Thomas de Groot <tho### [at] degroot org> wrote:
> That back bending is simply unrealistic. Just changing the bending
> direction already improves things. What I did was add 180 degrees to all
> negative rotations.
> Thanks for all the suggestions.
> @ Bald Eagle: I do indeed use the image_map as a kind of force map,
> through the height_field stage and then using the properties of the
> normals. Basically, I think that is identical to what you suggest? The
> rate of bending is proportional to the normal: pointing upward => no
> bending; increased bending with increasing normal angle towards the
> horizontal.
> @ MichaelJF: Yes, that parting was killing the effect and came from my
> concept of rebounding of the stalks. In any case, this was far to strong
> here. I presently dropped this effect for the time being.
> @ clipka: the bending angle is uniform over the whole length as a first
> approximation. In reality, I expect bending to increase towards the top,
> due to the different effects already mentioned by Alain and Bald Eagle.
> Most important in my view are the thickness/rigidity of the stalks
> towards the base and the damping effect of surrounding stalks. The
> former is easy to implement, the latter is more difficult, especially if
> one also wants to consider collision effects. At present, I do not know
> how to tread that path.
> Something I still believe not right is the wave length of the effect. I
> think it should be larger.
> Also note in the present image that all stalks start from the same
> initial orientation/scale. I need to introduce more randomness /and/ add
> different types of stalks.
> Thomas
Looks very much better in my eyes. In fact I'm working on a somewhat similiar
issue at the moment. That is why I came up with suggestions to control the
bending and length of the straws depending on the position (and the normal
provided by the trace()-command). I'm trying to give a certain model a special
hair-style. (Stephen will recognize the source of my inspiration most likely.) I
admit, there is room to improvement...
Best regards,
Michael
Download 'mudmaid_veryfirstwip.jpg' (11 KB)
Preview of image 'mudmaid_veryfirstwip.jpg'
Subject: Re: Proof of concept: The wind in the reeds
Date: 17 Sep 2014 19:42:36
Message: <541a1c6c$1@news.povray.org>
Hi(gh)!
On 17.09.2014 13:30, Thomas de Groot wrote:
> Thanks Paolo.
> As a bonus, this image with randomisation of scale and initial vertical
> rotation. Also, bending diminishes downwards.
> Thomas
And they do not intersect each other? That in fact would be stunning!
See you in Khyberspace!
Yadgar
Now playing: Hearts (Jon Anderson)
> Well, I am interested in modelling wind patterns over a reed field, or a
> corn field. What I seem to observe are turbulent wave patterns moving
> the stalks back and forward while going over the field.
> This is a first approximation. I am not really satisfied yet with the
> pattern. What I did is:
> 1) Make an image_map with a more or less turbulent ripple pattern.
> 2) Make a height_field based on that image_map.
> 3) Build a reed stalk with Inverse Kinematic properties (macro with Bend
> parameter).
> 4) Select random locations on the height_field;
> 4a) calculate the vertical angle between the normal at that location and
> a horizontal plane (using: VAngleD(V1,V2));
> 4b) calculate the horizontal angle between (arbitrarily) the +z-axis
> direction (direction of primary bending of the reed stalks) and the
> normal of the random location point (using: VRotationD(V1,V2,axis)).
> 5a) bend the stalk with a proportion of the vertical angle (4a);
> 5b) orient the bended stalk by rotating through the horizontal angle (4b);
> 5c) place the reed stalks at the random locations on a flat surface.
> The image shows 15000 reed stalks. About 4.5 minutes render time.
> suggestions are more than welcome of course.
> Thomas
Wow, like a painting.
What are the povray objects you use?
Date: 18 Sep 2014 03:25:57
Message: <541a8905@news.povray.org>
Ah yes, I can see the similarities indeed. Interesting hair model!
There is great potential in using the normal. In my case length control
does not make really sense, derived from the normal - except if I were
using /another/ image_map for controlling reed height in determined
areas; evalpig would be my friend in that case.
Date: 18 Sep 2014 03:28:40
Message: <541a89a8@news.povray.org>
Alas! There is no collision control available. However, intersections
are probably only visible to the really discerning eye ;-)
Date: 18 Sep 2014 03:34:11
Message: <541a8af3@news.povray.org>
Thanks. Mesh2 objects, modelled in Silo. This one still has a couple of
small issues that need correction. When finished, I shall upload
everything to p.b.s-f.
