POV-Ray : Newsgroups : povray.binaries.images : concentric blobs clouds Server Time
30 Oct 2026 12:20:35 EDT (-0400)
  concentric blobs clouds (Message 37 to 66 of 66)
<<< Previous 36 Messages Goto Initial 50 Messages
Subject: Re: concentric blobs clouds
Date: 28 Apr 2016 10:55:01
Message: <web.572223a55193772e63ecef950@news.povray.org>
> El 28/04/16 a las 13:13, Simon J. Cambridge escribió:
> > I ended up using a single containing object (box or plane) and then filling it
> > with a skewed y-gradient density to get a flat bottom and then adding a mixture
> > of wrinkles, bozo and crackle (form<1, 0, 0>) to try to approximate fluffy tops.
> > Some of my images over at www.landofthefirst.com were created using this. I am
> > still not 100% happy with them.
>    The ones at Othil Homtoh look very nice...
> jaime
Here is the code:
    #macro SkyShell(minAlt, maxAlt, Int)
        difference
            sphere {<0, 0, 0> 1000000+maxAlt}
            sphere {<0, 0, 0> 1000000+minAlt}
            hollow
            texture {pigment {color rgbf 1}}
            interior {Int}
            translate <0, -1000000, 0>
    SkyShell(4000, 5000,
        interior {
            media {
                method 3
                samples 20
                scattering {2, color rgb 0.0075 extinction 1}
                density
                    wrinkles
                    scale <4000, 1000, 4000>
                    warp { turbulence 2 }
                    lambda 4
                    color_map
                        [0.00 color rgb 1.0]
                        [0.50 color rgb 0.8]
                        [0.55 color rgb 0.0]
                        [1.00 color rgb 0.0]
                    translate <-4000, 0, -1000>
                density
                    gradient y
                    scale 1000
                    color_map
                        [0.0  color rgb 0.00]
                        [0.4  color rgb 1.00]
                        [0.9  color rgb 1.00]
                        [1.0  color rgb 0.00]
I lied. It was concentric spheres!
And nice solution for the artifacts! One to remember.
Date: 28 Apr 2016 13:48:41
Message: <57224cf9$1@news.povray.org>
On 4/26/2016 12:39 PM, Jaime Vives Piqueres wrote:
> El 26/04/16 a las 15:02, Norbert Kern escribió:
>> Nice and fluffy as it should be.
>   Thanks... perhaps too fluffy, tough.
>> The method of averaging object patterns will be of further use - at
>> least I hope
>> so...
>  Well, it's nothing fancy, just the average pattern. The real trick is
> that the averaged blobs are concentric (with diminishing radius and the
> same threshold):
maybe i'm misunderstanding ... more complicated than taking the base
blob object and making scaled copies?
Date: 28 Apr 2016 14:23:14
Message: <57225512$1@news.povray.org>
   Just scaling down the copies only works for objects which are
symmetric on all axes. Scaling down an irregular, asymmetric blob makes
some components to be displaced towards the center, thus they get
outside the component on the original copy (and yes, I too though it
would work and tried that first... ;).
jaime
Date: 28 Apr 2016 15:20:00
Message: <web.572261c75193772efa0ec0bd0@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 04/28/2016 08:44 AM, Jaime Vives Piqueres wrote:
> >    Thanks for the detailed explanation, but in this case the best
> > solution was the one the other Bill P. suggested. A merge of spheres
> > with same radius and placement did work pretty well, and in this case it
> > doesn't matter as it is an invisible container. It still does the job of
> > being a close container, and the speed up provided is even a little
> > better too.
> Great! At least it was one of the Bill P's helped out... :-)
> Bill P.
Haha, I keep meaning to call this out. Too many Bill Ps! At least you come up as
a William on your account name, that saves huge confusion on the digest page (I
usually use the web view).
Jaime, glad my suggestion worked well. Honestly I nearly didn't say anything, I
thought it was too obvious and that you were bound to have tried it already! I
shall wheel out random suggestions more often in that case :)
Bill (the other P)
Date: 28 Apr 2016 16:25:24
Message: <572271b4@news.povray.org>
   Nothing is too obvious, at least if I'm involved...
jaime
Date: 30 Apr 2016 07:28:11
Message: <572496cb@news.povray.org>
On 28-4-2016 12:59, Jaime Vives Piqueres wrote:
>    BTW, I've just found a way to avoid the "bottom" problem with df3
> clouds:
It makes for different types of clouds of course. Left image is the
original use of the df3 files as densities; right used as pigment
patterns and with a gradient y density.
I had to substantially increase samples to eliminate artifacts. While
left I could get away with samples 10, on the right - to keep on the
safe side - I used samples 100. I probably could easily get away with
samples 50 though.
Download 'my_makecloud2_test_day.png' (852 KB)
Preview of image 'my_makecloud2_test_day.png'
Date: 30 Apr 2016 12:26:10
Message: <5724dca2$1@news.povray.org>
> samples 50 though.
