POV-Ray : Newsgroups : povray.binaries.images : Re: Regarding the defocus module Server Time
16 Jun 2024 13:43:58 EDT (-0400)
  Re: Regarding the defocus module (Message 11 to 16 of 16)
Subject: Re: Regarding the defocus module
Date: 9 Aug 2016 13:49:28
Message: <57aa17a8$1@news.povray.org>
Am 09.08.2016 um 13:52 schrieb pkrskr:
> I see the semi-transparent ray and that it originates at the center of the
> virtual aperture. This precisely clarifies the method you detailed in elaborate
> steps earlier.
> Can you elaborate on how the nominal pinhole camera location is computed as
> mentioned in step 2?
>> (2) From the camera settings, POV-Ray computes the parameters for a
>> simple pinhole camera equivalent, with the pinhole at the nominal camera
>> location.
I'll re-iterate:
"As a matter of fact, POV-Ray /never/ actually "thinks" of the real
camera geometry in the first place, since the geometry is only specified
indirectly. [...]"
Both the virtual aperture center and the pinhole are placed at the
nominal camera location, as per the camera block.
Date: 13 Sep 2016 09:00:02
Message: <web.57d7f7f829233825f2ed086a0@news.povray.org>
Hey!
@clipka: Thanks for your earlier clarifications. They really helped!
I need a little more help. I am trying out a sample scene with 3 horizontal bars
in the front and 3 vertical ones at the back. I have an image of this scene I
want to compare POVRay's result to, but I'm having problems setting up a few
parameters.
- First of all, in the picture you attached before (aperture.png) with the
standard lens diagram, We had an image plane along with the lens an object. My
understanding was that the camera parameters in POVRay are for the 'lens' part.
I set the focal length using the 'direction' variable (I hope that's correct).
So how do I specify where the image plane is to be?
- Also regarding the aperture, the official doc says "while this behaves as a
real camera does, the values for aperture are purely arbitrary and are not
related to f-stops." If I want to specify the aperture value as 'f/X' as in a
camera (ie. with respect to focal length), how can I specify that?
- Regarding the confidence value: the doc says "The confidence value is used to
determine when the samples seem to be close enough to the correct color." How
does POVRay 'know' the correct color? Suppose I have a point (like P in the
image) I'm shooting a number of rays from, which are slightly deviated from each
other going to the lens, and converging at 1 pt P' on the other side. Suppose
some hit an object before P' and some hit it after, but hit different objects.
So how do you know the correct color in such a case, and subsequently, when to
stop tracing more samples as the color is 'close enough'?
- Finally, I have a different setup where I've configured my rays to just pick
up the color value of the object the ray hits and add it up on the target pixel
the ray comes from. Is there a way to bypass the color calculations (the
diffuse/ambient/specular etc. values) and just make POVRay add up the color
value to the pixel where it's color is to be added?
I'm attaching the files I'm using in the setup, along with the 'aperture.png'
used for reference. The testing1.png is when i'm using the 'focal_point'
parameter, and testing2.png is when that is removed. Why is such an effect
happening? Because from my understanding, f-value=1 unit (As set by
'direction').
Thanks in advance!
Download 'files.zip' (940 KB)
Date: 13 Sep 2016 12:41:42
Message: <57d82c46$1@news.povray.org>
> Hey!
> parameters.
The direction vector set the reference plane of the image. Objects in
front of that point appear larger and those beyond appear smaller. Along
with the up and right vectors, it determine the field of view, not a
focal length.
The image plane is where the point computer by adding the camera's
location and the direction vector, and is perpendicular to the direction
vector. It's further modified if you use look_at or any transformation
on the camera.
The f/x is a ratio. Say the focal_point is 100 unit in front of the
camera and you want an f/x of f100, you divide the distance between the
camera and focal_point by your f/x, in this case, it gives an aperture of 1.
