![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This scene file looks different depending on whether you use official
POV-Ray or UberPOV:
----------------------[BEGIN CODE]----------------------
// +w496 +h248
#version 3.6;
#default { finish { diffuse 0.6 ambient rgb 0.16041 } }
light_source
{ <-3.3125, 7.6250, -5.7374>,
rgb 4045.5
fade_power 2 fade_distance 0.10417
spotlight point_at <0, 1, 0> radius 45 falloff 90
camera
{ location <0, 1, -5.6713>
look_at <0, 1, 0>
right 2 * x
up y
angle 55.7560
box
{ -<7, 9, 7>, <7, 9, 7>
pigment { rgb 1 }
plane
{ y, 0
pigment { checker rgb 0.05 rgb 1 }
#declare fn_Hills = function
{ pigment
{ bumps warp { turbulence 0.5 }
scale 0.3
height_field
{ function 100, 100 { fn_Hills (x, y, z).red }
translate <-0.5, 0, -0.5>
scale <4, 1, 4>
pigment { green 0.5 }
-----------------------[END CODE]-----------------------
Image uberhills-v36.jpg was rendered with POV-Ray 3.6.1.
Image uberhills-v37.jpg was rendered with POV-Ray 3.7.0.0.
Image uberhills-uber.jpg was rendered with UberPOV 1.37.1.0-beta.10.
When I tried using a regular (non-pigment) function, there was no
difference between UberPOV and official POV-Ray. I am running openSUSE
13.2 (GNU/Linux) on an Intel Core i7 (quad core).
Download 'uberhills-v36.jpg' (18 KB)
Download 'uberhills-v37.jpg' (20 KB)
Download 'uberhills-uber.jpg' (21 KB)
Preview of image 'uberhills-v36.jpg'
![uberhills-v36.jpg](/povray.binaries.images/attachment/%3C559046b4%40news.povray.org%3E/uberhills-v36.jpg?ttop=443824&toff=1200&preview=1)
Preview of image 'uberhills-v37.jpg'
![uberhills-v37.jpg](/povray.binaries.images/attachment/%3C559046b4%40news.povray.org%3E/uberhills-v37.jpg?ttop=443824&toff=1200&preview=1)
Preview of image 'uberhills-uber.jpg'
![uberhills-uber.jpg](/povray.binaries.images/attachment/%3C559046b4%40news.povray.org%3E/uberhills-uber.jpg?ttop=443824&toff=1200&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 28.06.2015 um 21:11 schrieb Cousin Ricky:
I'll have to investigate what's happening there; might be an error in
the default colour map for the bumps pattern, might be something else.
In the meantime, could you do me a favor and test it with a POV-Ray
3.7.1 development build, to see if the error is in the POV-Ray proper
codebase or the UberPOV modifications?
Thanks a lot.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, now you've given me an excuse to do some beta testing of the alpha.
It's in 3.7.1.
Download 'uberhills-v371.jpg' (21 KB)
Preview of image 'uberhills-v371.jpg'
![uberhills-v371.jpg](/povray.binaries.images/attachment/%3C559185d5%40news.povray.org%3E/uberhills-v371.jpg?ttop=443824&toff=1200&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I can confirm that this is a bug.
In a nutshell, POV-Ray defalts to the wrong noise generator during parsing.
The behaviour was broken by commit 35a20c2 (2014-06-13).
As a workaround, use "noise_generator 2" in the global settings.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 30.06.2015 um 19:39 schrieb clipka:
A source file fix for POV-Ray proper is available now in the master
branch at GitHub.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> parsing.
> branch at GitHub.
All I was able to find was a diff readout for 3 files. Is that all
there is, or is there a new complete alpha release? I guess I'm still
learning my way around GitHub.
I applied those 3 changes to my alpha.8141620 files and recompiled. The
new executable confirms that alpha.8150025 is running, but the problem
remains. I went back to GitHub to see if I had somehow miscopied the
changes, but I couldn't find the page again. (Like I said, I still have
trouble navigating GitHub.)
