High!
Meanwhile, I got some raw version of the vegetation texture for southern
Tasmania (just a heightfield exercise in between, don't worry, I'll
switch back to Khyberspace as soon as possible!) ready... it consists of
a texture_map containing five texture_maps, each of them again is a
slope pattern containing two or three basic textures:
// Basic textures
#declare T_Beach=
texture
pigment { color rgb <1, 1, 0.5> }
finish { ambient 0.05 diffuse 1 brilliance 0.25 }
#declare T_Meadow=
texture
pigment { color rgb <0.1, 0.7, 0.2> }
finish { ambient 0.05 diffuse 1 brilliance 0.5 }
#declare T_Forest=
texture
pigment { color rgb <0, 0.5, 0.2> }
finish { ambient 0.05 diffuse 1 brilliance 0.42 }
#declare T_Shrub=
texture
pigment { color rgb <0.65, 0.78, 0.2> }
finish { ambient 0.05 diffuse 1 brilliance 0.31 }
#declare T_Rock=
texture
pigment { color rgb 0.7 }
#declare T_Snow=
texture
pigment { color rgb 1 }
finish { ambient 0.05 diffuse 1 brilliance 0.18 }
// Slope-patterned texture_maps
#declare TM_Shore=
texture
slope { <0, -1, 0> }
texture_map
[0 T_Beach ]
[0.2 T_Beach ]
[0.2 T_Forest ]
[0.4 T_Forest ]
[0.4 T_Rock ]
[0.5 T_Rock ]
#declare TM_Lowlands=
texture
texture_map
[0 T_Meadow ]
[0.06 T_Meadow ]
[0.065 T_Forest ]
[0.4 T_Forest ]
[0.4 T_Rock ]
[0.5 T_Rock ]
#declare TM_Highlands=
texture
texture_map
[0 T_Forest ]
[0.4 T_Forest ]
[0.4 T_Rock ]
[0.5 T_Rock ]
#declare TM_SubAlpine=
texture
texture_map
[0 T_Shrub ]
[0.4 T_Shrub ]
[0.4 T_Rock ]
[0.5 T_Rock ]
#declare TM_Alpine=
texture
texture_map
[0 T_Snow ]
[0.4 T_Snow ]
[0.4 T_Rock ]
[0.5 T_Rock ]
// Overall texture map
#declare h=max_extent(terrain).y-min_extent(terrain).y;
#declare TMM_Tasmania=
texture
gradient y
texture_map
[0 TM_Shore]
[h/2/h TM_Shore]
[(h+3)/2/h TM_Shore]
[(h+3)/2/h TM_Lowlands]
[(h+200)/2/h TM_Lowlands]
[(h+200)/2/h TM_Highlands]
[(h+900)/2/h TM_Highlands]
[(h+900)/2/h TM_SubAlpine]
[(h+1200)/2/h TM_SubAlpine]
[(h+1200)/2/h TM_Alpine]
[1 TM_Alpine]
scale 2*h
translate -y*h
I originally scaled the overall texture_map to double y extent of the
heightfield and than translated it along the y axis to have some scope
for turbulence (otherwise, TM_Alpine would show up along the shores).
Probably I'll redo this, as general turbulence for the whole texture
would yield undesirable results...
Note that with the scene attached below, TM_Alpine does not appear as
the mountains visible from the chosen camera position are not high enough.
But as TMM_Tasmania uses a y gradient without turbulence, the boundary
between TM_Highlands and TM_SubAlpine is unnaturally straight (see image
below) - while keeping a sharp boundary between forest and subalpine
shrub, I would like to have the boundary "patchy" at an intermediate
scale. When I apply a general turbulence to TMM_Tasmania, the constraint
of the "beach" part to the lowest and closest to the sea parts of the
heightfields is lost... and, otherwisely, separating the SubAlpine and
AlpineParts (with a third, transparent texture for the lower regions)
from TMM_Tasmania and superimposing it as a second texture layer won't
work either, as PoV-Ray generally is not able to layer mapped textures...
How do I get a more realistic upper forest line?
See you in Khyberspace!
Yadgar
Download '2010-12-15 southwestern tasmania, take 16.jpg' (36 KB)
Preview of image '2010-12-15 southwestern tasmania, take 16.jpg'
> High!
