POV-Ray : Newsgroups : povray.binaries.images : Colony ship Server Time
2 Jun 2024 11:30:09 EDT (-0400)
  Colony ship (Message 11 to 20 of 92)
Subject: Re: Colony ship
Date: 9 Jan 2016 20:48:21
Message: <5691b865$1@news.povray.org>
Am 10.01.2016 um 01:51 schrieb Mike Horvath:
> I guess I should clarify that what you see in that last image is not a
> texture, but a physical array of cylinders and tori. Replacing them with
> a proper texture would make the scene render much faster as well.
Ah, I guess we have a misunderstanding there. I thought you wanted the
semi-transparent paraboloid sheet to look more like a fine mesh, but now
my understanding is that it is the visible support structure of that
paraboloid that you want to look more like a mesh.
Well, my guess there is that it doesn't look like wires because they're
not really the size of wires, and also because the "longitudinal" and
"latitudinal" structures simply intersect. Maybe if they just touched
each other, possibly in an alternating "weaving" fashion, and maybe
connected with some "clamps", it might look better.
Also I wouldn't use copper. It's expensive, heavy, and you only need it
if there are high currents involved. Presuming the shield is primarily
based on static voltage, metals with higher resistance should work just
as fine.
Aluminum might make for a great alternative, too.
Date: 9 Jan 2016 22:50:56
Message: <5691d520$1@news.povray.org>
> as fine.
No, you were right. I want to make the paraboloid sheet to look like a
mesh. The solid ribs take too long to render.
I will also switch the material to look the same as the engine nozzle.
Mike
Date: 10 Jan 2016 00:15:35
Message: <5691e8f7@news.povray.org>
> as fine.
Here's the code I use for the paraboloid, by the way. Whatever i end up
doing, it has to match up with that.
#local glass_cone = difference
	object
		Paraboloid_Z
		scale nose_cone_radius
		translate -z * ext_glass_thick/2
	object
		Paraboloid_Z
		translate +z * ext_glass_thick/2
Date: 11 Jan 2016 17:49:42
Message: <56943186@news.povray.org>
On 1/5/2016 11:31 PM, Mike Horvath wrote:
> I decided to dust off this old scene and work on a few more bits.
> I finalized how the docking bay and engine are going to be laid out, and
> I am happy with them.
> I also split the habitation area into two counter-rotating sections. I'm
> thinking of making the end caps concave, like the bottom of a soda can.
> A note about the cone in front. It's supposed to be a mesh of copper or
> gold wires that are electrically charged to keep dust from coming in
> contact with the ship. Kind of the opposite of a solar sail. I need to
> work on the wires a bit more to make them apparent.
> Enjoy!
> Mike
I changed the texture of the nose cone. I'm pretty happy with it. I
think I got all the things done on my checklist. I will put the project
back on the shelf until some later time when I come up with new ideas.
For now I am done.
Mike
Download 'gh_scene_spinner_cutaway_28_small.png' (1035 KB)
Preview of image 'gh_scene_spinner_cutaway_28_small.png'
Date: 11 Jan 2016 19:29:40
Message: <569448f4$1@news.povray.org>
> For now I am done.
> Mike
I created a youtube video showing how the model has changed over time.
https://www.youtube.com/watch?v=ajeZkwBuzIU
Enjoy!
Mike
Date: 12 Jan 2016 09:57:21
Message: <MPG.30fede481e62b2eb989697@news.povray.org>
In article <569448f4$1@news.povray.org>, mik### [at] gmailcom says...
> Enjoy!
Very cool.  I like the first generation where the solar panels circle
the ship, at 0:53.
Date: 12 Jan 2016 15:04:45
Message: <56955c5d$1@news.povray.org>
> Mike
I tried creating a texture, and while it does look good, it is actually
slower to render than creating the 3D cylindrical ribs.
Mike
Date: 13 Jan 2016 20:11:52
Message: <5696f5d8$1@news.povray.org>
>> Enjoy!
>> Mike
> For now I am done.
> Mike
Do the fuel tanks in back of the space craft appear too small? I was
aiming for nuclear propulsion, but might switch to something else.
Mike
Date: 16 Jan 2016 14:05:58
Message: <569a9496@news.povray.org>
Just got done rendering the attached image. It took 15 hours, and I
haven't even enabled finishes or interiors yet. :(
Mike
Download 'gh_scene_spinner_cutaway_e_method_c_14.45.17.png' (1088 KB)
Preview of image 'gh_scene_spinner_cutaway_e_method_c_14.45.17.png'
Date: 16 Jan 2016 14:35:19
Message: <569a9b77@news.povray.org>
> Mike
I have a rendering that racked about 800 times as much and is currently
just over 50% done...
Ok, it have multiple imbedded spheres and use blured reflection,
refraction, dispersion, photons, irid,...
I get a *LOT* of total internal reflections in those spheres.
