![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That, sir, is wicked cool and very useful and convenient.
An excellent job! :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 06/07/2016 22:42, dick balaska a écrit :
> Am 2016-07-06 12:58, also sprach Le_Forgeron:
>> wasting some round tuits,
> Wow. Pretty slick.
> Didn't warp have something similar years ago? I recall an anim of spaceship on a
spline from 4 angles at once.
Any link ?
> And because I'm a dork, I'll add
> "yeah, but you should support video wipe" (position the dividers between cameras).
Give a man a fish, and he will ask for a comfortable table and seat, with a fresh
bottle of white wine and a dedicated team of waitresses, free of charge.
"You can position the dividers anywhere, as long as it's 1/n and you have n*n
cameras".
(in the mood of Ford :"you can have the car in any colour you want, as long as it is
black.")
More seriously, if you can come up with a simple and clear syntax to describes a
layout of rectangles that have the same ratio than the final picture, I might consider
another extension.
But beware, HTML tried that with table, and that turns in a nightmare and ambiguous
descriptions (some engines render differently some complex tables).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> >Wow. Pretty slick.
> Any link ?
IIRC It was using megapov and quite a while ago.
I cannot find a link.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 06.07.2016 um 18:58 schrieb Le_Forgeron:
> camera{ grid 2 Camera_2 Camera_0 Camera_1 Camera_3}
> Followed by the number of camera per side, and then that squared number of camera
identifiers, to make a grid
> of the various view directly for the rendered image.
Why not provide two parameters, so that we can have arbitrary arrays of
NxM cameras?
That, btw, would obviously provide a reasonably simple way to generate
side-by-side stereographic images.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> NxM cameras?
Because I did not mess with image_height & image_width, which could be used in
(sub)camera computation.
And I already have side-by-side stereographic camera
http://wiki.povray.org/content/User:Le_Forgeron#Stereoscopic_camera
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 07.07.2016 um 16:05 schrieb Le_Forgeron:
>> NxM cameras?
They could be used to compute the aspect ratio, but they also could be
used to compute other stuff, so they're "broken" anyway if interpreted
as a per-camera value.
Also, if you develop a scene using a grid camera, you presumably know
what grid size you're using, so you can apply correction factors to
account for the mismatch between camera aspect ratio and image aspect ratio.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> NxM cameras?
ok... Granted evolution. Just do not blame me when the aspect ratio are not correct.
Instead of 2 paramaters, the parameter is now a vector, interpreted as 2D-vector.
#declare Camera_0 = camera { /*ultra_wide_angle*/ angle 10 // front view
location <0.0 , 2.0 ,-40.0>
right x*image_width/image_height*2/3
look_at <0.0 , 2.0 , 0.0>}
#declare Camera_1 = camera {/*ultra_wide_angle*/ angle 20 // diagonal view
location <20.0 , 20.0 ,-20.0>
right 2*x*image_width/image_height
look_at <1.0 , 2.0 , 0.0>}
#declare Camera_2 = camera { /*ultra_wide_angle*/ angle 10 //right side view
location <40.0 , 2.0 , 0.0>
#declare Camera_3 = camera { /*ultra_wide_angle*/ angle 10 // top view
location <0.0 , 40.0 ,0.0>
sky +z
direction -y
up +z
look_at <0.0 , 1.0 , 0.0>}
#declare GridT = camera { grid 1 Camera_1 }
#declare GridB = camera { grid <3,1> Camera_2 Camera_3 Camera_0 }
camera{ grid <1,2> GridT GridB }
Download 'grid.png' (172 KB)
Preview of image 'grid.png'
![grid.png](/povray.binaries.images/attachment/%3C5780c2a5%40news.povray.org%3E/grid.png?ttop=415949&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
MegaPOV actually had a camera_view pigment.
So you could use one rendered view and use it to texture e.g.
a picture frame. Or of course apply it to 2 x 2 boxes for a grid.
http://megapov.inetart.net/features.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Direct link:
http://megapov.inetart.net/manual-1.2.1/megapov0121.html#camera_view
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Direct link:
Thanks.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
