![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 05/08/2016 03:33 PM, Le_Forgeron wrote:
> For the time being, only available in hgpovray.
> lemon { P1, R1, P2, R2, R3 ... }
> similar to cone { P1, R1, P2, R2 ...} but connected with a lemon (inner circle of a
torus) of radius R3.
> Options includes : uv_mapping, open and sturm.
> All Rx must be positive or null, and there is a complain with error when R3 is too
small.
> The complain gives the minimal value that can be used.
> And now that I can sleep a bit, I'm returning to the extension of the ovus.
In working with this new object I came across this case:
// P1, R1, P2, R2, R3
#declare LemonLeft = lemon {
<-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999
#declare LemonCenter = lemon {
<0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50
#declare LemonRight = lemon {
<1.2,-0.5,0>, 0.0, <1.2,0.5,0>, 0.0, 0.500001
Where the LemonLeft generates this warning message:
File 'lemon.pov' line 176: Possible Parse Error: Inner (last) radius of
lemon is too small. Minimal would be 0.5. Subtituing a sphere to lemon
recommending the code used in LemonCenter. However the result for
LemonCenter is quite noisy. An 'epsilon' above is OK.
See attached image.
Bill P.
Download 'lemonissue.jpg' (75 KB)
Preview of image 'lemonissue.jpg'
![lemonissue.jpg](/povray.binaries.images/attachment/%3C5746de84%241%40news.povray.org%3E/lemonissue.jpg?ttop=415949&toff=150&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> See attached image.
> Bill P.
can you try to add "sturm" to LemonCenter ? (I'm away from my hgpovray)
<0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50 sturm
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Using sturm as follows is less noisy, but still noisy :
<1.2,-0.5,0>, 0.0, <1.2,0.5,0>, 0.0, 0.500001 sturm
On my first attempt I did the following:
<-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999 sturm
which gave me this parse error :
File 'lemon.pov' line 175: Parse Error: Keyword 'sturm' cannot be used
with this object.
So, I assumed you'd not yet set sturm up for the lemon! Wondering now if
the code creating the inner radius warning for LemonLeft is itself
creating the error for sturm use in that case?
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> with this object.
> Bill P.
On LemonLeft, parsing occurs up to the inner radius, then the message is
written and the object so far get replaced with a sphere.
Then parsing continue and find sturm, which is not supported by a sphere.
Notice that the same issue would occurs with current ovus (when the top
radius is more than twice the bottom radius).
For lemon, I could replace with another object which would support
sturm, but is it really needed ? or even wanted ?
(My first approach was to stop with an error instead of a warning, was
it better ?)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> it better ?)
Suppose if someone is doing an animation or sequence of images, it might
be convenient to transition into a sphere then continue to shrink that
sphere.
If so, we are not really doing that today as we seem to be at a 0.5
radius and then jump to a radius of 0.499999/2 where we'd need to not
have a discontinuity in result for inner radius moving from 0.5 to
0.499999.
Changing from the current discontinuous behavior and moving to say a
polynomial (See attached image) :
// #declare LemonLeft = lemon {
// <-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999
#declare LemonLeft = polynomial { 2,
xyz(2,0,0):1,
xyz(0,2,0):1,
xyz(0,0,2):1,
xyz(1,0,0):-2*-1.2,
xyz(0,0,0):pow(-1.2,2)-pow(0.49999,2)
sturm
allows sturm - but then not open... I suspect if we want this smooth
transition into a sphere we might be stuck filtering whatever keywords
the lemon supports but our substitute object does not.
If we are going to jump to the 0.499999/2 radius on substitution as we
do today, I vote we go back to an error message.
Bill P.
Download 'lemonissue2.jpg' (103 KB)
Preview of image 'lemonissue2.jpg'
![lemonissue2.jpg](/povray.binaries.images/attachment/%3C57472077%40news.povray.org%3E/lemonissue2.jpg?ttop=415949&toff=150&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> it better ?)
> Suppose if someone is doing an animation or sequence of images, it might be
convenient to transition into a sphere then continue to shrink that sphere.
> If so, we are not really doing that today as we seem to be at a 0.5 radius and then
jump to a radius of 0.499999/2 where we'd need to not have a discontinuity in result
for inner radius moving from 0.5 to 0.499999.
Thanks you for your input, on that point as well as the noisy surface when radius is
exactly the minimal one.
It should be corrected with the new (and hopefully last) change on the lemon.
> If we are going to jump to the 0.499999/2 radius on substitution as we do today, I
If the vertices are identical, an error message is issued (same as for cylinder/cone)
If the third radius is too small, it is adjusted to the smallest value and a warning
is written, thus allowing sturm and open without problem. So, no more discontinuity,
but no shrinking either.
and for extra benefit, when the third radius is the minimal one, a sphere is used
instead of the torus part, removing the problem of noise on the surface due to
coincident surface.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
cylinder/cone)
coincident surface.
Unfortunately, I am still seeing noise at the 0.5 radius with the
following code giving us the three rows in the attached image.
//----- Top set
// #declare LemonLeft = polynomial { 2,
// xyz(2,0,0):1,
// xyz(0,2,0):1,
// xyz(0,0,2):1,
// xyz(1,0,0):-2*-1.2,
// xyz(0,0,0):pow(-1.2,2)-pow(0.50000,2)
// sturm
// #declare LemonCenter = polynomial { 2,
// xyz(2,0,0):1,
// xyz(0,2,0):1,
// xyz(0,0,2):1,
// xyz(0,0,0):-pow(0.50000,2)
// sturm
//----- Middle set
// #declare LemonCenter = lemon {
// <0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50
//----- Bottom set
//----- All sets
Bill P.
Download 'hg_495:52beb76993f0.jpg' (208 KB)
Preview of image 'hg_495:52beb76993f0.jpg'
![hg_495:52beb76993f0.jpg](/povray.binaries.images/attachment/%3C574c5153%241%40news.povray.org%3E/hg_495%3A52beb76993f0.jpg?ttop=415949&toff=150&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
is exactly the minimal one.
cylinder/cone)
warning is written, thus allowing sturm and open without problem. So, no more
discontinuity, but no shrinking either.
coincident surface.
> Unfortunately, I am still seeing noise at the 0.5 radius with the following code
I agree there is still something on the surface, when used with a metallic reflection.
But the coincidence surface seems to not be the cause.
If anyone has a clue, feel welcome to share.
Download 'lo.png' (191 KB)
Download 'lo.pov.txt' (2 KB)
Preview of image 'lo.png'
![lo.png](/povray.binaries.images/attachment/%3C574c62eb%40news.povray.org%3E/lo.png?ttop=415949&toff=150&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
reflection.
seems it is tied to the computation when the sphere is used... Puzzling.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
reflection.
Interesting. Do you think it might be worth porting the lemon into the
current gitgub master branch for a test?
I'm not completely up on the differences compared to the Hg-povray
branch...
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
