![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A render of this scene with "+w512 +h256 +am3 +a0.2 +ac0.8 +r1" shows
definite non-random patterns in the output every time - the red circles
are post-processing ;-) You can change a lot of the numbers in the code
and command-line a little bit and still get the same patterns.
Is this a bug/feature of the random number generator algorithm?
#version 3.7
global_settings{radiosity{no_cache count 2}}
sky_sphere { pigment { gradient y
color_map{[.5 color rgb 2][1 color rgb 0]}
scale 2 translate -1 }
rotate x*30 rotate y*45 emission 2 }
plane{y 0 pigment{color rgb 1} finish{diffuse 0.3}}
angle 40
location <0,3,6> look_at <0,1,0>
Download 'noise.png' (100 KB)
Preview of image 'noise.png'
![noise.png](/povray.binaries.images/attachment/%3C53eb0eb5%241%40news.povray.org%3E/noise.png?ttop=443824&toff=1350&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Here is the difference between two renders of the scene a few minutes
apart. It seems some blocks always get given the exact same seed for the
RNG.
Download 'diff.png' (121 KB)
Preview of image 'diff.png'
![diff.png](/povray.binaries.images/attachment/%3C53fef2b9%40news.povray.org%3E/diff.png?ttop=443824&toff=1350&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 28.08.2014 11:13, schrieb scott:
> RNG.
Did you use the Windows version? If so, did you start the renders from
the same instance of the GUI?
I suspect that I'm only computing the base seed when POV-Ray is started,
erroneously using it over and over again during the entire session.
The difference between many of the blocks would then be solely due to
different assignment of render blocks to threads (because of different
thread scheduling), and using "+WT1" you should indeed see no
differences at all.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> RNG.
That can be aleviated by not reinitialising the random stream but
continuing using it from where it was at the end of the previous render.
That way, the last used value effectively becomes the seed of the next
render.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 28.08.2014 22:36, schrieb Alain:
>>> RNG.
> render.
Theoretically yes, but in practice no - each render thread needs its own
stochastic RNG instance, and the render threads only live as long as it
takes to render an individual image.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> RNG.
Yes and yes.
It seems like it.
> differences at all.
The new version you just uploaded works as expected now, thanks! I find
that after a long render if I'm still not happy with the level of noise
I can run it again and average the results - which will work now :-)
BTW I had the same issue when I first started using multi-instances of
mcpov, it uses the number of seconds as the seed by default, so if you
start 12 instances simultaneously they all render exactly the same result.
From a programming point of view, wouldn't it better to use
milli/micro/nano seconds or ticks to give more chance of avoiding
creating repeatable RNG streams?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 29.08.2014 09:16, schrieb scott:
>>> RNG.
> Yes and yes.
> It seems like it.
>> differences at all.
IIRC mcpov also had some command-line or SDL option to choose a custom seed.
Unfortunately, functions that provide this information tend to (A) not
be portable, or (B) have an unknown granularity, possibly only
increasing the value every second as well.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
