POV-Ray : Newsgroups : povray.binaries.images : Susanna sans the elders Server Time
16 Mar 2026 09:48:38 EDT (-0400)
  Susanna sans the elders (Message 1 to 9 of 9)
Subject: Susanna sans the elders
Date: 14 Mar 2011 14:44:42
Message: <4d7e621a@news.povray.org>
A quick test (ha! 4 hours) to see how SSLT handles an open mesh.
There are 2 meshes in a union with the texture applied to the union.
Regards
Download 'cloak02a1y1_.jpg' (304 KB)
Preview of image 'cloak02a1y1_.jpg'
Subject: Re: Susanna sans the elders
Date: 14 Mar 2011 15:11:45
Message: <4d7e6871$1@news.povray.org>
Am 14.03.2011 19:44, schrieb Stephen:
SSLT may work sufficiently good with open meshes in /some/ cases, but I
don't expect this to be the case in every situation (for instance I
expect it to break down for illumination from the back).
Date: 14 Mar 2011 15:15:44
Message: <4d7e6960$1@news.povray.org>
OK I'll try that and see what happens.
An overnight render as I posted a 7 hour rendered image without changing
the text.
PS will inside vector affect it? It is pointing up ATM.
Regards
Date: 14 Mar 2011 15:32:38
Message: <4d7e6d56$1@news.povray.org>
Am 14.03.2011 20:15, schrieb Stephen:
No, the SSLT code does not test for insideness (except where required
for intersection testing, i.e. with intersections or differences).
Date: 14 Mar 2011 15:46:10
Message: <4d7e7082@news.povray.org>
OK, remember this is R3. With two spotlights in a light group it seems
much faster rendering.
Regards
Date: 15 Mar 2011 05:40:47
Message: <4d7f341f@news.povray.org>
As expected the backlight spotlights shine through and lighten the
model. I attach the image for comparison.
BTW Differencing the JPGs shows a blocky-ness around the outline that
the PNGs do not have.
Regards
Download 'cloak02a1y1a_.jpg' (304 KB)
Preview of image 'cloak02a1y1a_.jpg'
Date: 15 Mar 2011 05:58:33
Message: <4d7f3849$1@news.povray.org>
Am 15.03.2011 10:40, schrieb Stephen:
No surprise there. Block artifacts - however subtle - are a virtually
inevitable feature of the lossy JPG compression.
Date: 17 Mar 2011 12:48:37
Message: <4d823b65$1@news.povray.org>
Btw, I'm wondering if SSLT could be used for something else than
making objects look like made of wax. (Ok, you could argue that this
object could be made of plastic. Not a very large difference, though.)
Date: 17 Mar 2011 14:23:59
Message: <4d8251bf$1@news.povray.org>
On 17/03/2011 4:48 PM, Warp wrote:
> Btw, I'm wondering if SSLT could be used for something else than making
> objects look like made of wax. (Ok, you could argue that this object
You have a point.
 From what I've read about the next release it should be easier to make
a different look.
And quicker to render, change, render...
Regards
