POV-Ray : Newsgroups : povray.binaries.images : Meet the Major [wip] Server Time
25 Jun 2026 15:40:49 EDT (-0400)
  Meet the Major [wip] (Message 12 to 21 of 21)
Subject: Re: Meet the Major [wip]
Date: 10 Nov 2014 10:10:30
Message: <5460d566$1@news.povray.org>
On 10-11-2014 15:34, Cousin Ricky wrote:
> His arms look too short.  Are they foreshortened?  If so, they don't look so.
Standard arms. Standard figure. Must be illusion :-)
Date: 10 Nov 2014 13:50:01
Message: <web.5461085028465dec7b7e0b710@news.povray.org>
A very nice start. Maybe it is easier to place the ladders in the background a
little bit closer to the camera. That would not change the image very much but
could spare additional rendering time.
Best regards,
Michael
Date: 10 Nov 2014 15:13:07
Message: <54611c53$1@news.povray.org>
I have been thinking that if one of the light sources was moved so that
the ladder's shadows fell onto the mist. It might look like a "glory".
Regards
Date: 10 Nov 2014 18:40:00
Message: <web.54614c9128465deca47478650@news.povray.org>
> For the time being, a stand-in. Missing rungs is a render issue. This is
> improved with stochastic rendering, although render time is much
> increased. I still have to experiment for the best balance.
Do you still get the same issue with focal blur?
> The ground texture itself will not really be changed. It is supposed to
> be related to so-called 'patterned grounds' in periglacial areas.
> However, I have now added rocks etc. Maybe more is needed...
Indeed, having googled periglacial I see that something I think does not look
natural is in fact a very natural phenomenon. If anything compared to the images
I have just seen your texture is not uniform enough but I realise this is not a
work aiming at realism.
I look forward to seeing the next post and being educated further ;-)
Sean
Date: 11 Nov 2014 03:08:10
Message: <5461c3ea@news.povray.org>
Interesting isn't? The natural world is full of surprises. My first try
out was more uniform but I did not like that too much so I introduced a
bit of turbulence. I have added rocks randomly but I realise now that I
need to relate them more to the pattern (evalpig is your friend).
I shall endeavour to do that :-)
Date: 11 Nov 2014 03:11:11
Message: <5461c49f$1@news.povray.org>
>> background a
>> much but
Yes, I can try that indeed. Not that the ladders slow down the render
that much by the way.
The ladders are enclosed into the mist but I am afraid they are too thin
to really make a glory.
Date: 11 Nov 2014 03:14:51
Message: <5461c57b$1@news.povray.org>
This is something I have not tried yet. I expect the issue to disappear
indeed. I would prefer stochastic render in the end but I found that I
first need to wait for the next Uberpov version addressing the problem I
had with Silentium.
Date: 11 Nov 2014 19:21:39
Message: <5462a813@news.povray.org>
> had with Silentium.
> Thomas
Another option would be to make the runs thicker. That way, they will
have more chances of showing. The trick here is to find a sweet spot
where it's large enough that they are not missed but still thin enough
so that they don't look bloated.
Date: 11 Nov 2014 23:25:00
Message: <web.5462e0f628465dec192ae5f10@news.povray.org>
> > had with Silentium.
> > Thomas
Or, if it doesn't take too much time, render an oversized image, then shrink it
down.
Date: 12 Nov 2014 03:15:00
Message: <54631704@news.povray.org>
> down.
Both suggestions are good to follow up although I slightly do prefer the
second one. It may be that I can go forward with Uberpov as I have
changed some of the textures that were offensive to it. I need to check
again. Stochastic aa remains the best solution by far.
