POV-Ray : Newsgroups : povray.binaries.images : brain vs. image_map Server Time
17 Jun 2026 12:14:44 EDT (-0400)
  brain vs. image_map (Message 1 to 5 of 5)
Subject: brain vs. image_map
Date: 21 Jan 2006 12:24:17
Message: <43d26e41@news.povray.org>
several days ago I stumbled over thread in p.b.i ("Walter's bones")
which made use of a nested pattern for the floor. So I thought it might
be possible to create a classic parquet floor without the usage of
image_maps, just plain procedural.
After 1 or 2 hours of bending my mind and several coffees later, I was
able to get following render.
take it as "prove of principal". No tile is repeated once, no matter how
large the floor will be.
- eight prototype wood textures
- three levels of nested checker patterns
... dave
Download 'parquet.jpg' (138 KB)
Preview of image 'parquet.jpg'
Subject: Re: brain vs. image_map
Date: 21 Jan 2006 16:15:05
Message: <k095t115fujmo4b6bhiek9dgvk42di6s0b@4ax.com>
On Sat, 21 Jan 2006 18:25:46 +0100, David El Tom <dav### [at] t-onlinede>
Nice, I tried in the past similar idea, see:
http://news.povray.org/povray.binaries.images/attachment/%3C3ab9cc23%40news.povray.org%3E/pattern.jpg
ABX
Date: 21 Jan 2006 17:05:00
Message: <web.43d2aef4cbd82167641d079c0@news.povray.org>
Well done. The wood is a nice light one, too. Did you have a scene in mind
for this, or is it only a proof-of-concept?
I especially like that you put some warps in the wood. They blend in better
than most of the warps I've seen in wood textures, so good job.
You might want to work on the pattern scaling just a bit, though. It's not
common to find end grain and side grain both in most of the floors I am
familiar with. (Minor quibble)
anyway, well done. Doesn't your brain feel limber now?
-Sefan
Date: 22 Jan 2006 04:13:22
Message: <43d34cb2@news.povray.org>
"David El Tom" <dav### [at] t-onlinede> schreef in bericht
news:43d26e41@news.povray.org...
> ... dave
Well done!
Scale the textures somewhat down too, I guess.
And.... there are two tiles which are identical!!!! or so I believe when I
look at them... watch carefully!
Date: 22 Jan 2006 08:24:25
Message: <43d38789@news.povray.org>
thanks to all so far,
mind
   actually it's both, the thrill to achieve something "ab initio" and
   the need of a good floor texture for my (long term) project of an
   indoor hdr-lightprobe.
better
   to be honest, just luck to got it in this way. 2 different black-hole
   warps per prototype texture turbulently repeated.
It's not
   what should I say, ..., you're right ;-)
 > -Sefan
   still a little dizzy ....
   yepp, .. see above.
> Thomas
   It seems, that I tricked myself trying to avoid exactly this
   behaviour. I just have to change 2 offsets and each tile will be
   really unique.
The layout of the parquet can be seen in the attached image.
So basicly what I needed was a checker pattern with 4
different tiles instead of 2 (standard checker pattern).
I wrote a small macro to achieve this:
SNIPPET START
//  Checker4Pig
//  - creates a checked pigment based on 4 different tiles
// usage: #declare my_pigment = pigment { Checker4Pig(.....) }
//                 ^ z
//             | 1 | 3 |
//            -+---+---+-> x
//             | 2 | 4 |
#macro Checker4Pig(PIG1,PIG2,PIG3,PIG4)
   #local PIG12 =
     pigment
       checker
       pigment{PIG1 translate (z+x) scale <.5,1,.5>}
       pigment{PIG2 translate (-z+x) scale <.5,1,.5>}
       translate (z-x)
       scale <.5,1,.5>
   #local PIG34 =
     pigment
       checker
       pigment{PIG4 translate (-z-x) scale <.5,1,.5>}
       pigment{PIG3 translate (+z-x) scale <.5,1,.5>}
       translate z+x
       scale <.5,1,.5>
   checker
   pigment { PIG34 }
   pigment { PIG12 }
   translate -z*.5 scale <2,1,2>
SNIPPET END
so feel free to experiment with it ...
... dave
Download 'parquet_layout.png' (25 KB)
Preview of image 'parquet_layout.png'
