![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Kenneth" <kdw### [at] gmail com> wrote:
> The strands utility definitely looks interesting.
Oops, I found it in the newsgroups, in binaries.utilities (September 2010)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I could not have been more precise. I picked them up at the moment when
Sam made them available and did not really note down a location, except
for the date.
According to my info, rockhead1.pov dates back to 2007. I think there
was an image, so p.b.i. should be a first guess.
There are still a lot of utilities from Sam that I have not really tried
out. I pick things up when they come by and then put them on the shelf.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> 2010)
> for the date.
If anyone - Sam? - has a pointer to the original theory or perhaps
source code for the strands technique I would appreciate it. I've done
some searches with the word strands, but come up empty and I don't quite
see what is being done.
I picked up the exe too, but it would not run under wine for me & it is
an effect I would like to try.
On the image, Thomas, are the floating shapes at the edges from an
underlying isosurface then? The general look I like.
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> 2010)
>> for the date.
> Bill P.
Yes the general shapes are isosurfaces. This is the (Sam-based) code for
the head:
#declare rock=
function{
//spherical //or:
boxed
pigment_map {
[0.0 rgb 0]
[0.5 pigment_pattern {
image_map {
//png"rockman.png" gamma 1.0 interpolate 2
//png"TdG_rock_01.png" gamma 1.0 interpolate 2
png"t_degroot01.png" gamma 1.0 interpolate 2
//png"Sam Benge Strands/strands_003.png" gamma 1.0
interpolate 2
translate-(x+y)/2
scale 2
pigment_map {
[0.0 rgb 0]
[0.5 granite
scale <5, 0.5, 5>
poly_wave 0.5
rotate z*12
color_map {
[0 rgb 0.25]
[1 rgb 0.75]
[1.0 rgb 1]
[1.0 rgb 1]
and the isosurface used:
isosurface {
function {
0-rock(x,y,z).grey+0.05
accuracy 0.001
max_gradient 2
all_intersections
contained_by {box {<-1,-1,-1>,<1,1,1>}}
texture {granite_rock}
The strands output image is used in Gimp in combination with the
portrait and additional layers, to get a final image.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >>> 2010)
> >> for the date.
> > Bill P.
> the head:
> #declare rock=
> function{
> pigment {
> //spherical //or:
> boxed
> pigment_map {
> [0.0 rgb 0]
> image_map {
> interpolate 2
> translate-(x+y)/2
> scale 2
> pigment_map {
> [0.0 rgb 0]
> [0.5 granite
> scale <5, 0.5, 5>
> poly_wave 0.5
> rotate z*12
> color_map {
> [0 rgb 0.25]
> [1 rgb 0.75]
> [1.0 rgb 1]
> [1.0 rgb 1]
> isosurface {
> function {
> accuracy 0.001
> max_gradient 2
> all_intersections
> Thomas
Thank you Thomas! More lovely toys to play with. And I love the images. Lots of
food for thought.
I really must dive through the binaries. Clearly there is a lot I have missed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>>> 2010)
>>>> for the date.
>>> Bill P.
>> the head:
>> #declare rock=
>> function{
>> pigment {
>> //spherical //or:
>> boxed
>> pigment_map {
>> [0.0 rgb 0]
>> image_map {
>> interpolate 2
>> translate-(x+y)/2
>> scale 2
>> pigment_map {
>> [0.0 rgb 0]
>> [0.5 granite
>> scale <5, 0.5, 5>
>> poly_wave 0.5
>> rotate z*12
>> color_map {
>> [0 rgb 0.25]
>> [1 rgb 0.75]
>> [1.0 rgb 1]
>> [1.0 rgb 1]
>> isosurface {
>> function {
>> accuracy 0.001
>> max_gradient 2
>> all_intersections
>> Thomas
> food for thought.
No thanks. All praise goes to Sam Benge for these tools. And yes, like
we all, there is a lot we miss one way or another.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> ...which brings me to A Portrait of the Artist as an Eroded Gentleman.
> Thomas
you look rock solid :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Thomas
Don't let appearances mislead you ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I need a bit of help. I made a depth_map of a Poser head (see attached)
and thought that using it in the Rockhead code would be straightforward.
It is, except that the face remains flat with hardly a hint of features.
I believe there is nothing wrong with the depth_map itself, so how can I
improve on this? Here is the basic code used:
//==start code==============================
#declare granite_rock=
texture{
pigment{
pigment_pattern{
bumps scale .15
pigment_map{
[-.2 rgb 1]
[.5
crackle solid scale .0125/4
color_map{
[0 rgb 1]
[.5 rgb <1,.875,.75>-.5]
[1 rgb 0]
normal{crackle 1 solid scale .0125/4}
finish{brilliance .5 diffuse .785}
#declare rock=
function{
spherical //or:
//boxed
pigment_map {
[0.0 rgb 0]
image_map {
png"Mapping_test.png" gamma 1.0 interpolate 2
translate-(x+y)/2
scale 2
pigment_map {
[0.0 rgb 0]
[0.5 granite
scale <5, 0.5, 5>
poly_wave 0.5
rotate z*12
color_map {
[0 rgb 0.25]
[1 rgb 0.75]
[1.0 rgb 1]
[1.0 rgb 1]
isosurface {
function {
accuracy 0.001
max_gradient 2
all_intersections
//==end code================================
Thanks!
Download 'mapping_test.png' (48 KB)
Preview of image 'mapping_test.png'
![mapping_test.png](/povray.binaries.images/attachment/%3C5739779a%40news.povray.org%3E/mapping_test.png?ttop=415949&toff=150&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 16/05/2016 09:32, Thomas de Groot a écrit :
> I need a bit of help. I made a depth_map of a Poser head (see attached) and thought
that using it in the Rockhead code would be straightforward. It is, except that the
face remains flat with hardly a hint of features. I believe there is nothing wrong
with the depth_map
> itself, so how can I improve on this? Here is the basic code used:
> Thanks!
If it can help... look at attached scene
then compare with your scene. (and please next time, give me camera & light sources
too)
Download 'dep.png' (273 KB)
Download 'dep.pov.txt' (2 KB)
Preview of image 'dep.png'
![dep.png](/povray.binaries.images/attachment/%3C573981e2%40news.povray.org%3E/dep.png?ttop=415949&toff=150&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
