POV-Ray : Newsgroups : povray.binaries.images : Why does it do this? Server Time
15 Apr 2026 22:01:28 EDT (-0400)
  Why does it do this? (Message 1 to 10 of 16)
Subject: Why does it do this?
Date: 7 Apr 2004 23:11:16
Message: <4074c2d4@news.povray.org>
The images are of a series of thin translucent boxes with small spaces
between each. The effect of added opacity for each added layer is realistic,
until it gets to the fifth layer, where the completely opaque dark
rectangles appear. It seems totally illogical to me. Test01a has an ordinary
material with no interior or finish. Test01b has an interior with scattering
media. Since they both have the same problem, it can't be blamed on anything
to do with media. I've tried every variable I can think of with no success.
Does anyone know what causes this, and if there is a cure for it?
Steve Shelby
Download 'test01b.jpg' (8 KB) Download 'test01a.jpg' (11 KB)
Preview of image 'test01b.jpg'
Preview of image 'test01a.jpg'
Subject: Re: Why does it do this?
Date: 7 Apr 2004 23:17:39
Message: <4074C405.8000300@hotmail.com>
Steve, have you checked the max_trace_level setting in global_settings?
I'm 99% sure this is your problem, since the default max_trace_level is
five. If it's set too low you will get opaque effects (usually black).
Try this at the top of your scene file:
global_settings{
  max_trace_level 10
Keep bumping it up until the black opaque areas are vanquished.
Hope this helps.
-Samuel Benge
> rectangles appear. <snip>
Date: 7 Apr 2004 23:50:59
Message: <4074cc23$1@news.povray.org>
That's it! Thank you very much! I don't think I would have ever figured it
out on my own. I had to move it to 15 to get the desired results.
Steve
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:407### [at] hotmailcom...
> global_settings{
>   max_trace_level 10
> Hope this helps.
> -Samuel Benge
realistic,
Date: 8 Apr 2004 00:03:44
Message: <Xns94C53DA63B2BEraf256com@203.29.75.35>
ssh### [at] rexnetnet news:4074cc23$1@news.povray.org
>> > spaces between each. The effect of added opacity for each added
>> > layer is realistic,
> figured it out on my own. I had to move it to 15 to get the desired
> results. Steve
Btw, adc_bailout was fixed in 3.6 beta and/or will it be in 3.6 final?
It was a quite serious time-wasting bug IMHO.
PS. please do not top-post, answare *below* quote of post to with are You
answearing.
http://www.raf256.com/3d/
Computer Graphics
Date: 8 Apr 2004 00:18:53
Message: <4074D25F.2020502@hotmail.com>
Couldn't possibly answer that. In fact, I didn't know there was a bug! I
hope this means rendering many layers of transparent objects (or
multiple reflections) will be made faster.
> answearing.
There are advantages to answering both ways, depending on how many
statements I'm replying to.
-Samuel Benge
Date: 8 Apr 2004 00:19:23
Message: <4074d2cb$1@news.povray.org>
<snip />
> answearing.
He wasn't using naughty words in his answer! :-P
Respectfully,
Dan P
http://<broken link>
Date: 8 Apr 2004 03:20:19
Message: <Xns94C55EFAECF1Fraf256com@203.29.75.35>
stb### [at] hotmailcom news:407### [at] hotmailcom
>> final? It was a quite serious time-wasting bug IMHO.
> I hope this means rendering many layers of transparent objects (or
Bug was that transparency / reflection was unnesesarly shooted even if
resulting color changes would be smaller then 1/256 (so they would not be
notacible in image). (I think even 1/64 is a good limit).
So if You set max_trace_level to 100 because in few space You have 100
boxes in each other, transparent, it will not only use 100 rays / pixel
there, but laso it will use it every else, so most reflective-seeing-
reflective surface will render 100 times slower, even if reflection is 0.1
and final step of rendering each pixel will "result in only change like
+/- 0.000000000000000000000000000000000000000000000000000000001 rgb ;)
>> You answearing.
Sorry, wrong word ;)
Computer Graphics
Date: 8 Apr 2004 05:47:39
Message: <40751fbb@news.povray.org>
> > answearing.
  Quoting properly is an art. But it's an art which everyone should master,
in my opinion. It makes your articles more readable and better organized.
  Some people seem to lack the notion of being able to *edit* quotes.
By editing I don't mean changing them (which you *never* should do,
heaven forbid!), but to remove irrelevant parts in order to make the
quotes as short and clear as possible (but of course you shouldn't remove
relevant parts of the quote in such way that it may change the meaning of
what you leave).
  Answering to an article should usually look like this:
> Original statement
Answer to that statement
> Another original statement
Answer to this one.
etc.
  That is, quote first, answer then (not the other way around), and
answer to each point separately, not to everything in a single block
of text.
  Don't quote too much. Quoting too much is specially bad if you are
answering to a single statement among tens of others. As said before,
remove unnecessary quotes until you have the essential part. Sometimes
people use "[snip]" or "[xyz removed]" or something similar to indicate
that more essential (but long) parts were removed (and that the reader
should refer to the original article if he wants to know).
  Sometimes you might even want to not to quote anything at all.
This is specially true when the original article is longish and you
are answering to the whole idea in it, not to any specific statement
inside it. If people want to know what you are answering to, they can
go one article back in the thread to see it.
Date: 8 Apr 2004 06:17:24
Message: <407526b4$1@news.povray.org>
"A: Top posters.
Q: What is the most annoying thing on Usenet?"
that about sums it up :)
cu!
Date: 8 Apr 2004 09:52:43
Message: <ltla705cs6ci6qojqgpqo1s2jeikjgoaqa@4ax.com>
On Wed, 7 Apr 2004 22:50:55 -0500, "Steve Shelby" <ssh### [at] rexnetnet>
>out on my own.
Check the messages after every render.  This will clear up lots of
mysteries, including max_trace_level exceeded.
------------------- Richard Callwood III --------------------
~  U.S. Virgin Islands    ~  USDA zone 11  ~  18.3N, 64.9W  ~
~  eastern Massachusetts  ~  USDA zone 6 (1992-95)          ~
--------------- http://cac.uvi.edu/staff/rc3/ ---------------
