![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 26-4-2016 18:58, Jaime Vives Piqueres wrote:
> Another one using the exact same clouds but with a sunset lighting.
Very nice indeed Jaime. How does this method relate to the df3 one used
by Gilles Tran? I am familiar with that; I also used blobs for making
smoke (Chris Huff or Michael Carneholm macros) but they are pretty slow.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Jaime Vives Piqueres wrote on 26/04/2016 14.47:
> I was going to add some cumulus to my sea scene, but the ones I had from
> the project tierra where not very convincing, so... I started another
> experiment.
> The approach is similar to that of my previous cumulus include, but with
> a trick to make softer media. As the method involved the object pattern,
> the media was a bit sharp with just 0 or 1 in the density map.
> The trick is to create an array of blob components positions and radius,
> then use that to create 4 blobs with concentric shapes and use them on
> an averaged density map. The results are surprisingly fast... this one
> took "only" 47 min.
> jaime
I like a lot this one!
Paolo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Gorgeous !
I find them an impressionism touch...
Can't wait to see the composition with the sea.
> experiment.
> took "only" 47 min.
> jaime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is excellent. Whenever I've tried to use this type of technique before, I
can never get the media settings right - my clouds either end up
not-really-opaque, i.e. I can see other stuff through even the densest regions,
or so dense that they saturate to black underneath.
Your code looks very straightforward - I must play with it!
Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> used by Gilles Tran? I am familiar with that;
Well, in fact I started first trying df3 clouds: I did my own
"makecloud" using ARRAYS_WriteDF3() to write the cloud files, sampling
the same blobs I'm using now. It worked fine, but it was slow to
generate clouds with decent resolution, and the look was too fluffy.
Also, I found no way to make the clouds less turbulent at bottom.
> I also used blobs for making smoke (Chris Huff or Michael Carneholm
Well, I'm using another blob as container, and perhaps that's making
them faster, because I find them not much slower than the df3 ones.
jaime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah yes, the cloud bottom was a problem indeed.
That's interesting. Thanks!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks!
jaime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Gorgeous ! I find them an impressionism touch...
Thanks. The "impressionism" touch is nice, but to be frank is only the
result of not being realistic enough... :(
I still have some things to try with the clouds, but I will let it
render this evening, as I've to leave for some hours... will post tonight.
jaime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 04/26/2016 12:56 PM, Jaime Vives Piqueres wrote:
> El 26/04/16 a las 15:52, William F Pokorny escribió:
>> Impressive - though am I correct there are some artifacts in the
>> right part of the center top plume? Was it run with AA ?
> You have a good eye... I had to zoom several times to see them! Yes,
> it was run without AA, and the artifacts are likely due to the media
> container (another blob, BTW... I forgot to mention this).
>> Asking mostly because of my continuing look into blob related
>> bugs.Those spots look like other issues I have seen related to media
>> and blobs at the blob(s) boundary.
> Yes, that's likely the problem: see the attached test. The inner solid
> blob is the object used on the density pattern, and the transparent
> outer blob is the media container: you can clearly see the artifacts are
> coincident with a blob boundary.
> jaime
Thanks for checking Jaime. The image is also helpful for understanding
your cloud technique.
Let me add my apologies for the many times I've no doubt mistyped your
name. I typed again this morning - Jamie - but saw it this time.
Many days, my eyes & brain fail to see in the moment the scrambled
things my fingers type!
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> before, I can never get the media settings right - my clouds either
> end up not-really-opaque, i.e. I can see other stuff through even the
> densest regions, or so dense that they saturate to black underneath.
Yeah... POV-Ray media isn't easy to setup. In fact it can drive you
crazy most of the time. It's happening to me now as I'm trying to add
another media for the haze (I was using a ground fog until now). But it
looks gorgeous when you find the right setup for your scene...
jaime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
