: Bump not showing? Server Time
16 Jun 2026 23:37:56 EDT (-0400)
  QUESTION: Bump not showing? (Message 31 to 40 of 91)
Subject: Re: QUESTION: Bump not showing?
Date: 25 Jul 2017 19:31:21
Message: <5977d4c9$1@news.povray.org>
On 25.07.2017 01:06, clipka wrote:
> Am 25.07.2017 um 01:41 schrieb Sven Littkowski:
>> Thanks a lot for your assistance, so far. But I admit, I am now irritate
d.
>> Did you see the bump image I posted inside the other group (GENERAL)
>> with the same topic? Someone there told me to reduce the image size,
>> make it 16bit, and increase the contrast between dark and bright areas
>> there. I did that all. Still - no success.
> I'm not sure what you are doing there. With the new bump map and using
> the scene from your original post, the attached image is what I get
> (after repairing broken comments and replacing the image_map with a
> plain white pigment).
> That looks like bumps to me. (Excessively strong ones, actually; try
> `bump_size 10` or lower.)
> You still have some residual issues:
> - Contrary to my recommendation, you apparently did not re-generate the
> image with higher contrast and bit depth, but rather just converted the
> old image and blurred it a bit. This still leaves you with artefacts
> from the original color banding.
> - You are using `gamma 1.8` in a bump map. This indicates to me that
> /something/ regarding gamma is not quite right: Either you didn't
> understand what you were doing, or your bump map uses a poor encoding
> scheme that gives you more precision in black areas than it does in
> white areas. (To tell which of the two is the case, I'd have to know
> more about how you created the bump map in the first place.)
> - Your radiosity block does not contain a `normal on` statement. As a
> consequence, if you turn on radiosity, you will not see any bumps in
> areas that are lit only indirectly.
It seems, with my graphic program I can work only with one layer, if it
comes to 16bit. Cannot create any additional layers when in 16bit, and I
would need, in order to crate a similar pattern.
I use Photoshop v7.0. That is the reason, why I could not create the
image you suggested (and I agree on).   :-(
Will create a new bump image, but it will be again 8bit. But I create it
as a smaller version. Hoping for the best.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 25 Jul 2017 20:01:32
Message: <5977dbdc@news.povray.org>
Latest Scene Code, Latest Bump, Latest Result
(still no bumps)
#version 3.7;
#include "kolors.inc"
#include "finish.inc"
#include "textures.inc"
#declare MyRadiosity = off;
//#declare MyBackground = "SL_Space_Scene_003"; // Wormhole /
SL_Space_Scene_003 /
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#declare LightDiameter =     10000.0;
#declare LightDistanceX =  -500000.0; // X = Left - Right
#declare LightDistanceY =  1000000.0; // Y = Up - Down
#declare LightDistanceZ =  -100000.0; // Z = Front - Back
#declare LightRotate =          36.0;
#declare MyLight =             0.125;
camera
 location < -000.0, 400.0, -500.0 >
 look_at < 0.0, -200.0, 0.0 >
 right 1.77*x
light_source
 < 2500.0, 2500.0, 500.0 > //< 2500.0, 2500.0, 5000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *1.5 // bright!?
