POV-Ray : Newsgroups : povray.binaries.images : Beach Sunset - Photons Question Server Time
18 Feb 2025 17:37:19 EST (-0500)
  Beach Sunset - Photons Question (Message 1 to 10 of 10)
Subject: Beach Sunset - Photons Question
Date: 21 Aug 2005 09:54:45
Message: <430887a5@news.povray.org>
I've been experimenting with photons in this beach scene and I'm not 100%
sure if my setup is correct. This is the setup that I'm working with. Any
comments concerning photons would be appreciated.
global_settings {
  max_trace_level 100
  number_of_waves 40
  #if (DoPhotons)
  photons {
    count 200000
    autostop 0.5
    jitter .4
    media 200, 2
These are light source photons (lights inside my homebrew sky sphere) ....
// sun - main lighting
 light_source {
   <0,0,0>
   color PaleGoldenrod
   looks_like {
     sphere {<0,0,0>, 0.095
       material {Sun}
       hollow on
       interior {
          media {
          scattering {5, rgb 0.025}
          density {
          spotted
          scale 0.095
          color_map {
            [0.0 rgb <1.0000, 0.0000,0.4980>]
            [0.5 rgb <0.9525, 0.2695,0.0000>]
            [1.0 rgb <0.5430, 0.1445,0.0000>]
          warp {turbulence 10}
       //finish {ambient 3}
       translate <0,-0.125,0>
   #if (DoPhotons)
   photons {
    refraction on
    reflection on
   translate <0,0,2.5>
   rotate <357,230,0>
   media_interaction on
   media_attenuation on
   fade_distance 7.2*WorldSize
   fade_power 0.5
 // additional lighting
 light_source {
  <0,2,0>
  color PaleGoldenrod
  area_light
  <1, 0, 1> <-1, 0, -1> 3, 3
  adaptive 2
  jitter
  circular
  orient
  media_interaction off
  media_attenuation off
  fade_distance WorldSize*1.25
  fade_power 1
  #if (DoPhotons)
  photons {
    reflection on
    refraction on
and finally the targets .....
// the water
  #if (Detail)
    disc {
     <0,0.0001,0>, <0,1,0>, 2.75*WorldSize
     hollow on
     material {Water}
     #if (DoPhotons)
     photons {
       target
       reflection on
       refraction on
       collect on
#declare CatTail =
union {
  object {
    Reeds
    rotate <0,-10,0>
  object {
    Stem
    translate <0.01,0,-0.01>
    scale 0.95
  object {Tail}
  #if (DoPhotons)
     photons {
       target
       reflection on
       refraction on
       collect on
After rendering at :   +am2 +a0.1 +r6 +fn
I spotted this in the messages pane:
Number of photons shot:           93273
Surface photons stored:               1
Priority queue insert:         60761272
Gather function called:        62614147
Does that mean that I only got  1  valid photon?
Thanks Jim
Download 'Beach.png' (488 KB)
Preview of image 'Beach.png'
Subject: Re: Beach Sunset - Photons Question
Date: 21 Aug 2005 10:25:02
Message: <dea2o0$6vg$1@chho.imagico.de>
Yes, in such a scene you will never get reasonable results with photons
when you shoot them at the whole water surface.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 21 Aug 2005 11:28:03
Message: <43089d83@news.povray.org>
news:dea2o0$6vg$1@chho.imagico.de...
    Yikes .... I thought so! Is there anyway to only look at a section of my
water plane?
    I wanted to try to get some sparkles on the water. Am I on a fools
errand?
Jim
> Christoph
Date: 21 Aug 2005 11:55:02
Message: <dea7v1$869$1@chho.imagico.de>
> water plane?
To only get photons shot at a part of your water only activate them for
a part of the water. ;-)
> errand?
Photons won't show up on the water but you might get them on the ground
below the water or on surfaces above the water.
It is unlikely though that this would have a significant effect in such
a scene (caustics are not a very common effect in real life sunset
scenes either).
Date: 21 Aug 2005 13:03:46
Message: <4308b3f2@news.povray.org>
news:dea7v1$869$1@chho.imagico.de...
> To only get photons shot at a part of your water only activate them for a
would that be the radius keyword?
radius <gather_radius>,<multiplier>,
          <gather_radius_media>,<multiplier>
or better yet what would YOU do to get sparkles on the water .... should I
be reworking my Water material?
Thanks
Date: 21 Aug 2005 13:24:38
Message: <4308b8d6$1@news.povray.org>
a
I believe you have to make two separate water objects, one infinite (so it
goes out to the horizon) and one smaller (so it's only near your scene). You
could use the top of a big, short cylinder for the smaller part, and just
translate it slightly vertically so that it pops up above the infinite water
plane. Then shoot photons at the cylinder.
Well, photons aren't the right solution here. Photons won't change the
appearance of the water; rather, they'll bounce off the water and illuminate
whatever else they hit.
Since in real life, sparkles are caused by light reflecting off the water
into our eyes, specular highlights (phong or specular in the finish) may be
the best way to achieve this, but you might have to change the water's
normal to make the highlights the right size. (If so, you might try the
wrinkles pattern to get both large and small variations in the water
surface.) If you don't already have one there, put a red light source way
off in the direction of the sun. Then add a high specular value to the water
(higher = brighter sparkles) like 1 or 2, and a low roughness value (lower =
smaller sparkles) like .01 or less.
If you can't get the effect you want this way, you might try Chris Colefax's
"Lens Flare" include file which has a water-sparkle example.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Aug 2005 13:26:00
Message: <4308b928$1@news.povray.org>
> "Christoph Hormann" <chr### [at] gmxde> wrote in message
To get sparkles on the water you could use
specular or phong in the finish statement
of your water texture. This doesn't even
require photons.
Sebastian
Date: 21 Aug 2005 16:14:37
Message: <4308e0ad@news.povray.org>
"Sebastian H." <van### [at] gmxde> wrote in message
news:4308b928$1@news.povray.org...
> require photons.
> Sebastian
ahhh ... as the previous response also mentioned .... back to the drawing
board on the Water material.
Thanks Much
Date: 23 Aug 2005 01:03:34
Message: <430aae26$1@news.povray.org>
High!
I'm in doubt whether clouds can be already that reddened with the sun
still halfway above the horizon - I've in fact seen such evening skies,
but then the sun already has set completely, i. e. was not seen anymore...
See you in Khyberspace!
Yadgar
Now playing: Silver Circle (Bakmak)
Date: 23 Aug 2005 13:18:07
Message: <430b5a4f@news.povray.org>
news:430aae26$1@news.povray.org...
> High!
Hmmmm .... you could be right but it seems to me that I've seen sunsets
simular to the one attempting to model.
But what the hey it's POV I'm allowed a little poetic license aren't I?
Ciao
