POV-Ray : Newsgroups : povray.binaries.images : "New Surface Subdivision Suite" examples Server Time
11 Jul 2026 23:32:25 EDT (-0400)
  "New Surface Subdivision Suite" examples (Message 1 to 8 of 8)
Subject: "New Surface Subdivision Suite" examples
Date: 29 Aug 2004 11:03:11
Message: <4131f02f@news.povray.org>
Here's some results from my latest experiments with
John VanSickle's "New Surface Subdivision Suite":
http://www.geocities.com/evilsnack/nsss.htm
Tor Olav
http://subcube.net
http://subcube.com
Download 'newsubdivisionsurfacesuite.jpg' (111 KB)
Preview of image 'newsubdivisionsurfacesuite.jpg'
Subject: Re: "New Surface Subdivision Suite" examples
Date: 30 Aug 2004 00:26:23
Message: <4132ac6f$1@news.povray.org>
I'd like to point out that My April 2004 IRTC entry
has a pair of aliens that use the same subdivision
surfaces as well.  Also, one of my two Jan 2004 entries
has a simple subdivided model as well.
These things get a whole lot easier to use when you
have a modeler (and the two models in the IRTC were made
using the modeler I've developed).  Now that I've got
uv-mapping working right (I think :-) I might update the
look of the Greb, and make one or two more alien races.
John
Date: 30 Aug 2004 19:05:16
Message: <4133b2ac@news.povray.org>
I just had a look at it. Nice !
"Programming" images is the way for me. - so I'll
see if I can find ways to use macros to generate
the vertices for the subdivisions.
> Now that I've got uv-mapping working right (I think :-)
> I might update the look of the Greb, and make one or
I don't understand how one can do UV-mapping on
surfaces with arbitrary topology. - I'll have to
read your documentation more thoroughly.
Btw.: Is there a way to make "inner" edges as sharp
as outer edges ? (See attached image.) I have tried
to specify sharp values for such "inner" edges, but
they don't seem get sharp at all.
Please explain.
Tor Olav
http://subcube.net
http://subcube.com
Download 'nsss_sharp_edges.jpg' (38 KB)
Preview of image 'nsss_sharp_edges.jpg'
Date: 30 Aug 2004 19:31:59
Message: <4133b8ef@news.povray.org>
The on-line docs contain an error.  A sharpness of -1 causes the
sharpness to be *on* for all levels of subdivision, and not off (as the
page erroneously states).
John
Date: 30 Aug 2004 19:46:49
Message: <4133bc69$1@news.povray.org>
Ok. Then I must have understood it right, even if it
was written wrong.
I have tried to specify different sharpness values
"manually" for such "inner" edges, but I'm still not
able to get them sharp.
Tor Olav
http://subcube.net
http://subcube.com
Date: 1 Sep 2004 19:21:45
Message: <41365989$1@news.povray.org>
> was written wrong.
I would do some testing to reproduce this problem, but
right now both of my machines are hip deep in an IRTC
render.
John
Date: 1 Sep 2004 20:15:04
Message: <41366608$1@news.povray.org>
> render.
Ok.
Then I'll investigate this further on my own, just to
make sure that I'm not doing anything wrong or mis-
understanding something.
Tor Olav
http://subcube.net
http://subcube.com
Date: 10 Sep 2004 00:03:09
Message: <4141277d@news.povray.org>
>> render.
> Ok.
I'm sorry.
The fault was all mine. I just found an insect in my code.
Now all is working as it should. (See attached image.)
Tor Olav
http://subcube.net
http://subcube.com
Download 'nsss_sharpedgesok.jpg' (32 KB)
Preview of image 'nsss_sharpedgesok.jpg'
