POV-Ray : Newsgroups : povray.binaries.images : Journey to an Unknown region [ wip 3] Server Time
15 Aug 2025 22:16:39 EDT (-0400)
  Journey to an Unknown region [ wip 3] (Message 1 to 10 of 11)
Subject: Journey to an Unknown region [ wip 3]
Date: 19 Dec 2009 10:39:23
Message: <4b2cf3ab@news.povray.org>
Latest wip here with more heavily transformed rocks (1 mesh2 object), an
eagle, a media in the middleground. Total render time about 14.5 hours
altogether.
Download 'Journey to an Unknown Region_06.jpg' (206 KB)
Preview of image 'Journey to an Unknown Region_06.jpg'
Subject: Re: Journey to an Unknown region [ wip 3]
Date: 20 Dec 2009 10:00:01
Message: <web.4b2e3b80242e0a9065f302820@news.povray.org>
The rocks look great!  And the media addition is a nice touch, too.  Something I
didn't mention before: I really like the ice-like glints on the snow, as if it's
slightly frozen over.
The texture or pigment on the closer, steeper mountain sides still doesn't look
quite right to my eye--something about those little gray(?) speckles. Or perhaps
the surface detail there is still too smooth.
Ken
Date: 20 Dec 2009 12:13:54
Message: <4b2e5b52$1@news.povray.org>
> Ken
Seconded.  Mysterious and surprising as nature can be, that glass-like
sheer face in the foreground just doesn't carry.  Especially with all
the evidence of freeze-melt cycle around it.  It is the only element in
the picture I don't find believable.
Date: 21 Dec 2009 04:51:52
Message: <4b2f4538$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> schreef in bericht
news:web.4b2e3b80242e0a9065f302820@news.povray.org...
> Something I
> if it's
> look
> perhaps
To Ken and Jim, Thanks a lot indeed.
I agree about the rockface in the foreground. It is frustratingly not coming
out as I want it to be. The reason is of course that the height_field is too
smooth at that distance/angle, which cannot be entirely compensated by a
texture. What I need to do is follow Robert McGregor's tip about adding
irregularities to the mountain in the foreground. I can also scale them down
with distance and making them merge with the rocks.
The snow/ice is all to be credited to a nice snow texture by Gail Shaw, she
presented here a couple of years ago:
//snow texture by Gail Shaw:
#declare T_Snow_close=
  pigment {rgb <0.95,0.95,1>}
  finish {
    ambient 0.0
    diffuse 1.0
    reflection {0,0.2}
    specular 0.6 roughness 0.008
  normal {granite 0.1 scale 0.01}
For the snow in the distance, I simply commented out the normal.
Date: 21 Dec 2009 09:15:01
Message: <web.4b2f8289242e0a9065f302820@news.povray.org>
> texture.
Another, more radical idea might be to make that foreground mountain a separate
height_field, with its own (finer) detail. Of course, visually blending that one
into your main HF could be a tricky (if not impossible) chore.
Another idea: Perhaps apply an image_map overlay of some kind--one with finer
'detail' so to speak-- to the nearer mountain slope, to give it some visual
variation.
As you can probably tell, I have no problem 'cheating' the structural make-up of
a scene, if I can make it look the way I want.
Ken
Date: 21 Dec 2009 10:36:46
Message: <4b2f960e$1@news.povray.org>
news:web.4b2f8289242e0a9065f302820@news.povray.org...
> separate
> that one
> finer
> visual
> variation.
> make-up of
Your two ideas are interesting to pursue further. The first would be
difficult to get really right, but I shall nevertheless give it a thought.
The second one could be simpler to do. I have to dig into my images (or make
one; or look for one) that would be appropriate. I could also use Jaime's
proceduralize macro to blend it better with the scene...
Thanks for the suggestions, Ken. You have put in motion a couple of
interesting challenges  :)
Date: 21 Dec 2009 17:18:29
Message: <4b2ff435@news.povray.org>
I just played a bit with adding sub-height_fields
on top of a main height_field and came up with this:
// *** SUB_HF *** Add detail to part of another height_field
// F_BASE:    Function describing the main height field
// F_SUB:     Structure of the overlaid subfield.
// F_MERGE:   Function for merging the seams. This should be smooth
//            and evaluate to 0 on the border of the unit square.
// SUB_SCALE: Strength of overlaid substructure for convenience
// SUB_?_???: Rectangle specifying the portion of the main field.
#macro SUB_HF(F_BASE,F_SUB,F_MERGE,SUB_SCALE,
               SUB_X_MIN,SUB_X_MAX,SUB_Z_MIN,SUB_Z_MAX)
   #local sub_x_min = SUB_X_MIN;
   #local sub_x_max = SUB_X_MAX;
   #local sub_z_min = 1-SUB_Z_MIN;
   #local sub_z_max = 1-SUB_Z_MAX;
   #local sub_x_ext = sub_x_max - sub_x_min;
   #local sub_z_ext = sub_z_max - sub_z_min;
   height_field
     function 512, 512
       0.5*f1(sub_x_min + x*sub_x_ext,sub_z_min+y*sub_z_ext) +
       0.5*SUB_SCALE*f_merge(x,y) * f2(x,y)
     scale     <sub_x_ext,2,sub_z_ext>
     translate <sub_x_min,0.001,1-sub_z_max>
Sample usage:
#declare f1 = function(x,z) {f_bozo(x*10,0,z*10)};
#declare f2 = function(x,z) {f_bozo(x*50,0,z*50)};
#declare f_merge = function(x,z){f_spherical(2*(x-0.5),0,2*(z-0.5))};
union
   height_field {function 512, 512 {f1(x,y)}}
   object {SUB_HF(f1,f2,f_merge,0.3,0.6,0.7,0.1,0.3) pigment {color Red}}
   object {SUB_HF(f1,f2,f_merge,0.2,0.2,0.3,0.6,0.8) pigment {color
Red}}
   scale 0.5 * y
   pigment {color White}
Date: 22 Dec 2009 03:10:26
Message: <4b307ef2$1@news.povray.org>
Thanks Christian, I have to play with this a while to see if it works...
Date: 27 Dec 2009 15:23:20
Message: <4b37c238@news.povray.org>
High!
> eagle,
Could it be Gwaihir carrying Gandalf above Mt. Caradhras? Sorry, but I'm
somewhat "Tolkienized" at the moment...
See you in Khyberspace!
Yadgar
Now playing: Sad Songs (Elton John)
Date: 16 Jan 2010 20:59:56
Message: <4b526f1c@news.povray.org>
Wow! You heard me, even before i finished to write... Even before i started
to think...   ;-)
Sven
