POV-Ray : Newsgroups : povray.binaries.images : Furry towel Server Time
21 Dec 2025 03:22:44 EST (-0500)
  Furry towel (Message 1 to 10 of 19)
Subject: Furry towel
Date: 8 Mar 2016 05:25:01
Message: <56dea87d@news.povray.org>
This is an old mesh generated with Megapov back in 2006, but now
resurrected to try some "furrifying" experiments. It uses some 260000
mesh threads traced randomly onto the mesh. No hg-povray yet... just a
test with regular pov for later comparison. Renders really fast using
default radiosity (1m46s), and parse time is not that bad (1m3s).
The lovely image map used as base is from archivetextures.net.
I like the look of it... like a softener ad: makes you want to rub your
face on it.
jaime
Download 'drap-04b-2m49s.jpg' (323 KB)
Preview of image 'drap-04b-2m49s.jpg'
Subject: Re: Furry towel
Date: 8 Mar 2016 05:50:01
Message: <web.56dead2dde63faef9e16205b0@news.povray.org>
> face on it.
> jaime
I love it - do you remember memory need?
Norbert
Date: 8 Mar 2016 06:05:12
Message: <56deb1e8$1@news.povray.org>
   No, but I just rendered it again, and I can't see it reported
anywhere on the output:
==== [Parsing...] ==========================================================
Parsing 98471K tokens
Parser Statistics
Finite Objects:       260003
Infinite Objects:          1
Light Sources:             1
Total:                260005
Parser Time
   Parse Time:       0 hours  1 minutes  3 seconds (63.464 seconds)
               using 1 thread(s) with 48.768 CPU-seconds total
   Bounding Time:    0 hours  0 minutes  0 seconds (0.913 seconds)
               using 1 thread(s) with 0.911 CPU-seconds total
Render Options
   Quality:  9
   Bounding boxes.......On   Bounding threshold: 3
   Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter
1.00,
  Gamma 2.50)
==== [Rendering...] ========================================================
Rendered 786432 of 786432 pixels (100%)
Render Statistics
Image Resolution 1024 x 768
Pixels:           836189   Samples:         6236739   Smpls/Pxl: 7.46
Rays:            8784686   Saved:                 0   Max Level: 4/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                           12303161        12303161    100.00
Mesh                         359030468        34685638      9.66
Plane                         12303161         7880984     64.06
Sphere                        12303161        12303161    100.00
Bounding Box                3818952101      1488571642     38.98
Shadow Ray Tests:           5559559   Succeeded:               3350070
Shadow Cache Hits:          2041084
Radiosity samples calculated:            51432 (0.59 %)
   discarded due to low quality:           4356
   retained for re-use:                   47076
Radiosity samples reused:              8649801
Radiosity sample rays shot:            1711758
Radiosity octree nodes:                   1181
Radiosity octree samples/node:           39.86
Radiosity blocks examined:         10482324788
Radiosity blocks passed test 0:    10482324788 (100.00 %)
Radiosity blocks passed test 1:     1227842362 (11.71 %)
Radiosity blocks passed test 2:      913390395 (8.71 %)
Radiosity blocks passed test 3:      184540151 (1.76 %)
Radiosity blocks passed test 4:       63080136 (0.60 %)
Radiosity blocks passed test 5:       59940830 (0.57 %)
Radiosity blocks rejected:         10422383958 (99.43 %)
Radiosity Depth 0 calculated:            46523 (0.66 %)
Radiosity Depth 0 reused:              7026405
Radiosity Depth 0 rays shot:           1628305
Radiosity (final) calculated:            46109 (0.53 %)
Radiosity (final) reused:              8633344
Radiosity (final) rays shot:           1610377
   Pass     Depth 0    Depth 1           Total
   1            130       1220            1350
   2            475       3498            3973
   Final      45918        191           46109
   Total      46523       4909           51432
   Weight     0.451      0.269
Render Time:
   Photon Time:      No photons
   Radiosity Time:   0 hours  0 minutes  0 seconds (0.723 seconds)
               using 6 thread(s) with 3.843 CPU-seconds total
   Trace Time:       0 hours  1 minutes 27 seconds (87.606 seconds)
               using 6 thread(s) with 517.339 CPU-seconds total
==== [Paused] ==============================================================
Press a key or click the display to continue...
POV-Ray finished
jaime
Date: 8 Mar 2016 07:20:57
Message: <56dec3a9$1@news.povray.org>
> face on it.
> jaime
I would gladly dry myself off with that.
Mike
Date: 8 Mar 2016 07:27:56
Message: <56dec54c$1@news.povray.org>
> face on it.
That does look good.
Regards
Date: 8 Mar 2016 07:30:13
Message: <56dec5d5@news.povray.org>
> face on it.
> jaime
Reminds me of this render from 2014. I don't know how many threads were
used in this one; quite a lot for the whole carpet and it was pretty
fast too iirc.
Download 'eval_pigmenttest_03.png' (1078 KB)
Preview of image 'eval_pigmenttest_03.png'
Date: 8 Mar 2016 12:23:17
Message: <56df0a85$1@news.povray.org>
> were used in this one; quite a lot for the whole carpet and it was
> pretty fast too iirc.
   Ah, yes... I didn't remember that one, but do remember now. Looks
gorgeous too. But here the threads seem all vertical? On my towel I used
a pigment (bumps) as a guide to tilt the threads smoothly.
jaime
Date: 8 Mar 2016 13:40:58
Message: <56df1cba$1@news.povray.org>
> face on it.
> jaime
Are you sure that's not the reference photo that you used as an inspiration?
Date: 9 Mar 2016 02:47:02
Message: <56dfd4f6$1@news.povray.org>
> inspiration?
   I didn't use a reference photo this time... sorry! :)
jaime
Date: 9 Mar 2016 03:08:12
Message: <56dfd9ec@news.povray.org>
I used a slight perturbation on the threads' angles. Nothing fancy I
confess. It was a kind of proof of concept for me and I might dig into
the code some day when I shall need a carpet badly (that is how things
work for me most of the time).
I checked the code and saw it dropped 500k threads on the whole carpet.
