POV-Ray : Newsgroups : povray.binaries.images : Optics: Straight beam of light Server Time
22 Feb 2026 21:50:57 EST (-0500)
  Optics: Straight beam of light (Message 1 to 7 of 7)
Subject: Optics: Straight beam of light
Date: 17 Dec 2005 04:05:01
Message: <43a3d4bd@news.povray.org>
A. I'm using photons to allow light to be reflected off an object.
However I don't seem to be able to get a perfectly straight beam of
light. The image below is a 16u x 16u grid. The spotlight is 72u from
the top of the grid and then is masked by the red 'turret' at the top in
order to thin it down. This does an OK job, but as the light reflects of
more and more objects, the wider the beam gets. Is there any way to stop
it getting wider?
B. Once the light reflects off the first object it starts to interact
with the media as I'd expect (the glow) however before it hits that
first object, there is no glow! How do I get the glow on the first part
of the beam? One solution I had was to start the beam to the left of the
masking turret and fit a mirror into the mask, but surely there's a
better way?
Cheers!
Rick Measham
Download 'example.jpg' (71 KB)
Preview of image 'example.jpg'
Subject: Re: Optics: Straight beam of light
Date: 17 Dec 2005 06:14:03
Message: <43a3f2fb$1@news.povray.org>
> it getting wider?
This is probably an inaccuracy in the photon mapping. Use more photons
and it will probably reduce the effect. (And the render speed!!)
> better way?
Hmm... can't help you there I'm afraid. :-(
Date: 17 Dec 2005 08:46:44
Message: <tdhd73-nc5.ln1@raf256.com>
Orchid XP v2 <43a3f2fb$1@news.povray.org> Saturday 17 of December 2005 12:14
Or set the light source to be parralelal? (spelling)
Btw, can You Rick share source code of this sexample scene?
Date: 17 Dec 2005 09:05:23
Message: <43a41b23$1@news.povray.org>
High!
parallel!
See you in Khyberspace!
Yadgar
Date: 17 Dec 2005 10:24:59
Message: <43a42dcb@news.povray.org>
Rick Measham nous apporta ses lumieres en ce 2005-12-17 04:04:
> it getting wider?
> better way?
> Cheers!
> Rick Measham
A. Try a parallel light.
b. Add a small transparent cylinder in the hole of the turret. It will make all of the
beam photons.
Before the first reflection, photons are not taken into consideration, they are after
that first
reflection. Adding the transparent cylinder, or a box, will stop the light and replace
it by the
photons. It may not be exactly how it works, but describe what appens.
Date: 17 Dec 2005 15:30:52
Message: <43a4757c$1@news.povray.org>
> it getting wider?
> better way?
If you are using a spotlight to create the beam, then the widening may
be caused by the natural dispersion of the beam.
I suspect that you might get better results by modeling the beam as a
set of cylinders, maybe with a cylindrical light source in each.
John
Date: 17 Dec 2005 17:39:23
Message: <43a4939b@news.povray.org>
> make all of the beam photons. Before the first reflection, photons are
> not taken into consideration, they are after that first reflection.
> replace it by the photons. It may not be exactly how it works, but
Thanks Alain, worked like a charm.
Here's the latest render with the parallel lights and the transparent
filter in the turret.
(The source will be available on my website once I've finished)
Cheers!
Rick Measham
Download 'example.jpg' (172 KB)
