POV-Ray : Newsgroups : povray.binaries.images : Just dawdling Server Time
17 May 2024 20:18:21 EDT (-0400)
  Just dawdling (Message 11 to 20 of 70)
Subject: Re: Just dawdling
Date: 9 May 2016 19:25:01
Message: <web.57311b2e4e13f48533c457550@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> The strands utility definitely looks interesting.
Oops, I found it in the newsgroups, in binaries.utilities (September 2010)
Date: 10 May 2016 02:54:23
Message: <5731859f$1@news.povray.org>
I could not have been more precise. I picked them up at the moment when
Sam made them available and did not really note down a location, except
for the date.
According to my info, rockhead1.pov dates back to 2007. I think there
was an image, so p.b.i. should be a first guess.
There are still a lot of utilities from Sam that I have not really tried
out. I pick things up when they come by and then put them on the shelf.
Date: 10 May 2016 07:37:30
Message: <5731c7fa$1@news.povray.org>
>> 2010)
> for the date.
If anyone - Sam? - has a pointer to the original theory or perhaps
source code for the strands technique I would appreciate it. I've done
some searches with the word strands, but come up empty and I don't quite
see what is being done.
I picked up the exe too, but it would not run under wine for me & it is
an effect I would like to try.
On the image, Thomas, are the floating shapes at the edges from an
underlying isosurface then? The general look I like.
Bill P.
Date: 10 May 2016 07:55:26
Message: <5731cc2e$1@news.povray.org>
>>> 2010)
>> for the date.
> Bill P.
Yes the general shapes are isosurfaces. This is the (Sam-based) code for
the head:
#declare rock=
function{
     //spherical //or:
     boxed
     pigment_map {
       [0.0 rgb 0]
       [0.5 pigment_pattern {
              image_map {
                //png"rockman.png" gamma 1.0 interpolate 2
                //png"TdG_rock_01.png" gamma 1.0 interpolate 2
                png"t_degroot01.png" gamma 1.0 interpolate 2
                //png"Sam Benge Strands/strands_003.png" gamma 1.0
interpolate 2
              translate-(x+y)/2
              scale 2
            pigment_map {
              [0.0 rgb 0]
              [0.5 granite
                   scale <5, 0.5, 5>
                   poly_wave 0.5
                   rotate z*12
                   color_map {
                     [0 rgb 0.25]
                     [1 rgb 0.75]
              [1.0 rgb 1]
       [1.0 rgb 1]
and the isosurface used:
isosurface {
   function {
     0-rock(x,y,z).grey+0.05
   accuracy 0.001
   max_gradient 2
   all_intersections
   contained_by {box {<-1,-1,-1>,<1,1,1>}}
   texture {granite_rock}
The strands output image is used in Gimp in combination with the
portrait and additional layers, to get a final image.
Date: 13 May 2016 05:45:00
Message: <web.5735a1b94e13f485dcc92c470@news.povray.org>
> >>> 2010)
> >> for the date.
> > Bill P.
> the head:
> #declare rock=
> function{
>    pigment {
>      //spherical //or:
>      boxed
>      pigment_map {
>        [0.0 rgb 0]
>               image_map {
> interpolate 2
>               translate-(x+y)/2
>               scale 2
>             pigment_map {
>               [0.0 rgb 0]
>               [0.5 granite
>                    scale <5, 0.5, 5>
>                    poly_wave 0.5
>                    rotate z*12
>                    color_map {
>                      [0 rgb 0.25]
>                      [1 rgb 0.75]
>               [1.0 rgb 1]
>        [1.0 rgb 1]
> isosurface {
>    function {
>    accuracy 0.001
>    max_gradient 2
>    all_intersections
> Thomas
Thank you Thomas! More lovely toys to play with. And I love the images. Lots of
food for thought.
I really must dive through the binaries. Clearly there is a lot I have missed.
Date: 13 May 2016 08:03:45
Message: <5735c2a1@news.povray.org>
>>>>> 2010)
>>>> for the date.
>>> Bill P.
>> the head:
>> #declare rock=
>> function{
>>     pigment {
>>       //spherical //or:
>>       boxed
>>       pigment_map {
>>         [0.0 rgb 0]
>>                image_map {
>> interpolate 2
>>                translate-(x+y)/2
>>                scale 2
>>              pigment_map {
>>                [0.0 rgb 0]
>>                [0.5 granite
>>                     scale <5, 0.5, 5>
>>                     poly_wave 0.5
>>                     rotate z*12
>>                     color_map {
>>                       [0 rgb 0.25]
>>                       [1 rgb 0.75]
>>                [1.0 rgb 1]
>>         [1.0 rgb 1]
>> isosurface {
>>     function {
>>     accuracy 0.001
>>     max_gradient 2
>>     all_intersections
>> Thomas
> food for thought.
No thanks. All praise goes to Sam Benge for these tools. And yes, like
we all, there is a lot we miss one way or another.
Date: 13 May 2016 12:40:00
Message: <web.5736024e4e13f48591327a850@news.povray.org>
> ...which brings me to A Portrait of the Artist as an Eroded Gentleman.
> Thomas
you look rock solid :)
Date: 14 May 2016 02:50:19
Message: <5736caab@news.povray.org>
>> Thomas
Don't let appearances mislead you ;-)
Date: 16 May 2016 03:32:42
Message: <5739779a@news.povray.org>
I need a bit of help. I made a depth_map of a Poser head (see attached)
and thought that using it in the Rockhead code would be straightforward.
It is, except that the face remains flat with hardly a hint of features.
I believe there is nothing wrong with the depth_map itself, so how can I
improve on this? Here is the basic code used:
//==start code==============================
#declare granite_rock=
texture{
  pigment{
   pigment_pattern{
    bumps scale .15
   pigment_map{
    [-.2 rgb 1]
    [.5
     crackle solid scale .0125/4
     color_map{
      [0 rgb 1]
      [.5 rgb <1,.875,.75>-.5]
      [1 rgb 0]
  normal{crackle 1 solid  scale .0125/4}
  finish{brilliance .5 diffuse .785}
#declare rock=
function{
     spherical //or:
     //boxed
     pigment_map {
       [0.0 rgb 0]
              image_map {
                png"Mapping_test.png" gamma 1.0 interpolate 2
              translate-(x+y)/2
              scale 2
            pigment_map {
              [0.0 rgb 0]
              [0.5 granite
                   scale <5, 0.5, 5>
                   poly_wave 0.5
                   rotate z*12
                   color_map {
                     [0 rgb 0.25]
                     [1 rgb 0.75]
              [1.0 rgb 1]
       [1.0 rgb 1]
isosurface {
   function {
   accuracy 0.001
   max_gradient 2
   all_intersections
//==end code================================
Thanks!
Download 'mapping_test.png' (48 KB)
Preview of image 'mapping_test.png'
Date: 16 May 2016 04:16:34
Message: <573981e2@news.povray.org>
Le 16/05/2016 09:32, Thomas de Groot a écrit :
> I need a bit of help. I made a depth_map of a Poser head (see attached) and thought
that using it in the Rockhead code would be straightforward. It is, except that the
face remains flat with hardly a hint of features. I believe there is nothing wrong
with the depth_map
> itself, so how can I improve on this? Here is the basic code used:
> Thanks!
If it can help... look at attached scene
then compare with your scene. (and please next time, give me camera & light sources
too)
Download 'dep.png' (273 KB) Download 'dep.pov.txt' (2 KB)
Preview of image 'dep.png'
