POV-Ray : Newsgroups : povray.binaries.images : The lemon is ready Server Time
27 May 2026 11:21:57 EDT (-0400)
  The lemon is ready (Message 15 to 24 of 34)
Subject: Re: The lemon is ready
Date: 18 May 2016 19:45:47
Message: <573cfeab$1@news.povray.org>
Am 18.05.2016 um 20:25 schrieb LanuHum:
> clipka <ano### [at] anonymousorg> wrote:
>> Am 12.05.2016 um 20:06 schrieb LanuHum:
>>> But, in the Blender the lemon is unprofitable to be used.
>>> Any this form is created by lathe.
>> You can't create this exact shape with lathe.
> I won't argue. Accuracy of computation of Bezier curves has enough for creation
> of a body of the car.
I doubt the designers of car bodies use Bezier splines -- their weapon
of choice are NURBS (non-uniform rational B-splines); AFAIK those do
have the capacity to precisely represent circular arcs.
Date: 19 May 2016 10:15:00
Message: <web.573dc93c370a969c7a3e03fe0@news.povray.org>
https://en.wikipedia.org/wiki/B%C3%A9zier_curve
ity to graphics was not realized for
> Renault. The study of these curves was however first developed in 1959 by
> mathematician Paul de Casteljau using de Casteljau's algorithm, a numerically
Date: 19 May 2016 11:04:06
Message: <573dd5e6$1@news.povray.org>
Am 19.05.2016 um 16:10 schrieb LanuHum:
[quote from Wikipedia, not clipka]
>> known since 1912, but its applicability to graphics was not realized for
Yes, the /invention/ of Bezier curves was driven by the French
automotive industry.
But as the article also notes, that was around _1960_.
Car body quality requirements have increased quite a lot since then.
Note how the "Applications" section in that article lists computer
graphics, animation and fonts, but /not/ [contemporary] automotive design.
Date: 19 May 2016 11:50:00
Message: <web.573ddf71370a969c7a3e03fe0@news.povray.org>
We distracted, but the task remained unresolved.
Task:
To place five spheres so that centers of spheres lay on a lemon surface.
difference{
lemon{}
sphere{??}
sphere{??}
sphere{??}
sphere{??}
sphere{??}
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.573cb381370a969c7a3e03fe0%40news.povray.org%3E/lemon.jp
g
WRITTEN_FOR="LANUHUM"
use_bezier_lathe = False
use_lemon = True
#macro Calculate_points_coords_lemon_surface(number_x,number_y,number_z)
//bla-bla-bla...
replace, please, //bla-bla-bla... with the working source code
If it isn't in documentation, then I don't know how to the rocket to attach
wings
Date: 19 May 2016 12:31:40
Message: <573dea6c$1@news.povray.org>
> Task:
> difference{
> lemon{}
> sphere{??}
> sphere{??}
> sphere{??}
> sphere{??}
> sphere{??}
> g
> use_lemon = True
> //bla-bla-bla...
> wings
The code below uses the new spindle torus & not the lemon, but is
something like this what you are after?
#declare Torus00=torus { 0.25, 0.5 intersection scale <1,2,1> }
#declare Norm=<0,0,0>;
difference {
     object { Torus00 }
     sphere { trace(Torus00, <1,0,0>,    <-1,0,0>, Norm) , 0.15 }
     sphere { trace(Torus00, <1,0.5,0>,  <-1,0,0>, Norm) , 0.15 }
     sphere { trace(Torus00, <1,-0.5,0>, <-1,0,0>, Norm) , 0.15 }
     pigment { color Niagara }
Bill P.
Date: 19 May 2016 12:33:26
Message: <573dead6$1@news.povray.org>
> Task:
> difference{
> lemon{}
> sphere{??}
> sphere{??}
> sphere{??}
> sphere{??}
> sphere{??}
For lemon { 0, 0, H*y, 0, R }
The 2D circle (of radius R) of the lemon is centred at <-V, H/2>, with
V^2 = R^2 - ((H^2)/4)
easily solved as V = sqrt( R^2 - ((H^2)/4) ).
Assuming you want the spheres in the z=0,x+ demi plane, you just have to satisfy for
< A, B, C> as the centre:
C = 0
R^2 = (B-(H/2))^2 + (A+V)^2
0 <= B <= H
As I'm tired of equations solving, I let it to wolframalpha solver :
A is sqrt(-2 B^2+2 B H-H^2+4 R^2+sqrt(H^2-4 R^2) sqrt(4 B^2-4 B H+H^2-4 R^2))/sqrt(2)
Have a nice sleep.
Date: 26 May 2016 07:31:16
Message: <5746de84$1@news.povray.org>
On 05/08/2016 03:33 PM, Le_Forgeron wrote:
> For the time being, only available in hgpovray.
> lemon { P1, R1, P2, R2, R3 ... }
> similar to cone { P1, R1, P2, R2 ...} but connected with a lemon (inner circle of a
torus) of radius R3.
> Options includes : uv_mapping, open and sturm.
> All Rx must be positive or null, and there is a complain with error when R3 is too
small.
> The complain gives the minimal value that can be used.
> And now that I can sleep a bit, I'm returning to the extension of the ovus.
In working with this new object I came across this case:
// P1, R1, P2, R2, R3
#declare LemonLeft  = lemon {
    <-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999
#declare LemonCenter = lemon {
    <0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50
#declare LemonRight  = lemon {
    <1.2,-0.5,0>, 0.0, <1.2,0.5,0>, 0.0, 0.500001
Where the LemonLeft generates this warning message:
File 'lemon.pov' line 176: Possible Parse Error: Inner (last) radius of
lemon is too small. Minimal would be 0.5. Subtituing a sphere to lemon
recommending the code used in LemonCenter. However the result for
LemonCenter is quite noisy. An 'epsilon' above is OK.
See attached image.
Bill P.
Download 'lemonissue.jpg' (75 KB)
Preview of image 'lemonissue.jpg'
Date: 26 May 2016 07:50:44
Message: <5746e314$1@news.povray.org>
> See attached image.
> Bill P.
can you try to add "sturm" to LemonCenter ? (I'm away from my hgpovray)
     <0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50 sturm
Date: 26 May 2016 09:24:35
Message: <5746f913@news.povray.org>
Using sturm as follows is less noisy, but still noisy :
    <1.2,-0.5,0>, 0.0, <1.2,0.5,0>, 0.0, 0.500001 sturm
On my first attempt I did the following:
    <-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999 sturm
which gave me this parse error :
File 'lemon.pov' line 175: Parse Error: Keyword 'sturm' cannot be used
with this object.
So, I assumed you'd not yet set sturm up for the lemon! Wondering now if
the code creating the inner radius warning for LemonLeft is itself
creating the error for sturm use in that case?
Bill P.
Date: 26 May 2016 10:15:18
Message: <574704f6$1@news.povray.org>
> with this object.
> Bill P.
On LemonLeft, parsing occurs up to the inner radius, then the message is
written and the object so far get replaced with a sphere.
Then parsing continue and find sturm, which is not supported by a sphere.
Notice that the same issue would occurs with current ovus (when the top
radius is more than twice the bottom radius).
For lemon, I could replace with another object which would support
sturm, but is it really needed ? or even wanted ?
(My first approach was to stop with an error instead of a warning, was
it better ?)
