POV-Ray : Newsgroups : povray.binaries.images : Merry christmas [70k] Server Time
21 Jun 2026 04:30:15 EDT (-0400)
  Merry christmas [70k] (Message 1 to 10 of 12)
Subject: Merry christmas [70k]
Date: 21 Dec 2003 04:02:10
Message: <3m3gb1-4ch.ln1@triton.imagico.de>
The snowman is reused from an old image:
http://www.tu-bs.de/~y0013390/pov/pict/snowman.jpg
The sky is made with the skylight macro from Jaime's lightsys:
http://www.ignorancia.org/t_lightsys.php
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Download 'snowman2.jpg' (71 KB)
Preview of image 'snowman2.jpg'
Subject: Re: Merry christmas [70k]
Date: 21 Dec 2003 10:32:28
Message: <3fe5bd0c$1@news.povray.org>
Christoph:
Nice.  This might be the best of your many landscapes so far.
Aaron
Date: 21 Dec 2003 10:45:33
Message: <3fe5c01d$1@news.povray.org>
Yeah, those mountains really look very good. Do we get the source as a Christmas
present ;)
Ryan
"Aaron Gillies" <bee### [at] snickerorg> wrote in message
news:3fe5bd0c$1@news.povray.org...
> Christoph:
> Aaron
Date: 21 Dec 2003 13:41:27
Message: <3fe5e957$1@news.povray.org>
Nice.
I just found and downloaded the new version of lightsys. Any idea why it
doesn't work with MegaPOV1.0 ?  It works with POV3.5 !
Yesterday I played with the skylight macro (apparently an older version from
this news archieve) but I ran into many problems with light intensity. The
sky around the sun couldn't get bright enough to give correct reflections.
Has this issue been addressed?
Hugo
Date: 22 Dec 2003 14:43:19
Message: <3fe74957$1@news.povray.org>
Very nice image, Christoph. Excellent for a quick christmas card,
indeed. No snow around here to check realism, sorry... :)
   To be honest, this version of skylight.inc is the work of Philippe
Debar, adapted by Ive to work with Lightsys: I even don't remember if I
myself done any little teaking...
   I don't know if the results are very accurate, but it gives slighty
nicer results than the original version.
Jaime
Date: 22 Dec 2003 14:50:18
Message: <3fe74afa$1@news.povray.org>
   How? ...what's the error? I can't figure why it will not work (I
don't have MegaPOV right now to test).
   Hmmm... I think the answer is no, but try yourself, please.
Jaime
Subject: Re: Merry Christmas - Lightsys error message
Date: 22 Dec 2003 16:31:46
Message: <3fe762c2@news.povray.org>
>  (I don't have MegaPOV right now to test).
Glad to see you stopped by! The updated lightsys is great! The bug is a bit
difficult for me to track down. The error message prevents all your demos /
templates / tests to parse. I have 4 versions of POV-Ray installed. They all
claim to be based on the POV3.5 source, but your macros only work in 2
versions:
Official POV3.5  = works.
Unofficial MLpov 0.81   = works.
Unofficial POVman 1.0   = breaks.
Unofficial MegaPOV1.0  = breaks.
Here's an example of the error message:
File: demo_cyndi_cubes.pov  Line: 38
#declare LC1 = EmissiveSpectrum(ES_Osram_CoolFluor_36w) <----ERROR
Parse Error: Expected '( or [', ) found instead
Returned from renderer with error status
When I add () it complains that no value was found in between the
parantheses. When I write (1) it breaks the macros. Maybe it has something
to do with splines, since "ES_Osram_CoolFluor_36w" refer to a spline...(?)
Best regards,
Hugo
Date: 23 Dec 2003 02:12:48
Message: <4hqfuvgtf76hs5l39sbcspt9o84nf3da3d@4ax.com>
On Mon, 22 Dec 2003 22:32:19 +0100, "Hugo Asm" <hua### [at] post3teledk> wrote:
Yes, there is known problem of spline being parameter. It is fixed for next
release, meantime try to add spline{} around ES_Osram_CoolFluor_36w. It should
help. Sorry for inconvenience.
ABX
Date: 28 Dec 2003 11:42:03
Message: <d8d3c1-h7e.ln1@triton.imagico.de>
Thanks.
The snow is indeed the weak point - i played with the idea of a
subsurface scattering version but this scene is not fast enough and the
geometry is not that good to show the scattering anyway.
The problem i have with the skylight macro is that it does not offer
much control over the colors.  I used a different light color for the
sky than for the light source to have more freedom in that part.
Another thing is of course that the use of a mesh for the sky is
certainly not the best solution - although it is of course the only
viable one with standard POV. A feature to have image_maps based on an
internal array (or an ascii hdr file format) would be useful for this.
Date: 28 Dec 2003 11:52:03
Message: <3sd3c1-i4g.ln1@triton.imagico.de>
> present ;)
The mountains are actually quite simple, the structure is made with a
f_ridged_mf() function and the coloring with a slope pattern.  I posted
examples for this in the past:
Subject: Re: iso - ridged mf question
Date: Mon, 12 Mar 2001 19:20:26 +0100
Newsgroups: povray.unofficial.patches
news://news.povray.org/3AAD136A.E955EBF@gmx.de
http://news.povray.org/3AAD136A.E955EBF@gmx.de
Subject: Re: Isosurface troble
Date: Mon, 05 Aug 2002 22:58:41 +0200
Newsgroups: povray.general
news://news.povray.org/3D4EE701.AF500714@gmx.de
http://news.povray.org/3D4EE701.AF500714@gmx.de
Subject: Re: hf and slope
Date: Wed, 21 Mar 2001 17:08:21 +0100
Newsgroups: povray.advanced-users
news://news.povray.org/3AB8D1F5.7D4595C7@gmx.de
http://news.povray.org/3AB8D1F5.7D4595C7@gmx.de
