POV-Ray : Newsgroups : povray.binaries.images : First attempts at blurred reflection... Server Time
30 Sep 2024 01:17:13 EDT (-0400)
  First attempts at blurred reflection... (Message 1 to 6 of 6)
Subject: First attempts at blurred reflection...
Date: 27 Nov 2011 20:05:24
Message: <4ed2de54@news.povray.org>
High!
As I want to have floor tiles with slightly disturbed reflection in my
Port Whatmough villa, I started to play around with the blurred
reflection hack described here:
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_13
Slightly disturbed reflection works quite well (see my test table
below), but I wonder how to achieve that strong, smooth blur I've seen
in so many scenes during the last years - using a large scaling factor
for the normal (e. g. 1000) yields weird results with high turbulence
values, while using small scaling factors like 0.001 gives something
remotely resembling my notion of blurred reflection, albeit still quite
grainy.
Should I try an even smaller scaling factor (0.0001 or so) and/or using
stronger anti-aliasing?
See you in Khyberspace!
Yadgar
Download '2011-11-27 die, takes 12 to 61 - blurred reflection test.png' (2702 KB)
Preview of image '2011-11-27 die, takes 12 to 61 - blurred reflection test.png'
Subject: Re: First attempts at blurred reflection...
Date: 27 Nov 2011 22:05:14
Message: <4ed2fa6a@news.povray.org>
> grainy.
It looks to me like you're using just one single bumpy texture, rather
than multiple ones - or you've forgot to translate each of them
randomly; you need either multiple layers (e.g. 40 as in the example),
or - my personal preference - some slight but high-quality focal blur
for good oversampling (anti-aliasing doesn't quite cut it), in which
case a single small-scale bumpy texture will suffice.
Date: 28 Nov 2011 08:10:54
Message: <4ed3885e$1@news.povray.org>
Hi(gh)!
In fact I did so... here's the code:
#declare N_Blurred =
normal
   bumps pow(10, div(clock, 5)-2)
   turbulence pow(10, mod(clock, 5))
#declare F_Metallic =
finish
   diffuse 1
   brilliance 0.7
   specular 1
   roughness 0.001
   reflection 0.5
   metallic
#declare T_Blurred_Gold =
texture
   average
   texture_map
     #while (i<40)
       #declare rn=seed(0);
       [1  pigment { color rgb <0.8, 0.75, 0> }
           finish { F_Metallic }
           normal { N_Blurred translate <rand(rn),rand(rn),rand(rn)>*100
scale 0.001  } ]
       #declare i=i+1;
// end of code
Yadgar
Date: 28 Nov 2011 10:19:11
Message: <4ed3a66f$1@news.povray.org>
> Hi(gh)!
> texture
> average
> texture_map
> #while (i<40)
Heh! You're seeding the random number generator inside the loop, giving
you the very same sequence of "random" numbers (and hence the same
translation vector) over and over again. Don't do that :-P
Date: 28 Nov 2011 17:23:20
Message: <4ed409d8@news.povray.org>
Hi(gh)!
Oh yes... it seems to be not a matter of stupidity, but of impatience!
Here's the correct table!
Yadgar
Download '2011-11-28 die, takes 62 to 111 - blurred reflection test.png' (2740 KB)
Preview of image '2011-11-28 die, takes 62 to 111 - blurred reflection test.png'
Date: 28 Nov 2011 18:31:06
Message: <4ed419ba$1@news.povray.org>
Yup, looks more like it :-)
As you may notice, turbulence doesn't add anything useful to it; neither
does a bump value of >> 1. The latter is because it causes lots of rays
to get reflected "into" the geometric object, which doesn't make sense,
so POV-Ray's algorithm replaces them with rays reflected according to
the unpertubed normal instead.