   That's strange... I'm getting good results with just 16 samples.
jaime
Date: 30 Apr 2016 12:29:43
Message: <5724dd77@news.povray.org>
Am 30.04.2016 um 18:26 schrieb Jaime Vives Piqueres:
>> samples 50 though.
Different version?
Media sampling method 3 had various bogosities until somewhen between
3.7.0 and today.
Date: 30 Apr 2016 13:10:00
Message: <web.5724e5f85193772e87fca9f40@news.povray.org>
How do you achieve the atmospheric haze effect?
Date: 1 May 2016 02:47:24
Message: <5725a67c$1@news.povray.org>
That is a fog. The scene is Gilles Tran's.
Date: 1 May 2016 02:52:26
Message: <5725a7aa$1@news.povray.org>
This is basically what I do; most other details are Gilles' original
settings (more or less):
   #declare P_cloud2_1 =
   pigment {density_file df3 "cloud2_1.df3"
     lambda 3
     omega 0.6
     interpolate 1
     translate -0.5
     scale <1, -1, 1>
   #declare Cloud1 =
   box {-0.5,0.5
     texture {pigment {Clear} finish {ambient 0 diffuse 0}}
     hollow
     interior {
       media {
         scattering {1, C_Sun*0.006 extinction 0.25}
         intervals 1
         samples 100, 1000
         density {
           gradient y
           density_map {
             [0 pigment_pattern {P_cloud2_1}
                turbulence Turbulence*0.1
             [1 pigment_pattern {P_cloud2_1}
                turbulence Turbulence*2
     scale <4/3,1,1>
Date: 1 May 2016 03:12:57
Message: <5725ac79$1@news.povray.org>
Sorry, forgot to mention: version 3.7.1 alpha (blablabla) +av123
Date: 1 May 2016 03:35:12
Message: <5725b1b0$1@news.povray.org>
   The only notable difference I see is that I'm using scattering type 2
with default extinction.
jaime
Date: 1 May 2016 04:32:04
Message: <5725bf04@news.povray.org>
The solution was straightforward (see also image):
   #declare Cloud1 =
   box {-0.5,0.5
     hollow
     interior {
       media {
         intervals 1
         samples 50, 1000
         density {
           gradient y
           density_map {
                scale 50 warp {turbulence 0.1} scale 1/50
                scale 50 warp {turbulence 2} scale 1/50
     scale <4/3,1,1>
I shall try your scattering now.
Download 'my_makecloud2_test_day_2016.png' (391 KB)
Preview of image 'my_makecloud2_test_day_2016.png'
Date: 1 May 2016 13:00:28
Message: <5726362c@news.povray.org>
>      lambda 3
>      omega 0.6
>      interpolate 1
>      translate -0.5
>      scale <1, -1, 1>
>    #declare Cloud1 =
>    box {-0.5,0.5
>      hollow
>      interior {
>        media {
>          intervals 1
>          samples 100, 1000
>          density {
>            gradient y
>            density_map {
>      scale <4/3,1,1>
samples 100, 1000 is specific to method 1 and 2. As it is now, the 1000
is ignored.
Also, it's preferable to not set intervals at all and just use the
default of 1.
Date: 2 May 2016 03:40:49
Message: <57270481$1@news.povray.org>
> is ignored.
> default of 1.
Yes, thanks. I know this and - as it happens - just overlooked the
second samples value.
Date: 2 May 2016 06:39:24
Message: <57272e5c$1@news.povray.org>
Jaime Vives Piqueres wrote on 28/04/2016 14.44:
> El 28/04/16 a las 14:32, William F Pokorny escribió:
>> Hope one or more things here enough to get this cloud method working
>> generally.
> better too.
> jaime
:-o
Date: 3 May 2016 06:38:27
Message: <57287fa3@news.povray.org>
Latest development:
+ new and improved cumulus shapes using trace() over a rough base shape.
There are 10 different clouds using 500 blob components each one.
+ added cirrus layer using a panoramic photograph of real clouds as
pattern for the media density (had to "cheat" because I could not find
any convincing pattern).
jaime
Download 'ocean-22.jpg' (149 KB)
Preview of image 'ocean-22.jpg'
Date: 3 May 2016 06:57:15
Message: <5728840b$1@news.povray.org>
On 3-5-2016 12:38, Jaime Vives Piqueres wrote:
> Latest development:
Looking very good indeed... I am not entirely convinced by the cirrus
layer though.
Date: 3 May 2016 06:59:37
Message: <57288499$1@news.povray.org>
On 03/05/16 11:38, Jaime Vives Piqueres wrote:
> Latest development:
> jaime
Very convincing cumulus; however, I'm less sure about the cirrus. I
think that a clockwise rotation might fix that.
