POV-Ray : Newsgroups : povray.binaries.images : Ribbon following spline Server Time
21 Dec 2025 05:03:24 EST (-0500)
  Ribbon following spline (Message 1 to 4 of 4)
Subject: Ribbon following spline
Date: 1 Jan 2016 08:21:18
Message: <56867d4e@news.povray.org>
For kurtz le pirarte, from povray.general
Download 'ribbon.png' (36 KB) Download 'ribbon.pov.txt' (2 KB)
Preview of image 'ribbon.png'
Subject: Re: Ribbon following spline
Date: 3 Jan 2016 02:51:23
Message: <5688d2fb@news.povray.org>
For
complete code :
// --- INCLUDES
#include "myMacros.inc"
#declare displayAxis = false;
#default {
	finish { ambient 0.40 diffuse 0.60 }
// --- CURVE FUNCTION
//		x = cos(t) + 2.cos(2.t)
//		y = sin(t) - 2.sin(2.t)
//		z = 2.e.sin(3.t)
#macro myFunc(thisTime)
   < cos(thisTime) + 2*cos(2*thisTime),
     sin(thisTime)-2*sin(2*thisTime),
     2*sin(3*thisTime)>
// --- MACROS
// --- Returns a vector perpendicular to V1 and V2
#macro VPerp_To_Plane(V1, V2)
   (vnormalize(vcross(V1, V2)))
// -- VRotation() will find the rotation angle from V1 to V2 around Axis.
#macro VRotation(V1, V2, Axis)
(acos(min(vdot(vnormalize(V1),vnormalize(V2)),1))*(vdot(Axis,vcross(V1,V2))<0?-1:1))
// -- Projects a vector onto the plane defined by Axis.
#macro VProject_Plane(V, Axis)
	#local A = vnormalize(Axis);
	(V - vdot(V, A)*A)
#macro Matrix_Trans(A, B, C, D)
	transform {
		matrix <	A.x, A.y, A.z,
					B.x, B.y, B.z,
					C.x, C.y, C.z,
					D.x, D.y, D.z>
#macro curve_Trans (Time, Sky, Foresight)
	#local Location = <0,0,0> + myFunc(Time);
	#local LocationNext = <0,0,0> + myFunc(Time + Foresight);
	#local LocationPrev = <0,0,0> + myFunc(Time-Foresight);
	#local Forward = vnormalize(LocationNext-Location);
	#local Right = VPerp_To_Plane(Sky,Forward);
	#local Up = VPerp_To_Plane(Forward,Right);
	#local Matrix = Matrix_Trans(Right,Up,Forward,Location)
	transform {
		transform Matrix
// --- SCENE
global_settings {
	assumed_gamma 1.80
	max_trace_level 10
	location p2r(50, 25, 15,false)
// up y
// right x*image_width/image_height
	look_at <0, 0, 0>
	angle 36
light_source {
	p2r(45, 45, 1000,false)
	color White
background {
	color White*0
// --- GRID
#if (displayAxis)
	#declare gridSTep=0.50;
	#declare axisLen = 9;
	#declare gridColor = White*0.25;
	drawAxis (axisLen + 0.50, 0.02)
	#declare index=-axisLen*0.50;
	#while (index<= + axisLen*0.50)
		cylinder { <index, 0, -axisLen*0.50>, <index, 0, + axisLen*0.50>, 0.01
pigment { color gridColor } }
		#declare index=index + gridSTep;
	#declare index = -axisLen*0.50;
		cylinder { <-axisLen*0.50, 0, index>, < + axisLen*0.50, 0, index>,
0.01 pigment { color gridColor } }
// --- CURVE
//		z = 2.e.sin(3.t)
//			e = + 1 pour droit (dextre)
//			e = -1 pour gauche (senestre)
#declare deuxpi = 2*pi;
#declare r = 0.05;
#declare courbeFinish = finish {
	phong 0.85
	brilliance 2
#declare currentPt = <0.00, 0.00, 0.00>;
#declare previousPt = <0.00, 0.00, 0.00>;
#declare theColor = rgb <1.00, 1.00, 1.00>*0.80;
#declare tt=0;
#declare step=2*pi/360;
#while (tt<deuxpi)
	#declare currentPt = myFunc(tt);
	sphere { currentPt, r pigment { theColor } finish { courbeFinish } }
	#if(tt!=0)
		cylinder { previousPt, currentPt, r pigment { theColor } finish {
courbeFinish } }
	#declare previousPt = currentPt;
	#declare tt=tt + step;
#declare a = 0.40;
#declare b = 0.05;
#declare cercle = torus {
	a, b
	rotate 90*x
	pigment { color Goldenrod }
#declare p0=< + a, + a, 0>;
#declare p1=<-a, + a, 0>;
#declare p2=<-a, -a, 0>;
#declare p3=< + a, -a, 0>;
#declare cadre = union {
	sphere { p0, 0.05 }
	sphere { p1, 0.05 }
	sphere { p2, 0.05 }
	sphere { p3, 0.05 }
	cylinder { p0 ,p1, b }
	cylinder { p1 ,p2, b }
	cylinder { p2 ,p3, b }
	cylinder { p3 ,p0, b }
	pigment { color Brass }
#declare p0=<0, a, 0>;
#declare p1=< + a*cos(radians(30)), -a*sin(radians(30)), 0>;
#declare p2=<-a*cos(radians(30)), -a*sin(radians(30)), 0>;
#declare Triangle = union {
	sphere { p0, 0.05 }
	sphere { p1, 0.05 }
	sphere { p2, 0.05 }
	cylinder { p2 ,p0, b }
	pigment { color Brass*0.85 }
//	pigment { color Goldenrod*0.75 }
// --- DRAW OBJECTS
// curve_Trans (Time, Sky, Foresight)
#declare index=0;
#while(index<360)
	object {
		Triangle
		curve_Trans (radians(index), y, 0.10)
	#declare index=index + 2;
kurtz le pirate
compagnie de la banquise
Download 'probleme.jpg' (88 KB)
Preview of image 'probleme.jpg'
Date: 3 Jan 2016 04:51:21
Message: <5688ef19@news.povray.org>
> For
> complete code :
in your picture, you used a triangle... and your computation of the
normal has TWO singularities with inversion of the sign on each side of
them. Of course, the triangle is sensible to the sign of the normal.
In attached code, you could replace the SV spline with something totally
different. I just reuse the same function as for SU, and normalized the
vector to get a constant width of the ribbon.
> kurtz le pirate
Download 'ribbon.png' (98 KB) Download 'ribbon.pov.txt' (2 KB)
Date: 10 Jan 2016 01:24:35
Message: <5691f923$1@news.povray.org>
>> For
>> complete code :
... that's exactly what I'm looking for.
i'll try to understand your code.
thanks
kurtz le pirate