Hi Thomas,
This is looking really great, I pobably am missing some step but how exactly can
you bend a mesh2 object in pov?
Thanks
Sean
On 18-9-2014 10:08, s.day wrote:
> Hi Thomas,
I shall upload the model soon, when I have finished some corrections.
In the mean time, you need to build the model following inverse
kinematic principles. This means that the model subdivided in discrete
elements and articulated at their juncture, but not in a haphazardly
way. Here follows the construction of the reed stalk as I use it. You
can already study its inner workings:
#macro Reed(Bend)
//random rotation for the whole stalk:
#local Rot = RRand(-180, 180, R);
//construction of the Inverse kinematic stalk:
#local Bend1 = Bend+((2*Bend)/10);
#local Plume =
union {
object {ReedMesh_03_ik_Reed01_plume_ material{Reed01_plume_} hollow
translate -10.40*y rotate Rot*y rotate Bend1*x translate (10.40-10.18)*y }
object {ReedMesh_03_ik_Reed01_11_ material{Reed01_11_} hollow
translate -10.18*y rotate Rot*y}
#local Bend2 = Bend+(Bend/10);
#local Top =
union {
object {Plume rotate Bend2*x translate (10.18-9.86)*y}
object {ReedMesh_03_ik_Reed01_10_ material{Reed01_10_} hollow
translate -9.86*y rotate Rot*y}
#local Stem9 =
union {
object {Top rotate Bend*x translate (9.86-9.54)*y}
object{ReedMesh_03_ik_Reed01_9_ material{Reed01_9_} hollow translate
-9.54*y rotate Rot*y}
#local Bend = Bend-(Bend/20);
#local Stem8 =
union {
object {Stem9 rotate Bend*x translate (9.54-9.165)*y}
object{ReedMesh_03_ik_Reed01_8_ material{Reed01_8_} hollow translate
-9.165*y rotate Rot*y}
#local Stem7 =
union {
object {Stem8 rotate Bend*x translate (9.165-8.79)*y}
object{ReedMesh_03_ik_Reed01_7_ material{Reed01_7_} hollow translate
-8.79*y rotate Rot*y}
#local Stem6 =
union {
object {Stem7 rotate Bend*x translate (8.79-7.72)*y}
object{ReedMesh_03_ik_Reed01_6_ material{Reed01_6_} hollow translate
-7.72*y rotate Rot*y}
#local Stem5 =
union {
object {Stem6 rotate Bend*x translate (7.72-6.20)*y}
object{ReedMesh_03_ik_Reed01_5_ material{Reed01_5_} hollow translate
-6.20*y rotate Rot*y}
#local Stem4 =
union {
object {Stem5 rotate Bend*x translate (6.20-4.65)*y}
object{ReedMesh_03_ik_Reed01_4_ material{Reed01_4_} hollow translate
-4.65*y rotate Rot*y}
#local Stem3 =
union {
object {Stem4 rotate Bend*x translate (4.65-3.10)*y}
object{ReedMesh_03_ik_Reed01_3_ material{Reed01_3_} hollow translate
-3.10*y rotate Rot*y}
#local Stem2 =
union {
object {Stem3 rotate Bend*x translate (3.10-1.55)*y}
object{ReedMesh_03_ik_Reed01_2_ material{Reed01_2_} hollow translate
-1.55*y rotate Rot*y}
#declare ReedMesh_03 =
union {
object {Stem2 rotate Bend*x translate 1.55*y}
object{ReedMesh_03_ik_Reed01_1_ material{Reed01_1_} hollow rotate Rot*y}
#end //macro
As you can see, the construction starts at the top of the stalk and
gradually incorporates adjacent elements until the base is reached. Note
that /only/ rotations can be used as transformations inside the IK
model. All other transformations must be applied to the /complete/ model
or not at all. Note also that /all/ internal rotations of the model are
applied *at the origin*.
Thanks Thomas,
I hadn't thought about having separate sections, I thought you were somehow
bending the acutal mesh (doh!).
Sean
Date: 19 Sep 2014 08:19:18
Message: <541c1f46@news.povray.org>
I have attached my code and the used reed stalk, in p.b.s-f.
Explore and enjoy!
Download 'wind_pattern.png' (662 KB)
Preview of image 'wind_pattern.png'
