POV-Ray : Newsgroups : povray.binaries.images : Seraglio (WIP) Teardown Server Time
20 Apr 2026 06:26:59 EDT (-0400)
  Seraglio (WIP) Teardown (Message 1 to 4 of 4)
Subject: Seraglio (WIP) Teardown
Date: 4 Sep 2015 00:14:10
Message: <55e91a92@news.povray.org>
Tearing down the scene to investigate render time problems.
Trace time on this pass was something over 14h, stats are attached below.
I would have expected it to render faster with just one thread per core,
but that doesn't seem to be the case.  This render used 48 threads.
I'm using Radiosity_IndoorHQ from rad_def.inc with one small(ish)
alteration.  Since there aren't any light sources, I bumped the count up
to 160k and set a default importance of .001 with the emitting objects
having an importance of 1.
one problem area seems to be the tiles.  I only have one patch of tiles
in this render (the smallest one).
I said in the other thread that the tiles are modeled as a single prism,
but I was wrong (obviously, since there are two different colors)
they're actually a merge of prisms, each one is individually textured.
I'd consider breaking them into two sets and texturing each set as a
whole, except that it might look odd if the texture for each tile
weren't different.
A.D.B.
Download 'csgtest01.png' (192 KB) Download 'stats.txt' (9 KB)
Preview of image 'csgtest01.png'
Subject: Re: Seraglio (WIP) Teardown
Date: 4 Sep 2015 09:12:21
Message: <55e998b5$1@news.povray.org>
Is there a reason you are using a merge rather than a union?  It is hard
for me to see what is going on, due to the low lighting.
http://wiki.povray.org/content/Knowledgebase:Miscellaneous#Topic_3
Date: 4 Sep 2015 15:05:00
Message: <web.55e9ea4f68945012aaea5cb0@news.povray.org>
I believe it was faster to use a merge when I was first testing the tile macro.
A.D.B.
Date: 5 Sep 2015 02:46:01
Message: <55ea8fa9@news.povray.org>
Hash: SHA256
>>> single prism, but I was wrong (obviously, since there are two
>>> different colors) they're actually a merge of prisms, each one
>> is hard for me to see what is going on, due to the low lighting.
> tile macro.
not really. Merge need to compute all the intersections of a ray with
the object, then remove the ones that are inside the object.
which means an additional inside test per intersection point, IIRC. If
the texture is opaque, union is enough (as it does not remove the
internal points)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlXqj6gACgkQhKAm8mTpkW1CywQA3YklEgHJChlxBWKHWu4W8VpV
DMB/ZxstClAd9LtkoWRUiTm51bLSk8vx/LRE7QYWc+PR3LS1zTdlyM1j7XUbiGVW
8mP4Pv3wZnQkJOtfXp+lbD09HC8mY+k7NGJr42UhfrWyor31Mma+XzxKsEemkx8X
DbsRwGNhFkFva+masWA=
=3Ds9
-----END PGP SIGNATURE-----
