POV-Ray : Newsgroups : povray.binaries.images : Blue Mars Server Time
13 Nov 2024 20:31:44 EST (-0500)
  Blue Mars (Message 1 to 10 of 11)
Subject: Blue Mars
Date: 22 May 2004 01:44:37
Message: <40aee8c5@news.povray.org>
6ish hours on 1.8 GHz/512 DDR
Wanted to do spherical heightfield.  No specific info in docs.
Isosurface hmm, it can use pigments, la la l...hey wait, you
can use images in pigments.  Go my thinking process!
Mars bump is 16k x 8k, texture half that.  Not high enough res
to make out 'face'...oh well :P
Tim Cook
Version: 3.12
Download 'bluemars.jpg' (63 KB)
Preview of image 'bluemars.jpg'
Subject: Re: Blue Mars
Date: 22 May 2004 08:04:08
Message: <40af41b8@news.povray.org>
Awww... that's preeeeety :-)
Date: 31 May 2004 11:50:00
Message: <web.40bb5389f72d05f9a14125e90@news.povray.org>
> Tim Cook
> http://home.bellsouth.net/p/PWP-empyrean
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Your Blue Mars effort inspired me.  I had been wanting to create a spherical
height field for analyses that I was doing on Mars' surface features.  I
created an isosurface based on a Mars topo map as pigment.  The attached
image is the result so far (without the ocean sphere).  I can't seem to get
a complete map of the surface in spherical form.  Weird.  Is your map
complete?
Rick Smith
Download 'isosurface.jpg' (27 KB)
Preview of image 'isosurface.jpg'
Date: 8 Jun 2004 01:05:05
Message: <40c54901$1@news.povray.org>
"Richard Smith" <rms### [at] penet> wrote in message
news:web.40bb5389f72d05f9a14125e90@news.povray.org...
spherical
get
> complete?
Seeing as you haven't gotten a reply here yet, looks like the median pigment
value is at the threshold. Meaning, maybe you could change 'threshold' to
something other than 0 (greater than) and get the rest to show up. Either
that or a max_gradient being too low, but that usually doesn't appear so
clean in my experiences.
So if this was done by adding the function to a sphere the black parts are
probably ending up less than zero and so below the container sphere's
surface, if I'm thinking of all this correctly. I might be way off.
To Timothy Cook:  Wow! That's a beautiful view from space!
Bob H.
Date: 21 Jun 2004 11:52:01
Message: <web.40d2688df72d05f9fa7cbea50@news.povray.org>
> spherical
> get
> > complete?
> Bob H.
I'll check the things you mentioned.  I'm not entirely sure I am using
isosurface correctly.
Thanks for the suggestions.
Rick Smith
Date: 21 Jun 2004 19:51:13
Message: <40d77471$1@news.povray.org>
>>>spherical height field for analyses that I was doing on Mars' surface features.  I
>>>get a complete map of the surface in spherical form.  Weird.  Is your map
>>>complete?
Er...whoah, I didn't even see these replies originally...sorry!  ^_^;;
Hang on, let's see if your post is still there...
Tim Cook
Version: 3.12
Date: 21 Jun 2004 19:55:15
Message: <40d77563@news.povray.org>
> complete?
Hmm ok, here 'tis...yeah, as B. Hughes noted, looks like you have some
values extending byeond some boundary and being clipped.
Tim Cook
Version: 3.12
Date: 21 Jun 2004 22:15:00
Message: <web.40d79617f72d05f9ed725010@news.povray.org>
> > complete?
> Tim Cook
I've tried changing all the parameters but am unable to make the image any
more complete than it is.
Rick Smith
Date: 22 Jun 2004 00:09:36
Message: <40d7b100$1@news.povray.org>
humm...well, here's my code for the isosurface...with commentary
#include "functions.inc"
#declare fn_MarsPigm=function{
   pigment{
     image_map{
       tga "D:\3D\Textures\Mars\RMv3_Bump16K.tga"
       map_type 1
       once
       interpolate 4
     scale  <-1,1,1>   // right-hand rule; makes more sense to me,
     rotate 90*x       // since i started out doing autosketch/cad
isosurface{
   function{f_sphere(x, y, z, 3375)-fn_MarsPigm(x, y, z).red*30}
   // mars mean diam 3375 km, topo range 30 km...the image is greyscale
   // but pov's 'gray' function is weighted...? so i used red component
   contained_by{sphere{0,5000}}  // probably a bit much O.o;;
   pigment{
     image_map{
       jpeg "D:\3D\Textures\Mars\RMv3_FlatColor4K.jpg"
       map_type 1
       once
       interpolate 4
     scale  <-1,1,1>
     rotate 90*x
EOF
i included it in a moray document with some other stuff, and voila!
Tim Cook
Version: 3.12
Date: 22 Jun 2004 20:05:00
Message: <web.40d8c816f72d05f9c4afa97d0@news.povray.org>
>    pigment{
>      image_map{
>        tga "D:3DTexturesMarsRMv3_Bump16K.tga"
>        map_type 1
>        once
>        interpolate 4
> isosurface{
>    pigment{
>      image_map{
>        jpeg "D:3DTexturesMarsRMv3_FlatColor4K.jpg"
>        map_type 1
>        once
>        interpolate 4
>      scale  <-1,1,1>
>      rotate 90*x
> EOF
> Tim Cook
Thenks Tim.  I'll compare your code to mine and see if I've muffed it.
Rick Smith
