![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thomas de Groot <tho### [at] degroot org> wrote:
> Most work to date went into the character of the Major, first creating
> the person himself according to the sources, then modelling the dynamic
> clothes based on conforming ones, and the other attributes (pith helmet
> and bag). A lot remains to be done in scene building textures etc. The
> present scene has two light sources as suns.
> At this stage, comments are welcome.
His arms look too short. Are they foreshortened? If so, they don't look so.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Standard arms. Standard figure. Must be illusion :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A very nice start. Maybe it is easier to place the ladders in the background a
little bit closer to the camera. That would not change the image very much but
could spare additional rendering time.
Best regards,
Michael
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have been thinking that if one of the light sources was moved so that
the ladder's shadows fell onto the mist. It might look like a "glory".
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> For the time being, a stand-in. Missing rungs is a render issue. This is
> improved with stochastic rendering, although render time is much
> increased. I still have to experiment for the best balance.
Do you still get the same issue with focal blur?
> The ground texture itself will not really be changed. It is supposed to
> be related to so-called 'patterned grounds' in periglacial areas.
> However, I have now added rocks etc. Maybe more is needed...
Indeed, having googled periglacial I see that something I think does not look
natural is in fact a very natural phenomenon. If anything compared to the images
I have just seen your texture is not uniform enough but I realise this is not a
work aiming at realism.
I look forward to seeing the next post and being educated further ;-)
Sean
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Interesting isn't? The natural world is full of surprises. My first try
out was more uniform but I did not like that too much so I introduced a
bit of turbulence. I have added rocks randomly but I realise now that I
need to relate them more to the pattern (evalpig is your friend).
I shall endeavour to do that :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> background a
>> much but
Yes, I can try that indeed. Not that the ladders slow down the render
that much by the way.
The ladders are enclosed into the mist but I am afraid they are too thin
to really make a glory.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is something I have not tried yet. I expect the issue to disappear
indeed. I would prefer stochastic render in the end but I found that I
first need to wait for the next Uberpov version addressing the problem I
had with Silentium.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> had with Silentium.
> Thomas
Another option would be to make the runs thicker. That way, they will
have more chances of showing. The trick here is to find a sweet spot
where it's large enough that they are not missed but still thin enough
so that they don't look bloated.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > had with Silentium.
> > Thomas
Or, if it doesn't take too much time, render an oversized image, then shrink it
down.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