 area_light x*100,z*100,5,5 circular orient
 area_illumination
light_source
 < -50.0, 50.0, 0.0 >
 rgb < 0.3, 0.4, 0.8 > *1.1
#declare MyLight = light_source
 < -1000.0, 1000.0, 1000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *0.25
// spotlight
// point_at < 0.0, 25.0, 100.0 >
// falloff 100.0
// radius 10.0
// fade_distance 50.0
// fade_power 4
union
 object { MyLight rotate < 0.0, 000.0, 0.0 > }
 object { MyLight rotate < 0.0, 036.0, 0.0 > }
 object { MyLight rotate < 0.0, 072.0, 0.0 > }
 object { MyLight rotate < 0.0, 108.0, 0.0 > }
 object { MyLight rotate < 0.0, 144.0, 0.0 > }
 object { MyLight rotate < 0.0, 180.0, 0.0 > }
 object { MyLight rotate < 0.0, 216.0, 0.0 > }
 object { MyLight rotate < 0.0, 252.0, 0.0 > }
 object { MyLight rotate < 0.0, 288.0, 0.0 > }
 object { MyLight rotate < 0.0, 324.0, 0.0 > }
 translate < -1000.0, 0000.0, -1000.0 >
#declare MyRadius = 200.0;
#declare PositiveBump = normal
 bump_map
  png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher - Balloon -
Type 001 - Moon Runnings - Balloon BumpMap.png"
 translate -0.5
 rotate < 90.0, 0.0, 0.0 >
 scale MyRadius*2
 bump_size 0.02
#declare NegativeBump = normal
 bump_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher -
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" map_type 0
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
#declare MyOuterBalloonFinish = finish
// reflection   0.00
 crand        0.10
#declare MyInnerBalloonFinish = finish
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
#declare MyOuterBalloonTexture = texture
 pigment
  image_map
Type 001 - Moon Runnings - Balloon Texture.png"
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
   [ 0.175 PositiveBump ]
   [ 0.175 NegativeBump ]
  scale < 1.0, 1.5*MyRadius, 1.0 >
 finish { MyOuterBalloonFinish }
#declare MyInnerBalloonTexture = texture
 pigment { color rgb < 0.7686275,  0.7607843,  0.7333333 > }
 normal
  gradient y
  normal_map
  scale <1,1.5*MyRadius,1>
 finish { MyInnerBalloonFinish }
#declare UpperBalloonShape = torus     // Balloon Radius: 175 m /
Launcher Radius: 10 m
 95.0, 105.0
 scale < 1.0, 0.5, 1.0 >
#declare LowerBalloonShape = difference
 sphere { < 0.0, 0.0, 0.0 > MyRadius }
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 175.001, 0.0 > MyRadius+0.001 }
 scale < 1.0, 1.5, 1.0 >
#declare MyBalloonHullOutside = union
 object { UpperBalloonShape }
 object { LowerBalloonShape }
 texture { MyOuterBalloonTexture }
#declare MyBalloonHull = difference
 object { MyBalloonHullOutside hollow }
 cylinder  // Launcher Openings
  < 0.0, -((MyRadius*1.5)+0.001), 0.0 > < 0.0, (MyRadius+0.001), 0.0 > 3.5
  texture { MyInnerBalloonTexture }
#declare Launcher = difference
 union
  #declare MyLength = 10.0;
  #declare MyHeight = 0.0;
  #declare MyTop = 35.0;
  cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 > < 0.0, MyTop, 0.0 >
3.5 }
  box { < MyLength, -MyHeight, -0.1 > < -MyLength, MyTop, 0.1 > rotate <
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
 cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 > < 0.0, MyTop+0.001,
0.0 > 3.3 }
 pigment { color rgb 1.0 }
#declare DoublePositionLight = union
 union
  cylinder { < 0.0, 0.0,  2.5 > < 10.0, 0.0,  2.5 > 0.20 }
  cylinder { < 0.0, 0.0, -2.5 > < 10.0, 0.0, -2.5 > 0.20 }
  pigment { color rgb < 0.05, 0.05, 0.05 > }
 union
  sphere { < 10.0, 0.0, 2.5 > 0.35 }
  sphere { < 10.0, 0.0, -2.5 > 0.35 }
  pigment { color rgbf < 1.0, 0.0, 0.0, 0.5 > }
  finish { ambient rgb < 0.3, 0.1, 0.1 > }
 union
  light_source
   < 10.0, 0.0, 2.5 >
   rgb < 0.7, 0.0, 0.0 > *10.0
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   rgb < 0.7, 0.0, 0.0 > *1.0
   fade_distance 50.0
   fade_power 4
#declare PositionLights = union
 #declare MyDistance = MyRadius-0.1;
 object { DoublePositionLight translate < MyDistance, 0.0, 0.0 > rotate
< 0.0, 045.0, 0.0 > }
< 0.0, 090.0, 0.0 > }
< 0.0, 135.0, 0.0 > }
< 0.0, 225.0, 0.0 > }
< 0.0, 270.0, 0.0 > }
< 0.0, 315.0, 0.0 > }
union
 object { MyBalloonHull }
 object { Launcher }
 object { PositionLights }
background { rgb < 0.02392157,  0.03490196,  0.04627451 > }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB) Download 'space - launcher - balloon - type 001 - moon runnings.png' (171 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png'
Preview of image 'space - launcher - balloon - type 001 - moon runnings.png'
Date: 25 Jul 2017 20:07:26
Message: <5977dd3e@news.povray.org>
Clipka, I created a new, more contrasting bump image. I dream to get
something like your result. My Photoshop 7 does not allow to work with
multiple layers if the mode is 16bit, thus I had to create it again
(sadly) in 8bit.
