POV-Ray : Newsgroups : povray.binaries.images : Trying to understand Megapov's cloth... Server Time
10 Apr 2026 21:50:57 EDT (-0400)
  Trying to understand Megapov's cloth... (Message 1 to 3 of 3)
Subject: Trying to understand Megapov's cloth...
Date: 3 Jul 2007 17:44:18
Message: <468ac332$1@news.povray.org>
Here is the code for this scene:
// Begin code
#version unofficial MegaPov 1.21;
// Macro straight from Megapov documentation
#macro WriteClothFile(filename, n1, n2, nlng, ks, ht)
   #fopen file filename write
   #write(file, n1, ", ", n2, ", ", nlng, ", ", ks, ",\n")
   #local l1 = nlng*(n1-1);
   #local l2 = nlng*(n2-1);
   #local st = seed(1234);
   #local i=0;
   #while (i < n1)
     #local j=0;
     #while (j < n2)
       #local tempx = -l1/2 + i*nlng;
       #local tempz = -l2/2 + j*nlng;
       #local tempy = ht + (-1+2*rand(st))*nlng*0.1;
       #write(file, tempx, ",", tempy, ",", tempz, ", 0.0, 0.0, 0.0,\n")
       #set j=j+1;
     #set i=i+1;
   #fclose file
WriteClothFile("temp.cth", 50, 50, 0.2, 0.95, 0)
#declare stuff =
   sphere {
     <02.5, -2, 02.5>, 1
     pigment {color rgb <0, 1, 0>}
simcloth {
   environment stuff
   friction 0
   gravity -0.4*y
   damping 0.9
   intervals 0.03
   iterations 1000
   input "temp.cth"
   mesh_output "cloth.msh"
   smooth_mesh on
   uv_mesh on
mesh {
   #include "cloth.msh"
   uv_mapping
       checker
       color rgb <1, 0, 0>
       color rgb 1
       scale 0.1
object {stuff}
   location <5, 1, -10>
   look_at <5, 0, 5>
light_source {
   <5, 15, -5>
   color rgb 1
// end code
Why is the sphere showing through the cloth in the final scene? I'm
going nuts trying to figure out what I screwed up. Did I just hit a bug
in Cloth-ray?
William Tracy
|a|f|i|s|h|i|o|n|a|d|o|@|g|m|a|i|l|.|c|o|m|
|w|t|r|a|c|y|@|c|a|l|p|o|l|y|.|e|d|u|
You know you've been raytracing too long when www.povray.org is your
default homepage in your web browser.
fish-head
Download 'clthtest.png' (7 KB)
Preview of image 'clthtest.png'
Subject: Re: Trying to understand Megapov's cloth...
Date: 4 Jul 2007 03:36:42
Message: <468b4e0a@news.povray.org>
This is fairly normal behaviour with ClothRay. It happens because the two
surfaces are almost coincident. I think it is explained somewhere in the
docs, or I remember this from earlier comments. What you should do is to
scale up a tiny bit the final cloth so that it covers nicely the sphere.
Alternatively, you can start by scaling up a tiny bit the sphere before
processing and use the resulting cloth over your original sphere. Very small
amounts will be enough.
Date: 4 Jul 2007 16:38:06
Message: <468c052e$1@news.povray.org>
Okay. I'd just never seen ClothRay do this before, and was wondering how
  I'd triggered it in this scene.
I was originally using this scene to play with some macros of my own,
and this was making me think I'd screwed up my macros. But between being
able to reproduce it with the "default" macro, and your reassurance that
this is normal :-) I'm feeling better now.
William Tracy
You know you've been raytracing too long when your ophthalmologist
examines you for complaints of eye strain and blurred vision and asks
you why the words Pov, #declare, #include, sphere, translate, rotate,
texture, and pigment are permanently burned into your retina.
Ken Tyler
