POV-Ray : Newsgroups : povray.binaries.images : Cave concept Server Time
25 Jun 2026 13:10:45 EDT (-0400)
  Cave concept (Message 1 to 10 of 64)
Subject: Cave concept
Date: 29 Feb 2016 05:44:56
Message: <56d42128@news.povray.org>
Hi:
     Here is a new scene on the making... a cave with stalactites and
stalagmites. The rough shape is a mesh created with Wings3d, then I
added a heighfield for the ground, and thrown some isosurface rocks
using trace(). Finally, also using trace(), I added some stalactites and
stalactites, which are cone-shaped isosurfaces. The water is currently a
simple plane, but should evolve into a heighfield. And yes, there will
be crystals there at some point, but for the moment I'm just looking for
comments/suggestions about the cave itself.
jaime
Download 'the-cave-05-2h2m.jpg' (111 KB)
Preview of image 'the-cave-05-2h2m.jpg'
Subject: Re: Cave concept
Date: 29 Feb 2016 06:19:04
Message: <56d42928$1@news.povray.org>
Jaime Vives Piqueres wrote on 29/02/2016 11.44:
> Hi:
> jaime
The scene is beautiful as usual, but in my opinion the textures are a
bit too dark (usually the limestone is more pale) and perhaps need to be
a bit reflective near stalactites and stalagmites in order to give a
sense of humidity.
Paolo
Date: 29 Feb 2016 07:22:39
Message: <56d4380f$1@news.povray.org>
>> Hi:
>> jaime
> sense of humidity.
> Paolo
I agree with Paolo. Here there seems to be a lot of iron in the water ;-)
I happened to read/watch about the Frasassi Caves in Le Marche in Italy
a couple of days ago. There are those beautiful lace-like stalactite
structures which I would like to see. Also, of course, a bit of
translucency.
Date: 29 Feb 2016 07:36:52
Message: <56d43b64$1@news.povray.org>
> to be a bit reflective near stalactites and stalagmites in order to
> give a sense of humidity.
   Good points, thanks... the first one should be easy to fix, but the
second is going to be a render-time-nightmare.
jaime
Date: 29 Feb 2016 07:40:10
Message: <56d43c2a@news.povray.org>
> Italy a couple of days ago. There are those beautiful lace-like
> stalactite structures which I would like to see. Also, of course, a
> bit of translucency.
    Well, after looking at images from these amazing caves, I hope you're
joking... it would be terrifically difficult to go for something even
remotely resembling that.
   And I better will do I as I've not heard about translucency on
isosurfaces... :)
jaime
Date: 29 Feb 2016 08:44:06
Message: <56d44b26$1@news.povray.org>
Am 29.02.2016 um 11:44 schrieb Jaime Vives Piqueres:
Stalactites and stalactites, and I guess more stalactites, right? And of
course stalactites ;)
Looks fascinating.
Date: 29 Feb 2016 08:54:31
Message: <56d44d97$1@news.povray.org>
They do use coloured lights around the rocks and in the water, you know. :-)
Regards
Date: 29 Feb 2016 09:45:01
Message: <web.56d4591fa0304854823f4a0f0@news.povray.org>
> Hi:
It's dark in caves - therefore I'm used to cave images lighted with torches,
head lamps or other other point lights. I expect strong specular reflections and
light fading - especially in humid caves.
With this lighting the cave looks "flat" - I'm sure you are aware of this.
Norbert
Date: 29 Feb 2016 11:05:01
Message: <web.56d46b08a03048545e7df57c0@news.povray.org>
I'd say that shape-wise, you're off to a good start so far.
Your material texturing probably needs to have some more --- differentiation.
In my mind's eye, I conceive of layers and strata and veins of different
minerals and sediments, and oxides, and benthic layers, etc.
The homogeneous red-rust-brown looks like someone sprayed it with pigment or
rusty water.   I had a shower supplied by a dug well that looked like that.   :O
as for real caves - browse around and see what _you_ think.
https://www.google.com/search?q=caves&rlz=1C1AFAA_enUS660US660&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwivuvDQqp3LAhX
C9h4KHZLNBRsQsAQIHA&biw=1366&bih=705
I have no doubt that you'll come up with something visually stunning, inspiring,
and something to learn from and aspire towards - as usual.  :)
Date: 29 Feb 2016 11:23:23
Message: <56d4707b@news.povray.org>
> Norbert
Just a gentle reminder that TC-RTC finishes today (GMT) and all entries
need to be rated. :-)
Regards
