POV-Ray : Newsgroups : povray.binaries.images : another landscape Server Time
19 Oct 2024 12:21:35 EDT (-0400)
  another landscape (Message 1 to 10 of 11)
Subject: another landscape
Date: 21 Sep 2003 15:18:12
Message: <3f6df974@news.povray.org>
Hi all,
yet another landscape. I've spent the last couple of days re writing my code
to use isosurfaces instead of height fields.The attached image is the first
major test. It was rendered with the isosurface, atmospheric media and
clouds, media water, radisoity and aa. The render took 9.5 hours on my p4.
Download 'land4.jpg' (147 KB)
Preview of image 'land4.jpg'
Subject: Re: another landscape
Date: 21 Sep 2003 15:42:08
Message: <3f6dff10$1@news.povray.org>
Hey Nathan!
Looks damn cool! Nice landscape, great skies, cool water...
But I think the texture of the rocks needs a bit of tweaking. Looks to
plastic-like IMHO.
Nice idea for your project would also be to include automated
placement of grass (Gilles' MakeGrass) and trees (Gilles' MakeTree or
TomTree).
Keep up the great work!
Florian
//=================[web: http://www.torfbold.com]==================\\
#local a=-5;#while(a<5)sphere{<sin(a*pi)*5a*10pow(a,5)*.01>sin(a*a*a*
.1)+1pigment{rgb 9*z}}#local a=a+.01;#end camera{look_at-y*10location
<8,-3,-8>*10}// [www.povray.org]     [www.imp.org]     [www.irtc.org]
Date: 21 Sep 2003 17:12:02
Message: <sjg141-cns.ln1@triton.schunter.etc.tu-bs.de>
Nathan O'Brien wrote:
> Hi all,
The composition is very nice.  I can't see much effect of the radiosity
though.
Once thing i have observed in all your recent landscape scenes is the
very dim lighting - nearly like a full moon night scene.
Is it one isosurface or a combination of several objects?
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 21 Sep 2003 17:22:49
Message: <3f6e16a9@news.povray.org>
news:3f6df974@news.povray.org...
code
first
Hi Nathan
This is quite promising, but you should try to find a way to increase the
tone range, as it's much too dark right now. The other pictures suffered
from that problem too.
See a tone-corrected version below (I just stretched the half and high tone
values).
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Download 'land4.jpg' (46 KB)
Date: 21 Sep 2003 17:24:22
Message: <3F6CC545.60506@aol.com>
Texturing needs a little work, but I think the rock formations are
great! The render time, however, is a little long..... How long would it
take without atmospheric and water media?
I think you're making notable strides in the field of complex, detailed
landscape creation. I tried to make a height_field patchwork like your
last image, but was plagued with large gaps. I saw a good idea the other
day.... somebody was making turbulent oceans with a radiating mesh, not
entirely unlike a height_field, the main differences being it was disc
shaped and most of the detail was near the middle. Since objects that
are farther away are smaller and have less detail, the setup was ideal
for water, and probably landscapes too. I plan on making one soon. It
would be a perfect height_field2 if anybody were to ever make it into a
pacth:)
Samuel Benge
stb### [at] aolcom
Date: 21 Sep 2003 19:45:01
Message: <web.3f6e37222cd0d59ea0dca75e0@news.povray.org>
>plastic-like IMHO.
I agree. At the moment they are flat pigments. I'm going to start working on
thata rea soon.
>TomTree).
I've already created some placement macros for rocks and should have a grass
version up soon. I was thinking of creating a Java interface to run the
whole thing, in an ideal world it could then be integrated with Gena's Java
tree interface to Tomtree.
Date: 21 Sep 2003 19:50:01
Message: <web.3f6e386e2cd0d59ea0dca75e0@news.povray.org>
I'm using a flat panel screen now. I've noticed a big difference when the
images are displayed on a crt screen. I'll have to play with my gamma
steeings for the next render.
There are actually 316 individual isosurfaces that have been tiled. Each
isosurface has been optimised for its container (just big enough), its
max_gradient (exact) and its accuracy (based upon distance from the
camera).
I've written a series of pre parsing macros that do all the hard work. On
tests it looks like I've picked up about a 40-50% speed increase on a
single optimised isosurface when using the atmospheric media and radiosity.
Message: <web.3f6e390e2cd0d59ea0dca75e0@news.povray.org>
>values).
I agree. Still coming to terms with the flat panel display (need some gamma
correction) and the radiosity settings I'm using need a lot more work. The
interaction with the media needs some finer control.
Date: 22 Sep 2003 03:02:02
Message: <k9j241-hc3.ln1@triton.schunter.etc.tu-bs.de>
It is not just a matter of gamma, the scene is also too dark as a whole
and the brightness relations are wrong.  For example the lit parts of
the terrain are too uniform in brightness - if you adjust the image it
all looks washed out.
> camera).
Interesting.  Are there no problems at the borders between the tiles?
Date: 22 Sep 2003 04:05:01
Message: <web.3f6eacd82cd0d59ea0dca75e0@news.povray.org>
The lcd flat screen seams to increase the image contrast. Probably because I
keep the ambient lighting low in my study. Will try and preview images in a
different environment before I settle on the lighting settings.
>> camera).
I've had no problems at the tile borders. Sometimes small errors appear when
the maximum Y value of a container is set to low. When that happens I
either hand correct it if it's just one tile, or increase the sample rate
of the macro that calculates the Y values if there are lots of errors. It
also helps to have only a small step in the accuracy between each
isosurface. Most of this is handled with pre parse macros.
