On 10/08/2014 15:00, Thomas de Groot wrote:
> I believe I have a nice compromise now. I added a screen, simulating a
> skylight in the upper wall of the staircase. With a bit of emission.
To me that is much better, I can see the cat now. ;-)
IMO these images with deep shadows and bright sunlight need a compromise
as our eyes adjust in RL. But cannot do that on an image.
Don't you think that there should be some dust in the air?
Regards
Those are a couple of interesting ideas... I'll shelf them for the time
being to let the brain cells time to adjust :-)
Yes, and the compromising is delicate as the notion of 'acceptable'
tends to vary from person to person in this case. In the present case a
bit lighter or darker would also be possible. ;-)
Some dust. Yes indeed. Totally forgot that.
Some images are never finished. There are a lot of things I could still
tweak, add, move, etc in this one :-)
It is IMO a tricky shot to call but I think that you have got it right
with this one.
You might be house proud I am not. :-)
That is so true.
Regards
Am 14.08.2014 09:25, schrieb Thomas de Groot:
Not only does the notion of "acceptable" vary from person to person, but
-- I guess even more importantly -- it also varies from display to
display. Experience in these newsgroups has shown over and over again
that people complaining about images being too dark tend to change their
mind once they have been coaxed to calibrate their display properly.
Nonsense. They just need to increase/decrease the number and density of
rods/cones in their eyes.
Old CRT I had before.. something must have overloaded the damn caps in
it, or something, at some point. It was so dark that even if you turned
up the gamma in games, or the like, it was still "darker" than it should
be. Never realized it was that bad, at all, until I decided to go with a
whole new system, with wide screen LCD, then.. Holy... lol
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
LOL
A nice trick if you can do it. :-)
Regards
Am 15.08.2014 22:33, schrieb jhu:
That actually wouldn't do the trick. Turning off any other light sources
in the room might though, if the problem is reflection glare.
For wearers of corrective eyegear like me, cleaning the glasses from
time to time might also help ;-)
(And yes, dusting off the display may also helpful.)
+1
Top tips :-)
Regards
