POV-Ray : Newsgroups : povray.binaries.images : isosurface does not render as expected Server Time
11 Sep 2025 14:36:49 EDT (-0400)
  isosurface does not render as expected (Message 1 to 7 of 7)
Subject: isosurface does not render as expected
Date: 19 Apr 2004 10:21:33
Message: <4083e069@news.povray.org>
hello,
i made a try to look behind the the technique of isosurfaces. so i
read the Povray-documentation delivered with Povray
(file:/opt/povray35_first/share/doc/povray-3.50a/html
povdoc_082.html#target_137).
i was surprised that my results are not the same as shown in
documentation.
it should look like iso_23.gif but does look like iso_map.jpg.
as you can see i use self-compiled 3.50a-version of Povray.
is there my mistake?
or did i missunderstood the documentation so my code is wrong?
additionally i read a isosurface-tutorial under
http://www.econym.demon.co.uk/isotut/
it is nice. but what i need is a more basic one or one even better
than Povray's. does anyone know where i can find them in net?
thanks for help in advance.
this is the code i have written:
//------------------------------>>iso_map.pov
#version 3.5
#include "functions.inc"
#declare radiosity_on=true;
//#declare radiosity_on=false;
global_settings {
        adc_bailout 0.00392157
        assumed_gamma 1.5
        ambient_light 2
        #if (radiosity_on)
                radiosity {
                gray_threshold 1
        #end //if
#declare cam1=
        location <0,2.5,-2.5>
        look_at <0,0,0>
camera { cam1 }
light_source {
        <5,5,-5>
        color <255,255,255>/255
plane {
        y,-0.1
        pigment { color <255,255,255>/255 }
#declare fn_Pigm=function {
       agate
       color_map {
         [0 color rgb 0]
        [1 color rgb 1]
isosurface {
        function { f_sphere(x, y, z, 1.6)-fn_Pigm(x/2, y/2, z/2).gray*0.5 }
        pigment { color <255,225,32>/255}
        rotate y*-30
//------------------------------<<iso_map.pov
Download 'iso_23.gif' (8 KB) Download 'iso_map.jpg' (9 KB)
Preview of image 'iso_23.gif'
Preview of image 'iso_map.jpg'
Subject: Re: isosurface does not render as expected
Date: 19 Apr 2004 10:43:33
Message: <Xns94D0AA132D3C5raf256com@203.29.75.35>
not### [at] availablenet news:4083e069@news.povray.org
> isosurface {
>         z/2).gray*0.5 } pigment { color <255,225,32>/255}
You probably should
1) define bigger cointainer box i.e. cointained_by { sphere { 0 3 } }
2) maybe increase max_gradient
http://www.raf256.com/3d/
Computer Graphics
Date: 19 Apr 2004 10:49:06
Message: <4083e6e2$1@news.povray.org>
Unless you specify the contained_by-'object', inside the isosurface, (which
limits the area where POV-Ray samples for the surface of the function) a box
{ <-1, -1, -1>, <1, 1, 1>} will be used as default.
Consult your helpfile.
Werner Vesteraas
Oslo,
Norway
Date: 19 Apr 2004 10:55:00
Message: <web.4083e7168768e240a1fd027f0@news.povray.org>
> isosurface {
>         rotate y*-30
I don't see a bounded_by statement in there.  Maybe if your the default
bounding box is something like box { 1, -1 } then it would certainly cut
off most of your 1.6 radius sphere.
Try inserting this statement right beneath function{...}:
bounded_by { box { 2, -2 } }
That should make the bounding box plenty big enough for your sphere.  At
least, if that IS the problem.
Budge
Date: 19 Apr 2004 11:00:00
Message: <web.4083e8ff8768e240a1fd027f0@news.povray.org>
> Budge
Its official.  I'm a retard.  All those "bounded_by"'s in there should be
"contained_by"
Two other people got it right before I did, though :)
Budge
Date: 19 Apr 2004 11:01:03
Message: <Xns94D0AD0AADA79raf256com@203.29.75.35>
bud### [at] yahoocom news:web.4083e7168768e240a1fd027f0@news.povray.org
All is true, but just You mistaken bounded_by with contained_by.
The second option is needed, bounded_by will be calculated automaticly, but
You can specyfie it default (and/or another bounding-related segment -
clipped_by)
Computer Graphics
Date: 19 Apr 2004 11:05:58
Message: <4083ead6@news.povray.org>
Rafal 'Raf256' Maj wrote:
> You probably should
this was my problem. thank you for helping!
