POV-Ray : Newsgroups : povray.binaries.images : Making clothes in Poser - Take 4 Server Time
1 Aug 2026 12:55:07 EDT (-0400)
  Making clothes in Poser - Take 4 (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Making clothes in Poser - Take 4
Date: 18 May 2007 03:16:58
Message: <464d52ea@news.povray.org>
"Janet" <par### [at] attnet> schreef in bericht
news:web.464d098775be5ba7102f620@news.povray.org...
> "Thomas de Groot" <t.d### [at] internlDOTnet> wrote:
>> Radiosity version, and corrected position of the kilt.
>> Thomas
> It still didn't fall off. :(
<grin>
> Hey, that's good tip to set a material for the constrained part. Thanks!
Yes, I found that piece of info in the docs by the way...
> If you import your kilt.obj (or whatever its called) into Poser and
> uncheck
> everything on the import options, I beleive it should load exactly onto
> the
> zero figure without any transformation needed. At least it works that way
> in
> Poser 6.(make polygon normals consistent can be kept checked)
I was surprised because it didn't happen with the poncho. But this time, the
kilt was too large after import. I shall investigate this.
> Have fun Thomas!
I have!! Have fun too!
Date: 18 May 2007 03:53:13
Message: <464d5b69@news.povray.org>
One piece of advise which might be worthwhile for the would-be clothing
designers :-)
If you use a cone as a proxy for a kilt or a skirt, the more "flat" that
cone is at the start, the more creases it will generate after draping. This
is rather obvious if you think this through. In my kilt example, the initial
cone was rather steep, so the garment does not show many creases.
Date: 23 May 2007 06:20:02
Message: <web.4654145575be5ba7c4e49fa40@news.povray.org>
> So, the next logical step after the poncho is to investigate the use of
> Dynamic Groups, and in particular Constrained Groups. I thought about
> another fairly simple piece of garment: the kilt. Here is the result of the
> first satisfactory test, after a few abortive ones.
The garment is not a kilt it looks like a dress to me. Trust me, my mother
was a dressmaker and she made kilts. The check of the tartan should always
run parallel to the edges of the kilt. To do this you would need to use a
rectangle instead of a cone. Then you would need to wrap the kilt around
your figure. The pleats at the back, are square box pleats and it is all
gathered and held together by a belt. The pleats on Dress kilts are
stitched together at the top. You have the length just about right it is a
tad short another four centimeters would do. Although it could be down to
simple garment they seem and if you animate them the movement is quite
I think Janet is right about loading it into Poser (6).
Date: 23 May 2007 07:53:47
Message: <46542b4b@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> schreef in bericht
news:web.4654145575be5ba7c4e49fa40@news.povray.org...
> I missed this, nice one Thomas. I don't want to nitpick but I will :-)
> his calf's.
> I bet that's more than you wanted to know about kilts. They are not the
> distinctive and complex. I wouldn't attempt it. (Yet :-)
Ah, Stephen! I expected your comments with dread  :-)
I know. I didn't want to do a real kilt, only a make-believe, just to see
what a cone would do in terms of clothing. I probably shall experiment also
with rectangular pieces wrapped around the figure, but as you know, that is
a bit more work, although probably, highly satisfying.
One of the difficulties that I discovered, is to have a weave well-oriented
to the cloth, when that is not exactly a rectangle but an unwrapped mesh. In
RL that's easy, but in VL it's a headache and cannot be really done without
a lot of handwork probably... :-(
Date: 23 May 2007 07:59:13
Message: <46542c91$1@news.povray.org>
Oh yes, I forgot, Janet and Stephen!
That works much better indeed, although now the objects are a bit too
small... But overall, it is not a big issue and easily corrected.
Date: 23 May 2007 10:05:01
Message: <web.4654493b75be5ba7c4e49fa40@news.povray.org>
Fit like Mon?
your country.
bit sissy calling it a skirt. I think that to do a wrap a round with pleats
would be difficult, too difficult for me to try.
not tried it myself but it might be worth a try.
Date: 23 May 2007 11:25:26
Message: <46545ce6$1@news.povray.org>
news:web.4654493b75be5ba7c4e49fa40@news.povray.org...
> Fit like Mon?
> There is no need to fear :-) Anyway I must be polite as I'm now a guest in
> your country.
Visiting the Big Boss?
> I realized that it was just a test, part of the learning curve and it's a
> pleats
Well, I call it also a skirt, or at least I realize I can use it as a skirt
on a female figure. But then, fashion being what it is, skirts for males
will be hot next season! Years ago, my wife and I imagined exactly that for
fun :-)
Perhaps not too difficult to do a wrap. I have done something of the sort
with wrapping a rope around a post. Basically, it is extruding, translating,
rotating, extruding, translating, rotating, etc, etc, etc. tedious but not
impossible.
>> well-oriented
>> In
>> without
> How about using a spherical or cylindrical mapping for the UV mapping?
> I've
Oh sure, that works fine. However, for more complex things that does not
really work well. Watch the upcoming Take 5 to see what I mean.
Date: 23 May 2007 12:00:02
Message: <web.4654640275be5ba7c4e49fa40@news.povray.org>
> > Fit like Mon?
> > your country.
> fun :-)
They (the fashion houses) keep trying to promote that every couple of
years. If skirts were so good, why has my wife not worn one since she left
school?
> impossible.
> > I've
With interest.
Date: 24 May 2007 03:32:38
Message: <46553f96$1@news.povray.org>
news:web.4654640275be5ba7c4e49fa40@news.povray.org...
> No (I think). I'm working for Philips in, guess . Eindhoven.
<grin>
>> skirt
>> for
>> fun :-)
> school?
I know what you mean. Same here.
>> translating,
>> not
>> impossible.
> I forgot about that. I've not much experience with that sort of modeling.
It is quite rewarding in fact, and giving convincing results. I have no
experience with cloth but it should work the same. I shall have to try!
Date: 26 May 2007 07:53:14
Message: <is7g53d5g5nad5corargl8vqdd2ksbjrrc@4ax.com>
On Thu, 24 May 2007 09:32:39 +0200, "Thomas de Groot" <t.d### [at] internlDOTnet>
>>> translating,
>>> not
>>> impossible.
Sorry for the late reply, I missed this.
I can imagine that it is rewarding but I don't have the dexterity and defiantly
not the technique.
Regards
