POV-Ray : Newsgroups : povray.binaries.images : Moon rendering (prototype) Server Time
25 Jun 2026 15:41:36 EDT (-0400)
  Moon rendering (prototype) (Message 31 to 40 of 49)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Moon rendering (prototype)
Date: 17 Dec 2015 17:11:03
Message: <567332f7$1@news.povray.org>
Thanks for this information.
I wonder, if we still will find more elements, especially the heavier
ones. Or if we learn, to create ultra-heavy elements by our own somewhen
in the future, thanks to our continuous learning about new cosmic
building blocks (like quarks, black matter, etc.).
Maybe, one day we can even construct exotic elements that have a
negative gravity.
I think, I should go a little bit deeper into this science. Interesting
enough.
Date: 17 Dec 2015 19:30:03
Message: <5673538b$1@news.povray.org>
Maybe that so called "dark matter" is realy just a huge quantity of free
neutrons.
After all, "dark matter" is regarded as been non interacting with light,
having a mass, and only interact with normal matter gravitationaly. The
neutron nicely fit the bill.
> negative gravity.
That mean a negative MASS and ENERGY!
That's the stuff of fiction.
> enough.
If you think about stable elements, no unless there is a catastrophic
break through.
More elements? Yes. But, most will exist only as single atoms for less
than a micro second, 0.000001 second, before they spontaneously
desintegrate.
The heaviest element discovered to date is:
Ununoctium 	symbole: Uuo	 atomic number: 118 and it's most stable
isotope have 294 nucleotides. It's half life is estimated to be less
than a nano-second...
It /could/ be a noble gas following the radon, but is yet to be
classified into any family.
Date: 18 Dec 2015 01:39:53
Message: <5673aa39@news.povray.org>
Yes, this stuff is exciting!
And even better, "Negative Gravity" has been located already in space,
at an asteroid nearby:
https://www.google.com/search?q=Asteroid+Negative+Gravity
Date: 18 Dec 2015 01:44:35
Message: <5673ab53$1@news.povray.org>
Well, "Negative Gravity" as term is tricky, it is not what I previously
thought it is. I was just reading over that article.
Date: 18 Dec 2015 03:09:29
Message: <5673bf39$1@news.povray.org>
I would call that "centripetal force" ;-)
Date: 18 Dec 2015 03:12:10
Message: <5673bfda$1@news.povray.org>
Groan!
Regards
Date: 18 Dec 2015 12:51:18
Message: <56744796$1@news.povray.org>
Am 18.12.2015 um 01:30 schrieb Alain:
> neutrons.
Not really. According to the pretty well-tested Standard Model of
particle physics, free neutrons in deep space would readily undergo
beta(-) decay into hydrogen and electron neutrinos within a matter of a
quarter of an hour on average.
Date: 18 Dec 2015 16:08:27
Message: <567475cb$1@news.povray.org>
There is no such thing as negative gravity.
But... There are cases where it may /look/ as if there is:
A small space object is rotating fast enough that the tengential speed
at it's surface is larger than it's escape velicity.
Only possible if the object is small enough that it's mecanical strength
is higher than the centrifugal force.
In the case of 1950DA asteroid, it looks like the Van Der Waal
interaction could be strong enough. Then again, it may actualy be one
big rock held together by purely mechanical force but that look like
it's more gravel like.
On a another scale, radiation pressure can overcome gravity.
That's a major factor in the solar wind.
At a cosmological scale, it can actualy push whole galaxies away from
one another.
Date: 18 Dec 2015 20:46:41
Message: <5674b701$1@news.povray.org>
Yes, I found out by myself, when reading it. That reporter used a very
misleading headline, my apologies for my error.
Date: 19 Dec 2015 03:07:49
Message: <56751055$1@news.povray.org>
Ouch! "centrifugal" of course :-)
