POV-Ray : Newsgroups : povray.binaries.images : Area lights and looks_like Server Time
28 Sep 2024 21:19:37 EDT (-0400)
  Area lights and looks_like (Message 1 to 5 of 5)
Subject: Area lights and looks_like
Date: 30 Jan 2016 12:26:58
Message: <56acf262@news.povray.org>
I am having a problem with an area light. Here is the code:
light_source
	0, lamp_color
	area_light
	+z * lamp_length, +y, lamp_number, 1
	area_illumination	on
	looks_like {lamp_bulb}
The lamp in this case is the spiral wrapped tube in the attached images.
The problem is that the tube itself is not being properly lit. It should
be lit fairly evenly along its whole length. Instead, in both the area
light and point light examples, it is being lit heavily from the center
and not at all from the ends. Hence, parts of the tube in both images
are unlit from the direction of the camera.
How do I fix this?
Mike
Download 'gh_scene_spinner_cutaway_e - copy_area_light.png' (443 KB) Download 'gh_scene_spinner_cutaway_e - copy_point_light.png' (118 KB)
Preview of image 'gh_scene_spinner_cutaway_e - copy_area_light.png'
Preview of image 'gh_scene_spinner_cutaway_e - copy_point_light.png'
Subject: Re: Area lights and looks_like
Date: 30 Jan 2016 14:28:19
Message: <56ad0ed3$1@news.povray.org>
> light_source
>      0, lamp_color
>      area_light
> How do I fix this?
> Mike
Oops! I added area_illumination on to the code, but didn't check to see
if it worked. That seems to have solved the issue.
But I decided to also add emission, which was even better.
Mike
Date: 30 Jan 2016 16:39:25
Message: <56ad2d8d$1@news.povray.org>
Am 30.01.2016 um 20:28 schrieb Mike Horvath:
I was just about to ask what version of POV-Ray you are using, and to
state that "area_illumination" _should_ take care this in current
versions ;)
Yes, I guess in your case a purely emissive surface (no diffuse, no
highlights) should be the ideal solution.
Make sure to specify "no_radiosity" though.
Date: 30 Jan 2016 20:56:23
Message: <56ad69c7$1@news.povray.org>
Could you explain what that does? The docs are very brief on the subject.
Mike
Date: 30 Jan 2016 21:24:51
Message: <56ad7073$1@news.povray.org>
Am 31.01.2016 um 02:56 schrieb Mike Horvath:
It makes the radiosity code act as if the object wasn't there.
It solves the problem that a light source with a looks_like source would
illuminate the world twice if radiosity is enabled: Once via the classic
raytracing code computing the illumination from light sources, and once
via the radiosity code computing the illumination from objects (which by
default includes looks_like objects).
