![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This would be a first view of the Ring 'mountains'. I guess they are
composed of fine material temporarily swept out of their stable orbit by
an invisible shepherd moon. As yet I have not found any scientific
explication on the net. Filled with media they look better but cast no
shadows; with a simple pigment the shadows show imperfections
(supposedly epsilon value limits again).
All dimensions to scale, viewed from an altitude of 5km. Real dimensions
scaled down a thousand times. Yadgar's skysphere in the background and
the usual Tethys and Titan moons.
Download 'complex.png' (115 KB)
Preview of image 'complex.png'
![complex.png](/povray.binaries.images/attachment/%3C54ba851d%40news.povray.org%3E/complex.png?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Somehow, this looks more like the real thing...
From photographs, it is as if the perturbation takes the shape of a
helicoidal flow of the ring material...
Download 'complex.jpg' (33 KB)
Preview of image 'complex.jpg'
![complex.jpg](/povray.binaries.images/attachment/%3C54bcf226%40news.povray.org%3E/complex.jpg?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A number of corrections further and some thoughts more.
I have reduced the thickness exaggeration of the ring to 100m instead of
10m or less in reality. This is as far as I can go without breaking up
the render, in particular the media. Accordingly, I have reduced the
sizes of individual ring particles. Saturn reflects on the shadow sides
of the particles.
The A ring is there beyond the Cassini division (not filled in yet) but
is invisible as it is seen on the edge which is also in the shadow.
I am still not sure yet how I am going to fill-in the complex
"propeller" features reaching up to 2.5 to 3km above the ring surface. I
have more of those to build as patches towards the rim, and then we'll see.
Altitude of the camera: 5km above the ring.
Download 'complex_06.png' (503 KB)
Preview of image 'complex_06.png'
![complex_06.png](/povray.binaries.images/attachment/%3C54bfc062%40news.povray.org%3E/complex_06.png?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Slow progress, still progress.
Additional rings (A ring beyond the Cassini Division to the right; C
ring and D ring to the left); a wave density in the media to enhance the
ring feature.
I have to see about the ring colours...
Download 'complex_07.png' (669 KB)
Preview of image 'complex_07.png'
![complex_07.png](/povray.binaries.images/attachment/%3C54c2398a%40news.povray.org%3E/complex_07.png?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Saturn Ring - Second wip / POV version 3.71
Date: 24 Jan 2015 10:40:30
Message: <54c3bcee@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For different reasons, I have decided to use different ring thicknesses
according to the views. Overviews - like this one - uses thicker rings
than close ups. This implies also different ring parameters.
Here, the ring structure is conspicuously determined by the method 3
scattering media with a wave density pattern. This last also uses a
density map with real colours taken from a ring photograph. They are
much subdued here, I guess because the ring particles are of a uniform
texture ans should also bear the same pigment map pattern. Something I
need to test.
My first image using alpha version 3.71, incorporating the new
brilliance code in radiosity and in finish. However, settings are
conservative so nothing really different is visible at present.
I wanted to test the non-linear gradients but was unable to make it
work. From Clipka's note I assumed it should be added to the color or
pigment map blocks but that gives an error, as also added to the pigment
block. I need some guidance here.
Download 'complex.png' (992 KB)
![complex.png](/povray.binaries.images/attachment/%3C54c3bcee%40news.povray.org%3E/complex.png?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 24.01.2015 um 16:40 schrieb Thomas de Groot:
Usage should be like this (as an example):
gradient -x translate x*0.75 scale 2
pigment_map {
blend_mode MODE
blend_gamma GAMMA
[0.333 color srgb <1,0,1>]
[0.667 color srgb <1,1,1>]
Similar syntax should be used for colour_map.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 25 Jan 2015 03:31:10
Message: <54c4a9ce$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
OK Thanks. I shall try that too. Otherwise, no problems up till now.
Changing the backslash to forward slash was pending for my files for a
long time, so the opportunity was timely :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Saturn Ring - Second wip problem
Date: 27 Jan 2015 03:48:35
Message: <54c750e3@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have a problem showing up in the close up view of the ring.
-The upper half of the image shows the ring's isosurfaces with the media.
- The lower half shows the same but without the media.
In the upper half the isosurfaces are cut off in the area closest to the
camera.
Any idea?
Download 'complex_.png' (544 KB)
Preview of image 'complex_.png'
![complex_.png](/povray.binaries.images/attachment/%3C54c750e3%40news.povray.org%3E/complex_.png?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Once you have got these rings worked out to you satisfaction. You could
try modelling this ring system. ;-)
http://www.bbc.co.uk/news/science-environment-31001936
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Indeed. Could give interesting views.
But first our own neighbourhood :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
