POV-Ray : Newsgroups : povray.binaries.images : Playing with radiosity Server Time
11 Jul 2026 23:45:40 EDT (-0400)
  Playing with radiosity (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Playing with radiosity
Date: 3 May 2007 00:40:02
Message: <web.46396779e2c4640f5897f1740@news.povray.org>
Paul Fuller <pgf### [at] optusnetcomau> wrote:
> Nice images.
> I wrote a little program to combine the three images dynamically
> depending upon the mouse position on the screen.  It uses a very simple
> and not quite correct method but the results are interesting.
> Sort of simulates varying the intensity of any of the three lights.
> Unzip to a directory and run the exe.
That is interesting, I wonder how far you could push this trick?
I'm thinking out loud here, but bear with me. Lets say each image was 50KB,
and you loaded the images into the fast RAM on a video card. With 100MBs of
RAM you could have 2000 total images in memory, or alternatively your scene
rendered with the lightsource placed at each point of a 45 by 45 grid. You
would only need to sample the three or four images with the closest
lightsource to simulate light positions between grid points, so it seems
like computationally it would be feasible. With the use of an adaptive grid
you could simulate real-time radiosity with all the bells and whistles in
extrememly complex scenes.
So... any chance you could share your code?
Date: 3 May 2007 06:18:25
Message: <4639b6f1@news.povray.org>
>> Nice images.
There are definitely some possibilities for giving games a ray-traced
like appearance without actually calculating everything dynamically.
You are limited though by the combinatoric explosion that happens if you
want to support too much with this method.
Probably better applied to local effects rather than the illumination of
the whole scene as it is here.
Another trick / trade-off not done here is to render the basic scene
then calculate each effect independently.  Calculate the difference
between the original and new scene.  You don' necessarily need to store
every different pixel.  Perhaps only store the significant changes or
those within some subregion that is most significant.
By the way, there is a fault in the method as shown below.  The first
image is displayed with Alpha=1.0.  Then the second image is drawn over
it with an Alpha that depends upon how strong it should be.  The third
image is again drawn over that and I think has too strong an influence
on the result.  There needs to be some adjustment of the Alpha from the
simple method used here.  Perhaps it could all be made additive...
I wrote the program in BlitzMax which is great for quick graphics stuff.
  the graphics routines support hardware accelerated alpha and rotation
which is nice.  You may not have or know of BlitzMax but the code is
pretty straightforward.
Also it is just knocked together after seeing Warp's post.  Probably too
many globals and other frowned upon practices for the purists.
Anyway, publish and be damned:
SuperStrict
Global G_ScreenWidth:Int = 800
Global G_ScreenHeight:Int = 600
Global G_MaxDistance:Float = G_ScreenHeight * 2 / Sqr(3)
Graphics G_ScreenWidth, G_ScreenHeight,1
SetBlend(ALPHABLEND)
' H:\Resources\Images\System\QiD Logo 1920x1200.png
' H:\Resources\Images\System\QiD Logo 1920x1200 - Gold.png
Global G_Image1:TImage = GetImage("Warp - Rad1.jpg")
Global G_Image2:TImage = GetImage("Warp - Rad2.jpg")
Global G_Image3:TImage = GetImage("Warp - Rad3.jpg")
Global G_P3:TPoint = TPoint.CreatePoint(G_ScreenWidth / 2, 0)
Global G_P1:TPoint = TPoint.CreatePoint(G_P3.X - G_MaxDistance / 2,
G_ScreenHeight - 1)
Global G_P2:TPoint = TPoint.CreatePoint(G_P3.X + G_MaxDistance / 2,
G_ScreenHeight - 1)
Global G_Mouse:TPoint = Tpoint.CreatePoint(0.0, 0.0)
Global G_Offset:TPoint = TPoint.CreatePoint((G_ScreenWidth -
ImageWidth(G_Image1)) / 2.0, (G_ScreenHeight - ImageHeight(G_Image1)) / 2.0)
While Not KeyHit(KEY_ESCAPE)
	Cls
	G_Mouse.SetXY(MouseX(), MouseY())
	Local S1:Float = CalcStrength(G_Mouse, G_P1)
	Local S2:Float = CalcStrength(G_Mouse, G_P2)
	Local S3:Float = CalcStrength(G_Mouse, G_P3)
	DrawImageFade(S1, G_Image1)
	DrawImageFade(S2, G_Image2)
	If (G_Image3 <> Null)
		DrawImageFade(S3, G_Image3)
	EndIf
	DrawMarkers()
	Flip
Wend
Function GetImage:TImage(filename:String)
	Return LoadImage(filename, FILTEREDIMAGE | MASKEDIMAGE)
End Function
Function CalcStrength:Float(p1:TPoint, p2:TPoint)
	Local dx:Float = p1.X - p2.X
	Local dy:Float = p1.Y - p2.Y
	Local distance:Float = Sqr(dx * dx + dy * dy)
	If (distance > G_MaxDistance)
		Return 0.0
	Else
		Return 1.0 - distance / G_MaxDistance
	EndIf
End Function
Function DrawImageFade(s:Float, image:TImage)
	SetAlpha(s)
	DrawImage(image, G_Offset.X, G_Offset.Y)
End Function
Function DrawMarkers()
	SetAlpha(1.0)
	SetColor(255, 255, 255)
	DrawMarker(G_P1)
	DrawMarker(G_P2)
	DrawMarker(G_P3)
End Function
Function DrawMarker(p:TPoint)
	DrawOval(p.X - 1, p.Y - 1, 3, 3)
End Function
Type TPoint
	Field	X:Float
	Field	Y:Float
	Function CreatePoint:TPoint(x:Float, y:Float)
		Local T:TPoint = New TPoint
		T.X = x
		T.Y = y
		Return T
	End Function
	Method SetXY(x:Float, y:Float)
		self.X = x
		self.Y = y
	End Method
End Type
Date: 3 May 2007 09:15:01
Message: <web.4639df88e2c4640fdb039c4d0@news.povray.org>
Thanks for posting the code Paul, I hadn't heard of BlitzMax before but it
looks like it will be fun to play with. They even offer a trial of the
software, so I've been able to compile your code myself.