Low!
This is some project, Yadgar. How long have you been working on it?
Regards
High!
For about one week... nothing really huge, just to play around with
slope-dependent textures! Perhaps later on, I might add real trees and
other vegetation elements...
Yadgar
> High!
I thought it was part of your Khyberspace project which seems to have
ocupied you for years. (Or so it seems)
Regards
news:4d08a592@news.povray.org...
> High!
> // Basic textures
> #declare T_Beach=
> texture
> #declare T_Meadow=
> texture
> #declare T_Forest=
> texture
> #declare T_Shrub=
> texture
> #declare T_Rock=
> texture
> #declare T_Snow=
> texture
> #declare TM_Shore=
> texture
> texture_map
> [0 T_Beach ]
> [0.2 T_Beach ]
> [0.2 T_Forest ]
> [0.4 T_Forest ]
> [0.4 T_Rock ]
> [0.5 T_Rock ]
> texture
> texture_map
> [0 T_Meadow ]
> [0.06 T_Meadow ]
> [0.065 T_Forest ]
> [0.4 T_Forest ]
> [0.4 T_Rock ]
> [0.5 T_Rock ]
> texture
> texture_map
> [0 T_Forest ]
> [0.4 T_Forest ]
> [0.4 T_Rock ]
> [0.5 T_Rock ]
> texture
> texture_map
> [0 T_Shrub ]
> [0.4 T_Shrub ]
> [0.4 T_Rock ]
> [0.5 T_Rock ]
> #declare TM_Alpine=
> texture
> texture_map
> [0 T_Snow ]
> [0.4 T_Snow ]
> [0.4 T_Rock ]
> [0.5 T_Rock ]
> texture
> gradient y
> texture_map
> [0 TM_Shore]
> [h/2/h TM_Shore]
> [1 TM_Alpine]
> scale 2*h
> translate -y*h
> Yadgar
Hey, I live in southern Tasmania!!
I dont suppose you could tell me where you got the data for the heightfield?
I'm very interested in recreating the area around my house for starters :)
Then the whole island, that would be sweet!!!
Cheers Dre
High!
In Hobart?
Look here: http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/Australia/
These are data tiles from a Shuttle Radar Topography Mission (SRTM) in
February 2000, covering the entire land surface of the Earth between
of 3 arcseconds per data point. The name of each file indicates the
geographical coordinates of the *southwestern*, i. e. left lower corner
of the tile. So, you just look up the coordinate range of Tasmania in
your preferred atlas and find the respective tiles.
These tiles are NOT image files, but you can make them visible (and even
generate nice 3-D views, which export also to VRML) with a Windows
freeware called "3DEM". You find 3DEM here:
http://freegeographytools.com/3dem_setup.exe
With 3DEM, you can iron out error pixels (mostly resulting from cloud
cover) with the "Patch missing data" feature - but this works only for
error pixels which have no connection to the tile's edges!
To use them with PoV-Ray, you'll have to export the read-in data tile as
"ASCII terrain matrix". I wrote a POV script which generates a 16-bit
PNG heightfield from these ASCII files - attached here (ascii2png.pov)!
The ASCII files have the height data as number strings at two-digit
accuracy (xxxx.xx), each separated by a blank. PoV-Ray needs the blanks
to be replaced by commas to read the data in properly. If you have
access to Linux with its powerful UNIX console command line tools,
you're fine - just type in:
sed 's/ /,/g' original_file destination_file
and within two seconds, almost 1,5 million blanks are replaced by commas!
Unfortunately, I currently do not know of any Windows tool capable of
doing that job at a comparable speed - common GUI text editors, not to
mention full-fledged word processors toil for hours! But even if you
have no Linux on your computer, you can download a "Live CD" image of a
Debian distribution and burn it - afterwards you'll be able to boot a
proper Linux installation from the disk! If you face problems to write
data on your harddisk (because of missing rights), just try a USB stick
instead, it probably will work!
Note that the size of the data tiles is in fact 1201 by 1201 rather than
1200 x 1200, so adjacent rows and columns would repeat - if you want to
join two or more of your generated PNG heightfields, you'll first have
to remove the easternmost column and southernmost row.