Having said that, excellent work
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 4 May 2016 01:53:24
Message: <57298e54@news.povray.org>
Thanks, Thomas, John... see if these cirrus look better.
jaime
Download 'ocean-22c.jpg' (142 KB)
Preview of image 'ocean-22c.jpg'
Date: 4 May 2016 02:57:01
Message: <57299d3d$1@news.povray.org>
The wizard did it again! :-)
Yes, that is much, much better.
Date: 4 May 2016 05:47:44
Message: <5729c540@news.povray.org>
> jaime
You're not supposed to use a camera ;-)
Much better. Good work.
John
Protect the Earth
Date: 4 May 2016 08:07:23
Message: <5729e5fb@news.povray.org>
Am 04.05.2016 um 07:53 schrieb Jaime Vives Piqueres:
Something's still odd about this. Can't put my finger on it though.
Maybe thick low-hanging cumulus together with cirrus is a weather
situation we don't normally see?
Maybe there's a 3D-component to your cirrus clouds, whereas in reality
they seem to be quite flat?
Date: 4 May 2016 12:28:58
Message: <572a234a@news.povray.org>
> jaime
Usualy, cirrus clouds looks rather flat due to their altitude and their
small vertical extent.
My take would be to use a plane or very large, somewhat flattened,
sphere and use an image_map. Just be sure to set that to no_shadow.
Anyway, normaly, cirrus don't cast noticeable shadows as they are so thin.
Personaly, I'v seen some cases where you have cirrus above some other
clouds formations. Even cirrus above other cirrus, in this case, it's
usualy strato-cirrus above cirrus.
Date: 4 May 2016 16:45:44
Message: <572a5f78@news.povray.org>
   Well, it's not really that strange to have cirrus over cumulus, tough
most of the time there is a clear sky over them.
> reality they seem to be quite flat?
   The media shell is very thin, so I think that's not the problem. I
think it was the fact that I forgot to map them spherically, so they
don't look to be as high as they should.
jaime
Date: 4 May 2016 16:47:21
Message: <572a5fd9@news.povray.org>
> their small vertical extent. My take would be to use a plane or very
> large, somewhat flattened, sphere and use an image_map. Just be sure
> to set that to no_shadow. Anyway, normaly, cirrus don't cast
   I tried first the image map, but it was hard to match the lighting on
the photo with the sun on the scene, so I opted to use the photo as a
pattern for scattering media.
>  clouds formations.
   Me too...
jaime
Date: 22 Feb 2018 15:56:25
Message: <5a8f2e79@news.povray.org>
>> jaime
> Here is the code:
>          difference
>              hollow
>              interior {Int}
>      #end
>          interior {
>              media {
>                  method 3
>                  samples 20
>                  density
>                      wrinkles
>                      lambda 4
>                      color_map
>                  density
>                      gradient y
>                      scale 1000
>                      color_map
I am having trouble adapting this code. Here's what I have:
#declare lego_units = 20;	// LDU per foot
#declare earth_radius	= 20900000 * lego_units;
#declare earth_circum	= floor(2 * pi * earth_radius / 640) * 640;
#declare earth_radius	= earth_circum/2/pi;
#declare cloud_min_radius	= 6000 * lego_units;
#declare cloud_max_radius	= 9000 * lego_units;
	#local inner_radius = earth_radius + cloud_min_radius;
	#local outer_radius = earth_radius + cloud_max_radius;
	#local bound_radius = sin(acos(earth_radius/outer_radius)) * outer_radius;
	#local cloud_scale = 1;
	#local cloud_media = media
         method 3
         samples 20
         density
             wrinkles
             scale outer_radius * 300 * <1,1/4,1>
             lambda 4
             color_map
         density
             gradient y
             scale (cloud_max_radius - cloud_min_radius)
             color_map
		scale 1
	#local cloud_sphere = difference
		sphere {0, outer_radius}
		sphere {0, inner_radius}
//		bounded_by {cylinder {<0,-earth_radius,0,>, <0,-outer_radius,0,>,
bound_radius}}
		hollow
		material
			texture {pigment {color srgbft <1,1,1,0,1>}}
			interior
				media {cloud_media}
			scale cloud_scale
		translate +y * earth_radius
	object {cloud_sphere}
However, the effect is very grainy and dark. If I continue to scale it
upward, it turns nearly black. If I scale it downward, I can't see the
clouds any more. Does anyone know what I am doing wrong? Thanks.
Mike
Download 'wrapper_townview_normal.png' (1118 KB)
Preview of image 'wrapper_townview_normal.png'
Date: 22 Feb 2018 17:00:56
Message: <5a8f3d98$1@news.povray.org>
> Mike
Never mind. I think I have a handle on it.
Mike
Date: 22 Feb 2018 18:39:02
Message: <5a8f5496$1@news.povray.org>
On 5/3/2016 6:38 AM, Jaime Vives Piqueres wrote:
> Latest development:
> jaime
Does anyone have any actual code for these poofy clouds? They look so nice!
Mike
