POV-Ray : Newsgroups : povray.binaries.images : tractor 2008 (164k jpg) Server Time
8 May 2026 13:39:25 EDT (-0400)
  tractor 2008 (164k jpg) (Message 41 to 50 of 59)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: tractor 2008 (164k jpg)
Date: 3 Dec 2008 02:00:05
Message: <web.49362df062d2e221245753e10@news.povray.org>
stbenge <THI### [at] hotmailcom> wrote:
> currently impossible to use any proximity patterns with meshes. That's
> right, impossible!
What are proximity patterns?  Is it like AO or radiosity?
Date: 3 Dec 2008 08:26:50
Message: <4936891a$1@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> schreef in bericht
news:web.493594d862d2e22181c811d20@news.povray.org...
> A *quick* render.  I have made it very shiny!
LOL
Now let that baby ROAR....
(and black smoke, please....)   :-)
Date: 3 Dec 2008 16:53:13
Message: <4936ffc9@news.povray.org>
>> right, impossible!
I'm not sure if the term "proximity pattern" ever existed before
MegaPOV. I remember seeing it a long time ago as a new feature, but
never got to play with it.
Basically a proximity pattern is like a gradient indicating the distance
from a surface in 3D space. Imagine making an object pattern from some
object and applying a 3D blur to it. What you get is a fuzzy
representation of your object, but in pattern form. As a special bonus,
the inside edges and vacations end up black, the outside edges and
protrusions end up white, and all the flat parts in between end up a
gray color.
I have created two versions which I use for different things. I have
released one of them bundled with the fastSSS macros, but I think I will
release another include with just the proximity macros.
Sam
Date: 3 Dec 2008 17:52:19
Message: <49370da3$1@news.povray.org>
stbenge wrote:
> The biggest reason I didn't model this as a mesh is because it's
you never know when a wax tractor might come in handy ;)
Date: 3 Dec 2008 22:42:29
Message: <493751a5@news.povray.org>
> gray color.
Sounds like AO.  The occlusion effect is likewise achieved by taking
into account surrounding geometry, not angle of incidence or position of
light sources.  Your image looks very AO like.
Date: 3 Dec 2008 23:45:00
Message: <web.49375f8f62d2e221ef2b9ba40@news.povray.org>
> They are manually rounded off using cylinders, torii and spheres.
> There's an object pattern trick for making edges look rounded using
> surface normals, but it doesn't work too well with most objects.
Gosh.  I did that with a piano a few years back.  It was a *lot* of work and it
wasn't nearly this complex.  That's very impressive.
 - Ricky
Date: 3 Dec 2008 23:54:15
Message: <49376277@news.povray.org>
nemesis wrote:
>> distance from a surface in 3D space. Imagine making an object pattern
>> from some object and applying a 3D blur to it. What you get is a fuzzy
>> bonus, the inside edges and vacations end up black, the outside edges
>> and protrusions end up white, and all the flat parts in between end up
>> a gray color.
AO and proximity patterns give different results. Proximity patterns can
give you access to *outside* edge data as well as inside edge data. AO
just makes inside edges dark. Proximity patterns also make thin objects
lighter in color, and thicker ones slightly darker. When I combine my
proximity macros, I'll post examples to this group so you can see for
yourself how it looks.
Sam
Date: 3 Dec 2008 23:55:59
Message: <493762df$1@news.povray.org>
It's time consuming, that's for sure :/
Sam
Date: 7 Dec 2008 00:40:01
Message: <web.493b60e562d2e2216349cc2c0@news.povray.org>
> right, impossible! Actually, if somebody can figure out how to get a
> proximity pattern working with meshes, I would really appreciate it :)
Just write your own inside() function. I gave it a go with the following, and it
seems to work pretty well. It should really be improved with the equivalent of
an inside_vector, so you can usefully use it with open meshes, but it's OK for
a quick attempt.
#macro inside_m( obj, pos )
 #local current = pos;
 #local dir = x;
 #local done = 0;
 #local num = 0;
 #while ( done != 1 )
  #local norm = <0,0,0>;
  #local inter = trace( obj, current, dir, norm );
  #if ( vlength( norm ) != 0 )
   #local num = num + 1;
   #local current = inter + <0.0001,0,0>;
  #else
   #local done = 1;
 (mod( num, 2 ) = 1)
Cheers,
Edouard.
Download 'fastprox_bunny.jpg' (19 KB)
Preview of image 'fastprox_bunny.jpg'
Date: 7 Dec 2008 13:00:00
Message: <web.493c0ef762d2e221198b63d90@news.povray.org>
> a quick attempt.
>  #local dir = x;
>  #local done = 0;
>  #local num = 0;
>   #else
>    #local done = 1;
>   #end
>  #end
>  (mod( num, 2 ) = 1)
> #end
> Cheers,
> Edouard.
Forgive me for being slow as usual, but could you could help me understand your
macro?
I suppose you could used the inside test to fill up the inside of a mesh with
cubes to make CSG approximation of a mesh shape--but that doesn't appear to be
what you did.
