POV-Ray : Newsgroups : povray.binaries.images : Holes in isosurface Server Time
20 Jun 2025 11:05:10 EDT (-0400)
  Holes in isosurface (Message 1 to 10 of 16)
Subject: Holes in isosurface
Date: 7 Mar 2017 12:21:33
Message: <58beec1d@news.povray.org>
I am trying to render the following isosurface.
isosurface
	function {fFinal(fInpX(x,y,z),fInpY(x,y,z),fInpZ(x,y,z))}
	threshold	0
	accuracy	0.001
	contained_by
		box {0,1}
	max_gradient	50	// was 20000
However, from certain angles there appear gaps or cuts in the surface,
and you can see inside. The gaps disappear when viewed from other angles.
Does anyone have any tips on how to fix this? I already tried scaling by
200 but it does not help.
Mike
Download 'ciexyz_color_solid_cube_isosurface10.png' (56 KB)
Preview of image 'ciexyz_color_solid_cube_isosurface10.png'
Subject: Re: Holes in isosurface
Date: 7 Mar 2017 16:10:00
Message: <web.58bf2172bd2eb8ad9c5d6c810@news.povray.org>
> isosurface
>  threshold 0
>  accuracy 0.001
>  contained_by
>   box {0,1}
The outer box isn't there but I'm guessing your isosurface is part of CSG, so
maybe if you add all_intersections or max_trace 3 (or whatever integer) might
fix it.
Date: 8 Mar 2017 00:30:05
Message: <58bf96dd$1@news.povray.org>
>> isosurface
>>  threshold 0
>>  accuracy 0.001
>>  contained_by
>>   box {0,1}
> fix it.
I tried your suggestion and took the isosurface out of the union it
belonged to:
isosurface
	threshold	0
	accuracy	0.001
	contained_by
		box {0,2}
	all_intersections
	max_trace 3
But it did not solve the problem. I still get the jagged looking artifacts.
Mike
Date: 8 Mar 2017 02:08:38
Message: <58bfadf6$1@news.povray.org>
>>> isosurface
>>>  threshold 0
>>>  accuracy 0.001
>>>  contained_by
>>>   box {0,1}
>>> angles.
>> CSG, so
>> integer) might
>> fix it.
> belonged to:
> isosurface
>     threshold    0
>     accuracy    0.001
>     contained_by
>         box {0,2}
>     all_intersections
>     max_trace 3
> Mike
Here it is again with pigment and scaling:
#declare ScaleAmount = 400;
isosurface
	threshold	0
	accuracy	0.001
	contained_by
		box {0,2}
	all_intersections
	max_trace 3
	pigment {pigmentRGB}
	translate	<-1/2,-1/2,-1/2>
	rotate		y * clock * 360
	scale		ScaleAmount
Mike
Date: 8 Mar 2017 02:52:37
Message: <58bfb845$1@news.povray.org>
>>>> isosurface
>>>>  threshold 0
>>>>  accuracy 0.001
>>>>  contained_by
>>>>   box {0,1}
>>>> angles.
>>>> scaling by
>>> CSG, so
>>> integer) might
>>> fix it.
>> belonged to:
>> isosurface
>>     threshold    0
>>     accuracy    0.001
>>     contained_by
>>         box {0,2}
>>     all_intersections
>>     max_trace 3
>> artifacts.
>> Mike
> isosurface
>     threshold    0
>     accuracy    0.001
>     contained_by
>         box {0,2}
>     all_intersections
>     max_trace 3
>     scale        ScaleAmount
> Mike
To test this I need the fFinal() fInpX() fInpY() fInpZ() functions too.
Date: 8 Mar 2017 03:11:52
Message: <58bfbcc8$1@news.povray.org>
I posted a new thread in p.t.s-f.
Mike
Date: 8 Mar 2017 04:45:01
Message: <web.58bfd1e0bd2eb8ad9c5d6c810@news.povray.org>
Okay, maybe Thomas has figured this out too. I was just trying to think it out
using other functions and got nowhere but I did suspect something I had happen
before:
I ran your files as animation and found nothing wrong...
except after about clock=0.52 and until about clock=0.72
What's going on is simply a case of max_gradient 50 being too low for that
particular segment of frames.
That isosurface requires up to max_gradient 60 from what I found during that
part of the animation.
Try this instead of max_gradient:
evaluate 15,4,0.7
That will give a minimum gradient value with a multiple of 4 (=60) and change
rate.
Better yet, read about that at:
http://wiki.povray.org/content/Reference:Isosurface
Date: 8 Mar 2017 06:52:12
Message: <58bff06c$1@news.povray.org>
> before:
> evaluate 15,4,0.7
> rate.
That seems to work. Thank you!
Mike
Date: 8 Mar 2017 07:12:02
Message: <58bff512$1@news.povray.org>
>> think it out
>> had happen
>> before:
>> that
>> during that
>> evaluate 15,4,0.7
>> change
>> rate.
> Mike
I was not yet that far, but I was thinking in the same direction.
Evaluate is a good tool to use in this context.
Date: 8 Mar 2017 10:05:00
Message: <web.58c01d15bd2eb8adc437ac910@news.povray.org>
I haven't had a chance to look over the isosurface functions, but it looks like
the final shape is a parallelpiped.
If so, couldn't you just make a box and shear it in all 3 directions?
Simpler and lots faster, if that's the case.
I enjoy these color models you work on.
They are very pleasing to my eye.
Keep up the good work!  :)
