POV-Ray : Newsgroups : povray.binaries.images : Cave concept Server Time
25 Jun 2026 18:55:02 EDT (-0400)
  Cave concept (Message 5 to 14 of 64)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Cave concept
Date: 29 Feb 2016 07:40:10
Message: <56d43c2a@news.povray.org>
El 29/02/16 a las 13:22, Thomas de Groot escribió:
> I happened to read/watch about the Frasassi Caves in Le Marche in
> Italy a couple of days ago. There are those beautiful lace-like
> stalactite structures which I would like to see. Also, of course, a
> bit of translucency.
    Well, after looking at images from these amazing caves, I hope you're
joking... it would be terrifically difficult to go for something even
remotely resembling that.
   And I better will do I as I've not heard about translucency on
isosurfaces... :)
jaime
Date: 29 Feb 2016 08:44:06
Message: <56d44b26$1@news.povray.org>
Am 29.02.2016 um 11:44 schrieb Jaime Vives Piqueres:
>     Here is a new scene on the making... a cave with stalactites and
> stalagmites. The rough shape is a mesh created with Wings3d, then I
> added a heighfield for the ground, and thrown some isosurface rocks
> using trace(). Finally, also using trace(), I added some stalactites and
> stalactites, which are cone-shaped isosurfaces.
Stalactites and stalactites, and I guess more stalactites, right? And of
course stalactites ;)
Looks fascinating.
Date: 29 Feb 2016 08:54:31
Message: <56d44d97$1@news.povray.org>
They do use coloured lights around the rocks and in the water, you know. :-)
Regards
Date: 29 Feb 2016 09:45:01
Message: <web.56d4591fa0304854823f4a0f0@news.povray.org>
> Hi:
>      for the moment I'm just looking for
> comments/suggestions about the cave itself.
It's dark in caves - therefore I'm used to cave images lighted with torches,
head lamps or other other point lights. I expect strong specular reflections and
light fading - especially in humid caves.
With this lighting the cave looks "flat" - I'm sure you are aware of this.
Norbert
Date: 29 Feb 2016 11:05:01
Message: <web.56d46b08a03048545e7df57c0@news.povray.org>
I'd say that shape-wise, you're off to a good start so far.
Your material texturing probably needs to have some more --- differentiation.
In my mind's eye, I conceive of layers and strata and veins of different
minerals and sediments, and oxides, and benthic layers, etc.
The homogeneous red-rust-brown looks like someone sprayed it with pigment or
rusty water.   I had a shower supplied by a dug well that looked like that.   :O
as for real caves - browse around and see what _you_ think.
https://www.google.com/search?q=caves&rlz=1C1AFAA_enUS660US660&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwivuvDQqp3LAhX
C9h4KHZLNBRsQsAQIHA&biw=1366&bih=705
I have no doubt that you'll come up with something visually stunning, inspiring,
and something to learn from and aspire towards - as usual.  :)
Date: 29 Feb 2016 11:23:23
Message: <56d4707b@news.povray.org>
> Norbert
Just a gentle reminder that TC-RTC finishes today (GMT) and all entries
need to be rated. :-)
Regards
Date: 29 Feb 2016 12:02:02
Message: <56d4798a@news.povray.org>
Interesting. I, too, thought about concepts how to make a cave. :-)
It's a good idea.
My method would have been to create an iso surface and divide this from
a box. The resulting difference would be the cave. For the stalagtites
and -mites I would have used blobs. But that was my way, your way is
interesting and good, too. :-)
On 29.02.2016 05:44, Jaime Vives Piqueres wrote:
> Hi:
> stalactites, which are cone-shaped isosurfaces. The water is currently a
> simple plane, but should evolve into a heighfield. And yes, there will
> be crystals there at some point, but for the moment I'm just looking for
Date: 29 Feb 2016 12:05:37
Message: <56d47a61$1@news.povray.org>
Here my suggestion for the illumination:
an irregular hole somewhere at the ceiling, where some light rays come
in and are even visible in the dusty air inside the cave. Some radiosity
and air that distributes the light further. Maybe a seedling or small
plant in the center of the light.   :-)
>> Norbert
Date: 29 Feb 2016 13:09:53
Message: <56d48971@news.povray.org>
>> you're joking... it would be terrifically difficult to go for
>> something even remotely resembling that.
> know. :-)
   Yes, I know... I was referring to the intricate shapes of the
stalagmites and stalactites.
jaime
Date: 29 Feb 2016 13:14:57
Message: <56d48aa1$1@news.povray.org>
> of course stalactites ;)
   Yeah, I know what you mean... :) At the moment there are only
stalactites paired with corresponding stalagmites, but there should be a
lot of more think stalactites all around the ceiling.
> Looks fascinating.
   Thanks, it's also terrifically slow to render when you add area light,
focal blur and radiosity, to not talk about the suggested sss and wet
reflections. I'm not the kind of guy who waits patiently for a week to
complete a render...
jaime
