POV-Ray : Newsgroups : povray.binaries.images : Inversion Server Time
27 May 2026 10:02:19 EDT (-0400)
  Inversion (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Inversion
Date: 10 Apr 2016 21:15:01
Message: <web.570af99bc6ebc480fd6b6fe10@news.povray.org>
> Am 09.04.2016 um 22:32 schrieb Bald Eagle:
> > clipka <ano### [at] anonymousorg> wrote:
> >> What this new incarnation will add is the ability to apply different
> >> tonemapping functions to each colour channel, perform cross-channel
> >> colour maths, and as an extra bonus even use functions that depend on
> >> the screen location.
> > So, this would be analogous to various image processing features and "filters"
> > that a lot of graphics programs have?
> > I find the screen location feature interesting, and am wondering how that will
> > function, and what inspired its development.
> "Because we can".
> Actually the chain of thought was something like this:
<snip>
> And that's how the screen coordinates have ended up in the tonemapping
> feature.
> > I would imagine that various functions could be used to adjust brightness and
> > colour using gradients, concentric-type adjustment such as the cos^4 brightness
> > dropoff typically seen in camera lenses, etc.
> > I guess you could also use one image to map/adjust tones onto/in another kind of
> > like a pigment/texture/image map.
> With the x and y screen coordinates available, it should be possible to
> write tonemapping functions that overlay a pattern onto the image (via a
> pattern function); such a pattern could in turn be arbitrarily complex,
> from a simple spherical pattern creating a vignette effect to a complex
> object pattern based on one or more text objects overlaying textual
> information like a singature or frame number.
In the spirit of foresightedness... I'm going to shill for my idea of a plugin
api again.  Because:
1) New functionality should be added by new code, not modification of old,
working code.
2) Adding a plugin to a directory and using dependency injection would be vastly
preferable to recompiling multiple un-official versions.
In fact, I would imagine that large parts of the current codebase could be
abstracted out as plugins (necessary core plugins, perhaps, but plugins)
I would also imagine that this would be a task of more than somewhat Herculean
porportions, so I completely understand resistance.
Unfortunately, I wouldn't know where to begin with such a thing, as I have a
hard time following the patterns in the codebase. (to put it lightly)
*kicks the hornet nest and hides*
A.D.B.
Date: 10 Apr 2016 23:36:36
Message: <570b1bc4@news.povray.org>
Am 11.04.2016 um 03:13 schrieb Anthony D. Baye:
> api again.  Because:
Your motion is moot, because:
> working code.
While that may be true in an ideal world, in reality sometimes (actually
more often than not) new code needs to be hooked up someplace nobody had
ever imagined that code might have to be hooked up there, so plugins are
always more limited than patches.
Providing hooks to inject user-defined code wherever suitable is already
on the agenda. Except that there most likely won't be a plugin
directory; instead, such user-defined code would be written in a
next-generation scene description language, compiled to some virtual
machine bytecode, and uiltimately just-in-time-compiled to native code.
Not yet.
You're perfectly right as far as the proportions are concerned, but
you're off the mark concerning resistance. Herculean work is already
going on in the background.
Don't even try. The current codebase is still far too monolithic to bolt
on any way to inject user code. But we're working on it, slowly but
thoroughly.
Date: 11 Apr 2016 02:50:20
Message: <570b492c$1@news.povray.org>
On 10-4-2016 20:30, Jaime Vives Piqueres wrote:
> El 10/04/16 a las 17:10, clipka escribió:
>> But yeah, go out and enjoy the beautiful spring weekend. Desert me.
>> Go ahead and see if I care. ;)
>    I'm really curious about that new feature and wanted to test it today,
> but your derivatives example and my broken washing machine kept me busy
> all day... luckily, I could repair the washing machine, and somehow I
> worked out the derivatives example into a functional foam pattern (tough
> I'm still fine-tuning it).
What lame excuses! :-)
I am curious about the foam pattern. I have tried some ideas of my own
yesterday but to no conclusive results.
Date: 11 Apr 2016 05:32:48
Message: <570b6f40$1@news.povray.org>
This is PovRay's - Fermat's Last Theorem
I shall cheer on from the sidelines. And watch with interest.