Formula:
vlength(Camera_Location - focal_point)/ (f/x)
confidence is the probability that the resulting colour is correct.
It's a statistical thing. It's recommended to always use a value smaller
than 1.
variance is how much you are willing to deviate from the exact colour.
Using a value of zero is not recommended. Instead, use a very small
value like 1e-6 or smaller.
After each samples are taken, they are averaged and compared with the
average of the previous samples. If the change after adding a new sample
is small enough, you can say that you are close enough. That evaluation
also depends on variance and adc_bailout from the global_settings.
Remove all light.
Set all finish as :
finish{ambient 1 diffuse 0 reflection 0 specular 0 phong 0}
Alternatively, but without focal blur, use +q0 on the command line.
> 'direction').
> Thanks in advance!
You need to set focal_point.
If left undefined, it may get located at the same place as the camera,
or extremely far away.
A warning: You must use look_at AFTER you set the direction vector.
Normally, it's the last item when using a standard camera, and you only
set the focal blur parameters after it.
Good : direction <0,0,0>  look_at   <0.0, 1.0,  0.0>
Bad :  look_at  <0.0, 1.0,  0.0>   direction <0,0,0>
Date: 13 Sep 2016 13:30:01
Message: <web.57d836ac29233825f2ed086a0@news.povray.org>
> focal length.
> on the camera.
So if the direction vector is used to determine the field of view, how do I set
the 'f' value exactly? Suppose I've made a scene where I assume focal length=2
'units' and all objects, lens and image plane are set according to that.
How/Where do I set that in POVRay? As you must have seen in the .pov file, I say
"X units" from the camera. What I really want is that distance to be as "Y*f",
as in a multiplier of the f-value. How can I do that?
> Formula:
Here the f/X I meant was like the f/1.4 or f/1.7 in real cameras. Supposing the
focal_point is X*f from the camera, and I want an aperture of f/2.0, what should
I set the 'aperture' parameter as? [Given that I know how to set 'f' value
first?]
> than 1.
I still didn't get how you say you know the 'correct' color. For computing
probabilities, that knowledge
is reqd. Is it approximated such that you keep adding the colors to the target
pixel, and when that pixel's
color stops changing much, you say you don't need more rays?
But what does focal_point really do in the context of the tracing done?
Date: 14 Sep 2016 14:47:40
Message: <57d99b4c$1@news.povray.org>
>> focal length.
>> on the camera.
>> Formula:
> first?]
f/2 mean that the aperture is exactly half the distance between the
optical center of the lens and the film/detector.
In POV-Ray terms, that should be about half the direction vector length.
Do some testing using a fraction of the direction vector and the
distance between the camera and focal_point.
>> than 1.
Yes. When the change from a new sample get less that a threshold value,
you say, this is close enough and I don't need to get any new sample.
It define the plane of sharpness, every ray shot toward any given point
on that plane will represent exactly the same pixel in the final image.
Date: 15 Sep 2016 03:40:00
Message: <web.57da4f2b29233825f2ed086a0@news.povray.org>
It seems like from what you are saying is that the distance between the camera
location
set by the 'location' parameter and the 'focal_point' = focal length of lens.
But wouldn't that mean that all rays always come from infinity? Because if my
'plane of sharpness' is always around the focal plane of the lens, that means
rays always
come from infinity, which would mean I cannot test any other in-focus pair. For
example,
by the simple thin lens formula, if v=1.1f, then u=11f. Which means for an
object placed
11f on one side of the lens, I should be able to place a film 1.1f on the other
side and
be able to see at least the object at 11f in focus and other objects blurred
with respect
to their distance from the 'plane of sharpness' (which would now be around 11f).
How can I see such an effect in POVRay?
Understood!
1 more request: Will it be possible to have a chat with you somehow? I would
like to have
a bit more back-and-forth on this, if that's okay with you. Should I mail you,
or is any
other platform more suitable?
Thanks for all your clarifications regarding this!
