POV-Ray : Newsgroups : povray.binaries.images : Asteroid City 2 Server Time
11 Jul 2026 23:32:37 EDT (-0400)
  Asteroid City 2 (Message 1 to 10 of 11)
Subject: Asteroid City 2
Date: 10 Sep 2004 11:13:10
Message: <4141c486@news.povray.org>
Getting closer, but still not there yet.
Download 'AsteroidCity2.jpg' (260 KB)
Preview of image 'AsteroidCity2.jpg'
Subject: Re: Asteroid City 2
Date: 10 Sep 2004 13:33:41
Message: <4141e575$1@news.povray.org>
I think you need to work on the lighting. Too much of the scene is covered
in grey patches of unlit surfaces, IMHO.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 10 Sep 2004 14:50:57
Message: <4141f791$1@news.povray.org>
Yeah, throw a radiosity block into your global settings and tweak it from
there.  Should come out pretty well.
Skip
Date: 10 Sep 2004 14:51:01
Message: <4141f795@news.povray.org>
4141e575$1@news.povray.org...
>  - Slime
On this point, I think using radiosity means you have to put ambient 0 on
every texture you don't want to be emitting light.
Unlit surfaces should be  less flat.
Marc
Date: 10 Sep 2004 15:25:59
Message: <4141ffc7@news.povray.org>
Not explicitly; assuming those textures don't already have individual
ambient settings, setting ambient 0 in #default will do the trick.
Textures that ARE supposed to glow can still have nonzero ambient.
On this note.. Bryan, if you replace the ambient with radiosity, low
quality settings will work fine (count 5 - 30, recursion 1, error_bound
1 - .5). You can always increase them later if you want to pick out
small details.
-Xplo
Date: 10 Sep 2004 15:46:56
Message: <414204b0$1@news.povray.org>
Radiosity is a possibility but not even really necessary; I'd decrease the
ambient light significantly (it's space after all), maybe move the primary
light source to illuminate more, and add a dim shadowless light somewhere to
get some shading in the unlit areas.
Of course, on top of that, everything could use better textures, but I'm
assuming that hasn't really been worked on yet.
The stars could be improved also; they look kind of stretched and stuff.
More like whitish blobs than bright distant objects.
 - Slime
Date: 10 Sep 2004 16:03:46
Message: <414208a2$1@news.povray.org>
Nice, seems like it's been awhile since we've had some traditional
spacescapes, (just Gail's recent scene.)  I like the sweep of the
composition and the continuity of foreground and background.  The
foreground terrain texture works remarkably well.
I recently picked up some classic scifi hard-science type easy-reads
Ben Bova for instance.
Would an asteroid like this be cratered?
Is it true that space equipment is perpetually scarred by radiation and
dust bombardment like they picture it in those novels?
Looks like you got some good crit from the others.
Date: 10 Sep 2004 16:11:36
Message: <41420a78@news.povray.org>
Actually that _was_ with radiosity.  This is what it looks like without.
The goal here is not to highlight the nuances of the unlit rock.  It's a fantasy scene
about a
colony on a large asteroid.
I could maybe use some ideas on rad settings to make it less boring.
Here are the current settings - pretty much pasted out of the insert menu...
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.01
      count 40
      nearest_count 10
      error_bound 0.5
      recursion_limit 1
      low_error_factor .5
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness .2
      adc_bailout 0.01/2
      normal on
Download 'AsteroidCity.jpg' (232 KB)
Preview of image 'AsteroidCity.jpg'
Date: 10 Sep 2004 20:10:35
Message: <4142427b@news.povray.org>
Oops that was the wrong attachment, sorry.
Date: 10 Sep 2004 23:19:57
Message: <41426EDA.CCB11D92@gold.sdsmt.edu>
Very nice.  I like how you softened the becon-beam, but you might try
placing one at each corner of the landing pad to create a descent
coridoor effect.  Just a suggestion.
Is this an asteroid mine, or an actual habitat?
I  like the concept of the Thistledown from Greg Bear's "EON"
ADB
