Tim Cook <z99### [at] gmail com> wrote:
> And here's a sized-down version of the current version of the map.
> Turns out an 8192x8192 image isn't something my computer is particularly
> happy about being asked to work with, with multiple layers (even vector)
> in an image editor.
Looks good. Red lines are paved roads, yes?
Is it worth trying to convert this to a vector format, svg or something? This
type of graphic cries out to be in a non-bitmap form.
Bill
Thicker ones, yes. Started adding a few secondary unpaved roads; 7000
Steps up to High Hrothgar in particular was missing in the map mod I
had, so I had to compile and use the UESP wiki's map (which is much
better reference).
Ah yeah, svg might be a better format to use than psp. I don't want to
hand-trace and optimize all the contour lines, though. :( The
coastline and waterways stage is going to be enough of a nuisance. Any
program that can do that for me?
It would massively reduce the file size.
Also note: the image should be able to be chopped up and converted into
.dds files and used as the in-game map, at this point. There's a bit of
distortion due to my initial rendering of the height map from Moray,
which doesn't have the orthographic camera type, but it should be minor.
Tim Cook
http://empyrean.sjcook.com
