POV-Ray : Newsgroups : povray.binaries.images : Egg Server Time
1 Jun 2024 21:47:29 EDT (-0400)
  Egg (Message 25 to 34 of 44)
Subject: Re: Egg
Date: 1 May 2017 08:12:45
Message: <5907263d$1@news.povray.org>
On 5/1/2017 1:06 PM, Stephen wrote:
> On 5/1/2017 12:11 PM, Thomas de Groot wrote:
>> Indeed, yes. Take my image as example, the dragon is scaled 0.01, the
>> egg 0.25, the cube is not scaled, and the floor 0.50. It seems best to
>> use a standard mm_per_unit and change translucency as needed.
Another thought:
If you use the same material for your three objects. There should be no
difference in the look of the objects. That might be a way to check if I
am talking rubbish or not. And I am talking about meshes not primitives.
Regards
Subject: Re: Egg
Date: 1 May 2017 23:57:14
Message: <5908039a$1@news.povray.org>
Le 17-05-01 à 02:50, Thomas de Groot a écrit :
> On 30-4-2017 18:30, Alain wrote:
>> Le 17-04-30 à 07:05, Thomas de Groot a écrit :
>>> On 30-4-2017 9:48, Thomas de Groot wrote:
>>>> In fact, the differences are more subtle. For the cube, compare the
>>>> shadows of dragon and egg: their edges show the stone's
>>>> translucency. In
>>>> my next render I hope to show this better.
>>> In this render:
>>> - Dragon: no SSLT
>>> - Floor: no SSLT
>>> - Cube: SSLT with 5*translucency vector (was 2* in earlier example)
>>> - Egg: SSLT with 3*translucency vector (was 2* in earlier example)
>>> The cube is showing markedly more translucency in the shadows cast on
>>> it. I see not much difference in the egg, although if I increase the
>>> translucency exaggeratedly (*100 for instance) the effect becomes
>>> distorted.
>>> Question: In the wiki about SSLT it is said: "The effect doesn't scale
>>> with the object". Does this mean that SSLT works in the same way as a
>>> scattering media where the amount of scattering has to be compensated
>>> for the amount of media object's scale? It appears so to me at least
>>> although this is not mentioned in the wiki.
>> It does work similarly to medias, both emissive, absorbing and
>> scattering.
>> So, if you scale your scene by 10 and want SSLT to look the same, then
>> you need to multiply your SSLT vector by 10. Alternately, you can
>> increase mm_per_unit by the same amount in the global_settings block.
> OK. Only difference would be that with scattering media (for instance)
> you have to /divide/ the scattering vector by the scale of the container
> to get the same result, but I get the point indeed.
> I am a bit wary about the mm_per_unit and prefer not to touch it too
> much, especially if different objects have different scales.
You should set it according to the overall scale of your scene.
The default of 10 mean 1 POV unit = 1 cm. Set it to 1000 if your scale
is 1 POV unit = 1 m, and 25.4 for 1 inch = 1 POV unit.
In my suggestion, it would make a scene scalled in cm work in mm. So,
you can change mm_per_unit from it's default of 10 to 1 to reflect the
change in overall scale.
Subject: Re: Egg
Date: 2 May 2017 02:48:37
Message: <59082bc5$1@news.povray.org>
>>> Yes Clipka has put the fear of god into us. :-)
>>> I suppose it depends what you intend by scaling the models.
> My understanding is that the mm_per_unit is the world/scene scale
> And to add to the confusion (on my part at least) meshes can have an
> internal scale and an external one. By internal scale I mean the scaling
> you can change in PoseRay before exporting and external is how you
> change it in PovRay.
> In Blender when using the physics engine the scale should be 1.0. So to
> scale a mesh. You need to edit it and scale it there. Otherwise you get
> unexpected results.
> So if the dragon is an ornament. I would scale it down in PoseRay. If it
> is a statue scale it up in PoseRay. Keep the mm_per_unit as the default.
> Having said that. I have not used SSLT since its RC3. :-(
> So what do I know?
This all makes a lot of sense indeed. Generally, I do not build a scene
with a particular scale in mind so I just assemble the elements and let
the observer do the rest. Thus, a landscape can very well be built by
either relatively small elements or by big ones, I do not care as I am
only interested in the final effect.
With SSLT it seems I have to be much more careful.... ;-)
Subject: Re: Egg
Date: 2 May 2017 02:51:35
Message: <59082c77$1@news.povray.org>
On 2-5-2017 5:57, Alain wrote:
[snip]
As I wrote in my answer to Stephen, I am shamefully negligent about
overall scales and just throw together elements to be brewed in the same
pot. I need to be a bit more careful if I want to include SSLT. :-)
Subject: Re: Egg
Date: 2 May 2017 03:25:25
Message: <59083465$1@news.povray.org>
Gosh! a first. :-)
I'm the same. I tend to build my scenes small. For some reason I don't
like wasting Pov space. Which means I use a lot of decimals but decimals
are cheap.
I tend to use Poser figures as a reference. Michael is about six feet,
in my mind.
I am sure if Clikpa were about. He would agree. ;-)
Regards
Subject: Re: Egg
Date: 2 May 2017 03:48:32
Message: <590839d0@news.povray.org>
> Gosh! a first. :-)
Really?
> are cheap.
They are indeed. However, I try to avoid too small ones. They are more
difficult to find when they drop to the floor. :-)
> in my mind.
Typically, I scale the figures to the environment they are to live in. :-)
Ah! The Clipka! He seems to have gone on holiday? Shame. He /knows/ he
cannot go without our permission. ;-)
Subject: Re: Egg
Date: 2 May 2017 04:03:20
Message: <59083d48$1@news.povray.org>
>> Gosh! a first. :-)
> Really?
I meant a first for today.
>> are cheap.
Alt+ LMB + drag scoops them up. :-)
(Bishop3D setting)
>> in my mind.
I was talking my dreams. In truth I scale my scenes by the first object
I create.
As long as he hasn't taken a marching band with him. It is okay. ;-)
Regards
Subject: Re: Egg
Date: 2 May 2017 07:02:04
Message: <5908672c$1@news.povray.org>
> unexpected results.
> So what do I know?
I have been pondering this a bit. I think that you do achieve the same
(using meshes of course) if you first do basic transforms (in POV-Ray)
and /then/ use that copy of the original object with SSLT. In fact, I do
that exercise quite often:
#declare MyObject =
object {MyMesh_POV_
   transform {MyTransforms}
object {MyObject
   material {MyMaterial}
   rotate {MyRotate}
   translate {MyTranslate}
Subject: Re: Egg
Date: 2 May 2017 14:47:47
Message: <5908d453$1@news.povray.org>
Am 30.04.2017 um 13:05 schrieb Thomas de Groot:
That depends on what you want to achieve.
If you want the object to look like a larger item made of the same
material, scale the object and use the same SSLT parameters.
If you want the object to look exactly the same, but take up a larger
portion on the screen, scale the object and adjust the SSLT parameters.
(Or zoom in on the object ;))
Subject: Re: Egg
Date: 2 May 2017 14:52:12
Message: <5908d55c@news.povray.org>
Am 01.05.2017 um 14:06 schrieb Stephen:
Indeed.
Also, I might take the opportunity to re-iterate that it is not an SSLT
setting /per se/. It only just so happens that SSLT is currently the
only feature that makes use of it.