And joining heightfields would be the only way to get rid of the error
pixels which, with the original tiles, lie at the edges. I also wrote a
POV script (png2ascii.pov) to re-export joined heightfields to an ASCII
terrain matrix readable by 3DEM - the software will ask you about the
size and corner coordinates and then you can smooth out the remaining
error pixels.
After exporting them back to ASCII (and, of course, once more replacing
blanks by comma) and finally to PNG, you'll have a faultless heightfield
of your desired area. Note that the creation of the PNG heightfields
required quite at lot of memory, as each "pixel" in fact is a small box
object rendered in an orthographic view without light_source but with
ambient 1 - to do 1200 x 1200 boxes, you should have at least 1.5 GB of RAM!
As the tiles are square degree tiles, the resulting cartographic
projection is cylindrical, so that only along the Equator, the
heightfields give a realistical representation of terrain, while towards
the poles, the terrain is increasingly stretched in west-east direction.
To get an undistorted landscape, you'll have to finally convert the PNG
heightfield into a mesh2 which follows Earth's curvature according to
its geographical coordinates. I also wrote a script to do this
(mesh2writer), but as you see in the example rendering I attached, some
artifacts resulting from floating point inaccuracy show up. To avoid
them, we probably must use Christoph Hormann's IsoCSG include
(http://www.imagico.de/pov/ic/index.html) which is able to convert a
mesh2 into an isosurface!
I added two scripts I wrote to do the conversion from PNG to mesh2 -
mesh2writer.pov which writes the full POV code for the entire mesh (for
parsing speed reasons, the mesh2 is generated only once and then written
to harddisk), and png2mesh2.pov which includes the code written by the
former script and generates the scene from it.
As the SRTM data tiles mentioned above have an effective resolution of
about 90 metres per data point, you'll be better off with pixeling
heightfield from a scanned-in topographic map, perhaps 1:25,000 (which
can be quite cumbersome work)... but then adjusting it to Earth
curvature would be somewhat difficult, as those maps are based on
geodetic (equal distances between points) rather than geographic
coordinates.
Yes, with Tasmanian Tigers roaming the forests! In fact, I think
Tasmania a very interesting part of the world, as it is located in the
"Roaring Forties", mainly when it comes to vegetation and animals, and I
really would like to visit your island!
Yadgar
Download 'us-ascii' (3 KB)
Download 'png2mesh2.pov.txt' (3 KB)
Download 'ascii2png.pov.txt' (1 KB)
Download 'png2ascii.pov.txt' (1 KB)
Download '2010-11-20 afghan highlands south of koh-e baba range, take 1 (yadgar).jpg' (42 KB)
Preview of image '2010-11-20 afghan highlands south of koh-e baba range, take 1 (yadgar).jpg'
news:4d0a3421@news.povray.org...
> High!
> In Hobart?
Yep! Well Kingston actually, 10 minutes away. I work in Hobart city :)
>> heightfield?
> error pixels.
> RAM!
> coordinates.
> Yadgar
Thanks very much for the very thorough write up. I'm going to take a look
at that data over the weekend and see what I can come up with.
Tasmania is an awesome place, wonderful place to live. Unfortunately a
disease is threatening the Tassie Devils existance (no Tigers btw) so you
better hurry if you want to see them :)
Thanks again for the info, much appreciated!
Cheers Dre
Am 16.12.2010 23:21, schrieb Dre:
There aren't probably that many other settlements along the southern
coast... I've heard of another relatively large town called Launceston,
but it's located in the hinterland (on the Derwent river?) -
unfortunately, I don't have a large-scale map of Tasmania in handy!
Yes, I heard of that cancer-like plague... looks quite disgusting! And,
of course, I'm aware that the last known thylacine (in Germany, we call
Today, I'll just try out the tile with Christoph's IsoCSG...
Yadgar
news:4d0cf3e6$1@news.povray.org...
Umm, you make it sound like this is a very small island. Its very populated
and a state of Australia.
Launceston (in the north) is the second largest city in Tas :) Hobart (in
the south) is the capital and has the Derwent river running through it.
>> look
> Yes, I heard of that cancer-like plague... looks quite disgusting! And, of
> course, I'm aware that the last known thylacine (in Germany, we call them
> Yadgar
Cheers Dre
