POV-Ray : Newsgroups : povray.binaries.images : Egg Server Time
1 Jun 2024 20:14:15 EDT (-0400)
  Egg (Message 21 to 30 of 44)
Subject: Re: Egg
Date: 1 May 2017 02:50:29
Message: <5906dab5$1@news.povray.org>
On 30-4-2017 18:30, Alain wrote:
> Le 17-04-30 à 07:05, Thomas de Groot a écrit :
>> On 30-4-2017 9:48, Thomas de Groot wrote:
>>> In fact, the differences are more subtle. For the cube, compare the
>>> shadows of dragon and egg: their edges show the stone's translucency. In
>>> my next render I hope to show this better.
>> In this render:
>> - Dragon: no SSLT
>> - Floor: no SSLT
>> - Cube: SSLT with 5*translucency vector (was 2* in earlier example)
>> - Egg: SSLT with 3*translucency vector (was 2* in earlier example)
>> The cube is showing markedly more translucency in the shadows cast on
>> it. I see not much difference in the egg, although if I increase the
>> translucency exaggeratedly (*100 for instance) the effect becomes
>> distorted.
>> Question: In the wiki about SSLT it is said: "The effect doesn't scale
>> with the object". Does this mean that SSLT works in the same way as a
>> scattering media where the amount of scattering has to be compensated
>> for the amount of media object's scale? It appears so to me at least
>> although this is not mentioned in the wiki.
> It does work similarly to medias, both emissive, absorbing and scattering.
> So, if you scale your scene by 10 and want SSLT to look the same, then
> you need to multiply your SSLT vector by 10. Alternately, you can
> increase mm_per_unit by the same amount in the global_settings block.
OK. Only difference would be that with scattering media (for instance)
you have to /divide/ the scattering vector by the scale of the container
to get the same result, but I get the point indeed.
I am a bit wary about the mm_per_unit and prefer not to touch it too
much, especially if different objects have different scales.
Subject: Re: Egg
Date: 1 May 2017 06:08:34
Message: <59070922$1@news.povray.org>
Yes Clipka has put the fear of god into us. :-)
I suppose it depends what you intend by scaling the models.
Regards
Subject: Re: Egg
Date: 1 May 2017 07:11:32
Message: <590717e4$1@news.povray.org>
Indeed, yes. Take my image as example, the dragon is scaled 0.01, the
egg 0.25, the cube is not scaled, and the floor 0.50. It seems best to
use a standard mm_per_unit and change translucency as needed.
Subject: Re: Egg
Date: 1 May 2017 08:06:14
Message: <590724b6$1@news.povray.org>
My understanding is that the mm_per_unit is the world/scene scale
And to add to the confusion (on my part at least) meshes can have an
internal scale and an external one. By internal scale I mean the scaling
you can change in PoseRay before exporting and external is how you
change it in PovRay.
In Blender when using the physics engine the scale should be 1.0. So to
scale a mesh. You need to edit it and scale it there. Otherwise you get
unexpected results.
So if the dragon is an ornament. I would scale it down in PoseRay. If it
is a statue scale it up in PoseRay. Keep the mm_per_unit as the default.
Having said that. I have not used SSLT since its RC3. :-(
So what do I know?
Regards
Subject: Re: Egg
Date: 1 May 2017 08:12:45
Message: <5907263d$1@news.povray.org>
Another thought:
If you use the same material for your three objects. There should be no
difference in the look of the objects. That might be a way to check if I
am talking rubbish or not. And I am talking about meshes not primitives.
Regards
Subject: Re: Egg
Date: 1 May 2017 23:57:14
Message: <5908039a$1@news.povray.org>
>>>> translucency. In
>>> In this render:
>>> - Dragon: no SSLT
>>> - Floor: no SSLT
>>> distorted.
>> scattering.
You should set it according to the overall scale of your scene.
The default of 10 mean 1 POV unit = 1 cm. Set it to 1000 if your scale
is 1 POV unit = 1 m, and 25.4 for 1 inch = 1 POV unit.
In my suggestion, it would make a scene scalled in cm work in mm. So,
you can change mm_per_unit from it's default of 10 to 1 to reflect the
change in overall scale.
Subject: Re: Egg
Date: 2 May 2017 02:48:37
Message: <59082bc5$1@news.povray.org>
> unexpected results.
> So what do I know?
This all makes a lot of sense indeed. Generally, I do not build a scene
with a particular scale in mind so I just assemble the elements and let
the observer do the rest. Thus, a landscape can very well be built by
either relatively small elements or by big ones, I do not care as I am
only interested in the final effect.
With SSLT it seems I have to be much more careful.... ;-)
Subject: Re: Egg
Date: 2 May 2017 02:51:35
Message: <59082c77$1@news.povray.org>
On 2-5-2017 5:57, Alain wrote:
[snip]
As I wrote in my answer to Stephen, I am shamefully negligent about
overall scales and just throw together elements to be brewed in the same
pot. I need to be a bit more careful if I want to include SSLT. :-)
Subject: Re: Egg
Date: 2 May 2017 03:25:25
Message: <59083465$1@news.povray.org>
Gosh! a first. :-)
I'm the same. I tend to build my scenes small. For some reason I don't
like wasting Pov space. Which means I use a lot of decimals but decimals
are cheap.
I tend to use Poser figures as a reference. Michael is about six feet,
in my mind.
I am sure if Clikpa were about. He would agree. ;-)
Regards
Subject: Re: Egg
Date: 2 May 2017 03:48:32
Message: <590839d0@news.povray.org>
> Gosh! a first. :-)
Really?
> are cheap.
They are indeed. However, I try to avoid too small ones. They are more
difficult to find when they drop to the floor. :-)
> in my mind.
Typically, I scale the figures to the environment they are to live in. :-)
Ah! The Clipka! He seems to have gone on holiday? Shame. He /knows/ he
cannot go without our permission. ;-)
