POV-Ray : Newsgroups : povray.binaries.images : #read: why is the second variable undeclared? Server Time
11 Apr 2026 01:31:49 EDT (-0400)
  #read: why is the second variable undeclared? (Message 1 to 6 of 6)
Subject: #read: why is the second variable undeclared?
Date: 21 Apr 2010 11:05:48
Message: <4bcf144c$1@news.povray.org>
High!
As rendering Ghurghusht scenes using an isosurface for the planetary
terrain, I decided to use meshes generated from it in the future. First,
I have to find out most accurately the minimum and maximum elevations of
the isosurface terrain by probing altitude with trace(). To get a really
accurate representation, I divided the whole surface in 2592 (72 by 36)
tiles, each covering 5 x 5 degrees by 1800 x 1800 pixels (o.k., each
tile takes about 40 minutes, so the whole probing and afterwards, the
creation of heightfields would be done after eight months, assuming that
the computer runs 14 hours/day on average - but I hope this effort will
pay off later when rendering surface animations!). While running through
them using the clock variable, after each "frame" the current minimum
and maximum values are stored in a tiny ASCII file just conisting of
these two values separated by a tab.
Here is the code for the read routine:
       #fopen mm "minmax" read
       #while (defined(mm))
         #read (mm, min_file, max_file)
       #fclose mm
       #declare min_el=min_file;
       #declare max_el=max_file;
...but now I always get the error message "Cannot assign uninitialized
identifier." Why? According to the manual, it's legal to read more than
one variable from an ASCII file...
See you in Khyberspace!
Yadgar
Subject: Re: #read: why is the second variable undeclared?
Date: 21 Apr 2010 11:52:57
Message: <4bcf1f59$2@news.povray.org>
Jörg 'Yadgar' Bleimann wrote:
> the current minimum
The documentation says the values have to be separated by commas.
Replace your tab by a comma and it should work fine...
Vincent
Date: 21 Apr 2010 14:49:07
Message: <4bcf48a3$1@news.povray.org>
High!
No, it doesn't... either (when I initialize the two variables before
opening the text file) both variables are set to zero with each new
"frame", or (when I do not initialize) I still get the error message
mentioned in my first post!
Yadgar
Date: 21 Apr 2010 15:21:13
Message: <4bcf5029$1@news.povray.org>
Note that high resolution meshes require a lot of parse time,
so before you embark on this 8 month analysis you might wish
to verify that it will actually help your animation.
the code looks reasonable, can you post the data file
itself as you write it during the first frame?
Date: 21 Apr 2010 19:18:41
Message: <4bcf87d1$1@news.povray.org>
High!
Meanwhile, I found out my mistake: I just forgot to change the writing
routine from tab to comma!
Yadgar
Date: 23 Apr 2010 12:14:34
Message: <4bd1c76a$1@news.povray.org>
High!
You're right... I found out that at least the first four month (the
probing process) can be left out as at 24-bit resolution for the "height
fields" (from which the actual mesh2s will be constructed) even with the
rough 1800 x 900 probing across the whole planet, the smallest height
interval will be a mere 2.5 mm - any higher resolution probing will
increase this only by a few microns, and any elevations outside the
range already determined could easily be handled by adjusting them to
the "floor" and "ceiling" values.
The only problem with this mesh2/"heightfield" approach will be that
unlike with the original isosurface, there will by no overhangs (but
also no "hovering rocks") anymore...
Meanwhile, I did a test scene using the isosurface - it took 40 minutes
and 25 seconds! I hope I get the mesh2 version working tonight...
Yadgar
Now playing: I Take The Dice (Duran Duran) - as if time stood still 26
years ago...