Even with the various limits I think you could still use your approach to
make a cool little platformer or something. Each level could be a single
window, and the protagonist could be exploring a dark world with an area
light source (like a lantern or a burning torch). With some focal blur,
area lights and radiosity I think you could create a really cool, unique
visual style.
Date: 3 May 2007 10:15:47
Message: <pan.2007.05.03.14.15.46.432574@removeit.geloescht.net>
Am Thu, 03 May 2007 00:01:07 -0400 schrieb nemesis:
> Lukas Winter <web### [at] removeitgeloeschtnet> wrote:
>> This is the first time I see those incredibly soft shadows some
>> commercial renderers produce... done in POV-Ray.
> I see you're new to povray. :)
> Povray has got area light soft shadows for even longer than radiosity...
I have been using POV-Ray for about two years now, although not very
often. I know there are area lights but they don't have the effect I
thought of. Perhaps I should have said soft shading. I have the impression
most POV-Ray images have very "sharp" global illumination, everything
looks a bit too exact to be believable. Maybe it's the lack
of a light bleeding filter on the final image. As someone noticed, area
lights also only have an effect on shadows, not on highlights or diffuse
reflection.
Date: 3 May 2007 10:24:08
Message: <pan.2007.05.03.14.24.07.317269@removeit.geloescht.net>
Am Thu, 03 May 2007 00:28:18 +0300 schrieb Warp:
> Lukas Winter wrote:
>> Did you use pure radiosity lighting or in a combination with area
>> lights?
>   I used area lights, of course.
>> How long did it take to render these pictures?
>   Between 30 minutes and 1 hour.
>> And the most
>> important question: Which color has that light?
>   White.
Really? It looks a bit yellow.
Date: 3 May 2007 16:55:02
Message: <web.463a4b35e2c4640ffc02165f0@news.povray.org>
> >> lights?
> >> And the most
> >   White.
Two of the three lights are nearer the yellow table and red wall than the
blue; the reflected light is therefore warm; and even the top one, because
of the relative perceived 'brightness' of red compared to blue, appears to
have a warm tint --- but this is all because of the reflected light. The
shadows, you'll notice, don't look particularly cool in comparison;
comparing light to shadow id  a good way of getting a more absolute idea of
the color of a light.
-Sam Bleckley
http://www.meetsoup.com
Date: 3 May 2007 17:25:31
Message: <463a534b@news.povray.org>
Lukas Winter nous apporta ses lumieres en ce 03-05-2007 10:15:
> reflection.
If your shadows from area_light looks banded or grainy, the cause is a to sparce
aray of components. Try with larger values, then add adaptive N (start with 0
and increase as needed if you get artefacts) to use adaptive sampling that will
greatly accelerate the rendering.
I commonly use aray of 17*17 or 33*33, even 65*65 without to much slowing.
If the area_light is surrounded by several objects, it's effect will vary
accordingly to the relative positions. Use circular orient to emulate a
spherical light.
It doesn’t matter what you do. It only matters what you say you’ve done and what
you’re going to do.
Date: 3 May 2007 19:35:59
Message: <463a71df@news.povray.org>
> visual style.
That is a great idea.  Just mention me in the credits when you make it
big :)
Date: 3 May 2007 19:40:02
Message: <web.463a7228e2c4640fa591bdb0@news.povray.org>
> > lights?
> > And the most
>   White.
Those are some great soft shadows. Please post your area light sttings.
Date: 3 May 2007 20:53:16
Message: <463a83fc@news.povray.org>
Lukas Winter wrote:
> This is the first time I see those incredibly soft shadows some commercial
> renderers produce
  Perhaps you mean that the image has soft *shading* (which is a bit
different from *shadows*), uncommon in average povray images?
  The soft shading is purely produced by the color bleeding produced
by the global illumination.