The good news is that sometime between 3.7.0.0 and 3.7.1-alpha, another
bug was fixed: random white splotches in radiosity renders. I had not
reported it to date, because I was unable to narrow down the problem to
create a simplified scene file. (The attached renders may look simple,
but they were generated by a render rig with somewhat complex
internals.) Thomas de Groot seemed to have a similar problem when
testing out Scott Boham's SkySim, but I concluded that those anomalies
were completely unrelated to my problem.
splotches-36.jpg - Rendered by POV-Ray 3.6.1.
splotches-37.jpg - Rendered by POV-Ray 3.7.0.0. Note the ugly white
splotches. When the hills are deleted, there are no splotches. There
are circumstances in which the hills are present /without/ splotches,
but I have been unable to determine a pattern.
splotches-37norad.jpg - Rendered by POV-Ray 3.7.0.0 without radiosity.
There are no splotches, so they were somehow triggered by radiosity.
splotches-371.jpg - Rendered by POV-Ray 3.7.1. The hills are different,
but the white splotches are gone.
splotches-371ng2.jpg - Rendered by POV-Ray 3.7.1 with noise_generator 2
in global settings. The hills are back as desired.
Download 'splotches-36.jpg' (51 KB)
Download 'splotches-37.jpg' (58 KB)
Download 'splotches-37norad.jpg' (53 KB)
Download 'splotches-371.jpg' (54 KB)
Download 'splotches-371ng2.jpg' (53 KB)
Preview of image 'splotches-36.jpg'
![splotches-36.jpg](/povray.binaries.images/attachment/%3C559331b6%40news.povray.org%3E/splotches-36.jpg?ttop=443824&toff=1200&preview=1)
Preview of image 'splotches-37.jpg'
![splotches-37.jpg](/povray.binaries.images/attachment/%3C559331b6%40news.povray.org%3E/splotches-37.jpg?ttop=443824&toff=1200&preview=1)
Preview of image 'splotches-37norad.jpg'
![splotches-37norad.jpg](/povray.binaries.images/attachment/%3C559331b6%40news.povray.org%3E/splotches-37norad.jpg?ttop=443824&toff=1200&preview=1)
Preview of image 'splotches-371.jpg'
![splotches-371.jpg](/povray.binaries.images/attachment/%3C559331b6%40news.povray.org%3E/splotches-371.jpg?ttop=443824&toff=1200&preview=1)
Preview of image 'splotches-371ng2.jpg'
![splotches-371ng2.jpg](/povray.binaries.images/attachment/%3C559331b6%40news.povray.org%3E/splotches-371ng2.jpg?ttop=443824&toff=1200&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 01.07.2015 um 02:18 schrieb Cousin Ricky:
>> branch at GitHub.
I guess you're refering to this page:
https://github.com/POV-Ray/povray/commit/d1bb614
Those are the changes that comprise the fix. Such a bunch of changes is
called a "commit".
(A "commit" is also sometimes used in the sense of a particular version
of the entire source code. Not surprisingly, in this sense it refers to
the source code as it was right after the change was submitted.)
To get the most recent version of the entire source code via the GitHub
web interface, go to https://github.com/POV-Ray/povray, and click on the
"Download ZIP" button at the right margin. (To be precise, that'll give
you the most recent version of the "master" branch.)
You can also retrieve the source code via the "git" Unix command line
tool, but you have to know how (which I don't - not off the top of my
head anyway; IIRC Jim Holsenback had posted some standard recipe a while
ago, but from my experience it can be a bit more difficult than that at
times).
With "complete alpha release" you're presumably refering to the releases
at https://github.com/c-lipka/povray/releases.
Actually, if there is any such thing as an "alpha release" of POV-Ray,
then /any/ update to the "master" branch of the repository constitutes
such a release.
The stuff made available on https://github.com/c-lipka/povray/releases
is just semi-official builds of snapshots from the official repository,
provided as a courtesy to Windows users interested in test-driving the
latest and greatest stuff, who can't just pull the source code and build
their own binaries. The fact that these are labeled as "releases" is
entirely technical, just like the fact that they are accompanied by
source code packages. It just so happens that GitHub's "release"
mechanism is the most convenient way to distribute the binaries. (Also
note that those semi-official builds don't live in the official
repository, but in a clone on my personal GitHub account.)
> remains.
I'm quite surprised to hear that. I recommend to try and build again
from a full snapshot of alpha.8150025, and see what that does.
Did you experiment with the "noise_generator" workaround?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes I did. The (satisfactory) result is splotches-371ng2.jpg of my
previous post.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