Regards
Date: 11 Apr 2016 06:13:36
Message: <570b78d0@news.povray.org>
    No, really... my back hurts now, as I had to be laying on the ground
almost 2 hours to remove the obstruction on the drain pump. And my brain
hurts too, after some more hours fiddling with the derivatives result to
convert them into an usable pattern.
    I will publish the code soon, but here it is an extract:
// the derivatives
#declare EPSILON = 1e-4;
#declare
f1x=function{(f_water(x+EPSILON,y,0)-f_water(x-EPSILON,y,0))/2*EPSILON}
#declare
f1y=function{(f_water(x,y+EPSILON,0)-f_water(x,y-EPSILON,0))/2*EPSILON}
#declare f2x=function{(f1x(x+EPSILON,y,0)-f1x(x-EPSILON,y,0))/2*EPSILON}
#declare f2y=function{(f1y(x,y+EPSILON,0)-f1y(x,y-EPSILON,0))/2*EPSILON}
// the texture from them
#declare t_ocean=
texture{
    pigment_pattern{
function{select(f2x(x,y,0)+f2y(x,y,0),abs(f2x(x,y,0)+f2y(x,y,0))*1000000000*4,0)}
    texture_map{
      [0.0 t_water]
      [0.1 t_foam]
    As you can see, the final pattern using the derivatives is tricky...
I had to play with EPSILON to find a value suitable for the scale of my
height_field and the "precision" I wanted. Then used select find the
negative parts and convert them to positive, and scaling the values up
because they are extremely small. Don't ask me how the hell I worked
that out... attached is a first render showing the result. Still not
what I want, but seems this is the way to go.
jaime
Download 'ocean-16.jpg' (147 KB)
Preview of image 'ocean-16.jpg'
Date: 11 Apr 2016 06:54:39
Message: <570b826f$1@news.povray.org>
On 4/11/2016 11:13 AM, Jaime Vives Piqueres wrote:
> Still not what I want, but seems this is the way to go.
That looks just like before the foam starts streaming.
It is more than acceptable. Quite realistic, the horizon is not swamped
with small detail but my eye can see the longer frequency waves as you
would. It is only the foreground wave that needs a bit of breaking foam.
You could hang it on your wall. :)
I think that you are working in the right area. What sort of time did it
take? And what is the camera's FOV? I'm just curious.
Regards
Date: 11 Apr 2016 07:09:02
Message: <570b85ce$1@news.povray.org>
phew...! That is pretty good Jaime. Not yet there but very very close. I
wanted to explore further some ideas proposed by Marc Jacquier in his
sea code but I am not getting really anywhere. It probably is a dead
end, but worth looking into.
Date: 11 Apr 2016 07:23:47
Message: <570b8943@news.povray.org>
> did it take? And what is the camera's FOV? I'm just curious.
   Thanks... this one took only 11 seconds to parse (because the sea HF
is only 2048x2048, versus the final one of 10240x10240), and 17 minutes
to render (yes, the derivatives pattern is not much faster than the
proximity pattern, after all).
   About the camera, if you meant the angle... I don't know, I used
direction here:
   up 9*y right 16*x
   direction 16*z
jaime
Date: 11 Apr 2016 07:25:54
Message: <570b89c2$1@news.povray.org>
El 11/04/16 a las 13:08, Thomas de Groot escribió:
> On 11-4-2016 12:13, Jaime Vives Piqueres wrote: phew...! That is
> pretty good Jaime. Not yet there but very very close. I wanted to
> explore further some ideas proposed by Marc Jacquier in his sea code
> but I am not getting really anywhere. It probably is a dead end, but
> worth looking into.
   Thanks! I tried almost everything, and the only two approaches getting
some believable foam patterns are proximity and derivatives. I'm
suspecting a mix of the two would really do it...
jaime
Date: 11 Apr 2016 07:52:04
Message: <570b8fe4$1@news.povray.org>
> direction here:
>    up 9*y right 16*x
>    direction 16*z
It looks really good full screen. I can actually see what looks like
waves that have been reflected off a shore. Amazing what the brain will
make of images. :-)
As it was a test you might have used a wide angle along the horizontal.
To get a wider view.
That's not too bad a time. I would not want to put it in an animation at
the larger resolution, though.
Regards