Please have a look at my latest scene code, I also tried to incorporate
the changed scene code of Omniverse, too:
#version 3.7;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 right 1.77*x
light_source
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
 bump_map
 translate -0.5
 scale MyRadius*2
 bump_size 0.02
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
 normal
  gradient y
  normal_map
 95.0, 105.0
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (171 KB) Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB)
Date: 25 Jul 2017 20:12:51
Message: <5977de83$1@news.povray.org>
On 25.07.2017 19:16, Stephen wrote:
> How long have you lived there?
> And English is a Germanic language.
Well, quite some time. Speaking English is the easiest for me. Listening
to English takes on a bit more concentration, but I can manage. But
reading in English takes on the most concentration, if I read too much,
i lose the contents and nothing reaches my understanding anymore, after
some time. That is how i would try to describe it.
English and German are not really similar, even if the modern English
has some of its roots in the Germanic language of the Saxons. Some parts
are Celtic, some parts are French, and some are even Latin (beside
French a 2nd Romanic language). But that is not so important. Important
is, how similar languages are. Not enough for me, to avoid this problem. :-
http://www.avg.com
Date: 26 Jul 2017 00:40:00
Message: <web.59781c979f453b979c5d6c810@news.povray.org>
All I can say is I can render your exact scene using your bump map file and see
how it should be.
However, there is trouble with the image_map. You say a "texture" name for that
one, yet didn't give another, so I used the same bump_map file for the texture
too.
I can see the shadowing on the surface, but the contrast is now so much I lose
sight of it in the darkest areas.
What I tried, again, is remove that image_map from pigment statement and
replaced with a simple:
color rgb 1 // plain white
Rendering posted.
And I was confused at first about the rounded shadow seen on the top left side
of balloon.
That was once again the 'parachute' piece, you don't actually see it until
moving camera farther away; I got rid of it before by replacing 175.001 with
MyRadius+0.001 in the SDL part:
 cylinder {
  < 0.0, 0.0, 0.0 >,
  < 0.0, MyRadius+001, 0.0 >, MyRadius+0.001 } // instead of y*175.001
Date: 26 Jul 2017 03:31:13
Message: <59784541@news.povray.org>
nd see
> how it should be.
r that
xture
> too.
 lose
> Rendering posted.
 side
> of balloon.
l
ith
>  cylinder {
>   < 0.0, 0.0, 0.0 >,
I made the balloon HOLLOW (instead of a difference). And removed the
TRANSMIT keyword. Looks better. But not getting any bumps. Made also the
top a bit flatter again 8as it was before).
Are you able to reproduce anything that looks like Clipka's balloon image?
Complete Scene Code:
#version 3.7;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 right 1.77*x
light_source
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
 bump_map
 translate -0.5
 scale MyRadius*2
 bump_size 0.02
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
 normal
  gradient y
  normal_map
 95.0, 105.0
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Date: 26 Jul 2017 07:20:42
Message: <59787b0a@news.povray.org>
> (still no bumps)
I didn't change anything to your code and used the bump map provided,
and this is what I get: bumps *are* visible!
Download 'sl_balloon.png' (87 KB)
Preview of image 'sl_balloon.png'
Date: 26 Jul 2017 07:28:32
Message: <59787ce0$1@news.povray.org>
>> (still no bumps)
Not entirely true ;-)
I added:
global_settings {
   assumed_gamma 1.0
which was demanded by your kolors.inc (and for obvious reasons when
using version 3.7) and I provided a uniform red colour texture for the
balloon (as an image_map).
Date: 26 Jul 2017 07:50:01
Message: <web.597880ca9f453b97c437ac910@news.povray.org>
> > (still no bumps)
> Thomas
This whole thing really reminds me of:
http://1.bp.blogspot.com/-IFTXBJQc0UU/VIHkNM5jKkI/AAAAAAAA2F8/yyWnsQBHmO4/s1600/gah1.jpg
Since it's from the 80's, maybe Yadgar will join this thread  ;)   :D
Date: 26 Jul 2017 07:55:48
Message: <59788344$1@news.povray.org>
>>> (still no bumps)
>> Thomas
Close Encounters of the Third(?) Kind? :-)
