POV-Ray : Newsgroups : povray.binaries.images : WIP: mermaid (nsfw) Server Time
27 May 2026 16:12:33 EDT (-0400)
  WIP: mermaid (nsfw) (Message 11 to 20 of 46)
Subject: Re: WIP: mermaid (nsfw)
Date: 6 Oct 2014 19:21:16
Message: <543323ec@news.povray.org>
Am 06.10.2014 22:02, schrieb Tim Cook:
> Further progress on my mermaid mesh, dubbed off a copy and rearranged it
> some to be posed to show what it could end up being able to do.
Desktopped!
Say, could you perhaps do me a favor and - for the sake of perfecting
the perfect - do a wider (1920x1200) render of this scene, with
dithering enabled (+th)?
Date: 6 Oct 2014 22:26:58
Message: <54334f72$1@news.povray.org>
> Tim Cook
> http://empyrean.sjcook.com
Ah! You're headed in a very nice direction - I like this.
Bill P.
Date: 6 Oct 2014 22:30:38
Message: <5433504e$1@news.povray.org>
On 2014-10-06 17:53, andrel wrote:
> My problem with the current placing is that as far as I know there is no
> muscle there that could move the fin. Somewhat higher up one might use a
> modified abdominal muscle.
> I think if you make a vertebrate it should conform to the body plan of
> vertebrates or at least be physiological plausible. That is why I am a
> fan of Terryl Whitlatch (and not only because of the extra 'l' at the
> end of her first name).
Structure of this mermaid is directly based on my own dolphin-tailed
mermaid designs (which are more analogous to a centaur, having a two
sets of forelimbs and an extended spine).  The placement of the
nearly-vestigal dorsal fin corresponds roughly to that of a dolphin,
while the 'pectoral fins' are morphologically analogous to replacing the
legs of a human at the acetabulum of the pelvis with a dolphin's forelimbs.
references:
http://empyrean.deviantart.com/art/Mermaid-skeleton-105128891
http://empyrean.deviantart.com/art/Mermaid-musculature-136764629
http://empyrean.deviantart.com/art/Mermaid-anatomy-455530950
I had moved the 'pectoral fins' upwards from these drawings so they'd be
a little better-balanced, visually (would work by rotating the 'femur'
upwards, keeping its joints intact, just shifting where the limb exits
the thigh), and made other minor changes as I went, but am trying to
keep to my musculature layout.
Date: 7 Oct 2014 02:22:42
Message: <543386b2@news.povray.org>
Alas, I was fiddling around with lighting and media and so couldn't make
a widescreen render of the previous image, I'm afraid you'll have to
settle for this one (I found a better image for the background, also).
Tim Cook
Download '2014-10-06 mermaid.png' (986 KB)
Preview of image '2014-10-06 mermaid.png'
Date: 7 Oct 2014 02:26:43
Message: <54338791.6020004@gmail.com>
> references:
We do have a few mermaid skeletons in the Vrolik museum.
some are described her, but there may be better sources.
http://thechirurgeonsapprentice.com/2014/09/09/disturbing-disorders-sirenomelia-mermaid-syndrome/
The artist here took a different approach.
Of course you are free to create your own creature but this would not
work anatomically. I you want to have fins that are homologous to the
legs they have to be below the pelvis, otherwise the hip joint won't
work. Nor do I see a reason why they would not work if placed lower.
Hence evolutionary it would also not make sense. IMHO
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
Date: 7 Oct 2014 08:29:17
Message: <5433dc9d@news.povray.org>
Am 07.10.2014 08:22, schrieb Tim Cook:
Alas indeed! For when it comes to desktop background, I do prefer the
simpler previous version.
Date: 7 Oct 2014 12:25:00
Message: <web.5434135ff06154d05e7df57c0@news.povray.org>
>>  The tail indicates that this is definitely not a fish, but a landanimal
readapted to the seas.
Going with the "vestigial dorsal fin" - maybe a modified coccyx, that looks a
bit better in my head - if the plan isn't to use spined vertebrae as a support
for the fin-skin (tm), then maybe just slightly extend the taper of the fin up
the back a bit?
Obviously Tim has his vision for what she is, and I'm no expert in
mer-physiology.
I must confess that I don't quite get what that explanation means - but that's
ok.
IIRC, horses have a way to lock their knees when they sleep - maybe the same
musculature would tie into the leg-fins.
Along the lines of her being an adapted land animal, perhaps it could be
interesting to add a bit more of a suggestive element to show the modified
skeletal structure.  Femurs tapering into long, thin tibias, and the foot bones
composing the tail-fin like the fingers bones compose the wings of a bat, with
the tail being the webbing.
Add a flatness or convexity between the femurs to hint at the origin from two
separate legs, or backlight and add some translucency to the flesh.
>> Another mild criticism is that she will be the last of the line.
Well, I suppose that could either be fleshed-out (pun intended) or perhaps there
is some visually well-hidden fold or other covering.
Aaaaanyway - just my mental wanderings on it.  You've certainly done a great job
getting her modeled and posing her in a nice looking scene.  Looking forward to
seeing where your imagination leads her!
Date: 7 Oct 2014 15:11:52
Message: <54343af8$1@news.povray.org>
It is a kelpie, for crying out loud. ;-)
It doesn't follow the rules of the blind watchmaker.
The next thing will be people saying that leprechauns wear green.
Regards
Date: 7 Oct 2014 15:30:01
Message: <web.54343e6cf06154d05e7df57c0@news.povray.org>
So true.  With all that gold, they most likely wear Armani.
Date: 7 Oct 2014 17:22:44
Message: <543459a4$1@news.povray.org>
Red, It was Mr. Disney or his ilk that made them wear green. ;-)
Regards
